Changing Filters
Old 04-22-2024, 04:58 AM
pcmcia's Avatar
Changing Filters
I need to change the engine and cabin air filters for my 2019 RDX. What brand of filters do you recommend?
Also, I haven't done the engine air filters before. It seems pretty easy from this youtube video:
. Any gotchas that I should be aware of?
Thanks!
Old 04-22-2024, 05:44 AM
russianDude's Avatar
You will probably break plastic fasteners in the process, so be sure to buy replacements before attempting it
Old 04-22-2024, 07:56 AM
Texasrdx21's Avatar
Pretty simple. I buy the ones on amazon, typically you have lots of name brand choices that are inexpensive (both together are less than $35).
  1. Air cab filter is super easy, double door inside the back of the glove box.
  2. Engine Air filter - simple tool - like the "RussianDude" noted, the OEM plastic push pins break easily. You really only need to remove 2-3 of them, then the rest is pretty straight forward.
Lots of good "how to videos" on Youtube to do both.
Old 04-22-2024, 12:43 PM
John from PA's Avatar
With respect to quality, of the two filters, the engine air filter is more important than the cabin air filter. So my thought would be to use the OEM for the engine, or a reputable brand like Fram, Purolator, etc. As others have mentioned you likely will break one or more of the plastic clips. They are available at the dealer (Acura or Honda) at about $4 each, or you can get a bag of a dozen off eBay for about $10. The Acura ones (2022 RDX) have a P/N of 91501-S04-003. An eBay listing for 20 pcs. can be found at https://www.ebay.com/itm/15617791178...Bk9SR8rbsu7gYw
23LunarSilverASpec (04-22-2024)
Old 04-22-2024, 02:12 PM
Received 1,748 Likes on 1,402 Posts
Also, I haven't done the engine air filters before. It seems pretty easy from this youtube video: https://www.youtube.com/watch?v=md4a1Ly8S8Q. Any gotchas that I should be aware of?
Thanks!
Just an FYI.
If you are leaning toward the brand name high flow air filter used in the video & don't want to pay the premium price, you can find a surprisingly high quality foreign 'knock-off' equivalent on ebay for $22 shipped.
FOR 2019-2020 ACURA RDX 2.0L RED HI-FLOW ENGINE DROP-IN AIR FILTER INTAKE PANEL | eBay
I just installed one of these specific for my 03 CL-S automatic factory air box, as an experiment, just the other day.
The ebay item description claims that the filter pleats don't need oil; however, since I already had K&N oil available, for the cone filter on my S/C'ed CL-S6, I lubed it up anyway.
So far, so good.
Old 04-22-2024, 06:32 PM
supafamous's Avatar
Also, I haven't done the engine air filters before. It seems pretty easy from this YouTube video. Any gotchas that I should be aware of?
Thanks!
Very easy to do but like RussianDude says you're going to break a clip or two while doing it. The one I broke was not essential so I haven't put in a new clip yet - it cost $5CAD though. Brand wise I just use Fram - easy to find in my neck of the woods but any major brand is fine.
Old 04-22-2024, 07:34 PM
attofarad's Avatar
I bought a box of various plastic clips at Harbor Freight, or they are also available on Amazon. I haven't used them yet. They may or may not exactly match the factory clips, but I expect some to fit okay.
I will either use the Purolator A31440 from Amazon, or order the factory filter from acura.oempartsonline.com for ~$25 plus shipping, along with other parts.
I just replaced the cabin filter, at 2 yrs and 23k miles, and it absolutely did not need doing. That will vary a lot depending on whether you park the car outside (leaves, pollen, dust). Since it is so easy, you may want to just take 5-10 minutes and inspect the cabin air filter. The factory filter does have more pleats (good thing) than most aftermarket ones.
Old 04-23-2024, 04:42 PM
daRthDX's Avatar
Ha... Just as I was in the midst of changing out my own filters this thread popped up. I broke a clip too - it was one of the ones for the air intake. Referred to an older thread here: Broken clip - AcuraZine - Acura Enthusiast Community and the parts guy at the dealership independently brought up the same diagram showing the clips. Part number is 91512-5K7-003. They snap in great! Removal isn't as much fun.
As for my filters - it's only been about a year but my cabin air filter really really needed replacing. Dusty around here I guess. Engine air filter didn't need it as badly but it's done and I have a couple spare clips for next time!
Old 04-24-2024, 05:16 AM
pcmcia's Avatar
Thanks all for the reply!
Does anyone know whether these clips from Amazon (
Amazon Amazon
) with part number 91512-SX0-003 work? I can't seem to find part number 91512-5K7-003 on amazon.
Thanks!
Old 04-24-2024, 06:47 AM
It should be OK. The actual Honda/Acura part measures flange diameter 20 mm, for a 5/16 inch or 8 mm hole and a stem length of 10 mm. Your Amazon link didn't work but some searching seems to indicate that the 91512-SX0-003 has a stem length of 11 mm. The link I used is
91512-SX0-003 91512-SX0-003
Old 04-24-2024, 09:51 AM
Received 8,597 Likes on 6,640 Posts
Amazon Amazon
I bought this kit that has various lengths and diameters
Old 04-24-2024, 01:47 PM
https://www.amazon.com/gp/product/B07X5RVNRZ/
Nice kit but at the age of 81 I don’t buy green bananas let alone a bunch of clips I probably won’t ever need.
Texasrdx21 (04-24-2024)
Old 04-24-2024, 09:51 PM
jmhumr's Avatar
For cabin filter I use this Bosch one:
https://a.co/d/8mkgNJY
smitty56
11-05-2023 10:41 AM
Frecks82
3G RDX Performance Parts & Modifications
01-06-2020 06:44 PM
Hou-RL
3G RDX DIY & FAQ
12-10-2019 07:00 AM
Phoenix Rob
01-29-2018 12:58 PM
db78
04-24-2010 10:04 PM
Quick Reply: Changing Filters
