Transmission fluid question
Old 04-19-2014, 01:13 PM
Primitive6's Avatar
finally got my TL shipped here to me in San Diego! I dont know when the transmission fluid was last serviced.....is thisd something i should just do or if its clean leave it alone? im at about 90k
Old 04-19-2014, 01:40 PM
Due_Diligence's Avatar
If you have no knowledge about how the transmission was maintained I would recommend changing it just to be safe. I will be doing my second drain and fill tomorrow with redline D4 assuming your car is auto.
Old 04-19-2014, 06:12 PM
1KLRTOY's Avatar
And BE SURE to change the pressure switches
Old 04-19-2014, 07:49 PM
LaCostaRacer's Avatar
Welcome to San Diego. The normal change interval is 60k miles so perhaps it was changed then or never. I would change the ATF if I were you. The tip about changing the pressure sensors is good since you'll already be doing the fluid. It's easier to pull the driver's wheel to get to the sensors.
mada51589
05-03-2022 08:54 PM
Yikes
05-03-2021 04:29 PM
cobra10363
01-16-2021 08:12 PM
ghuns
09-16-2015 04:26 PM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: Transmission fluid question
