Front end noise - AcuraZine Community
AcuraZine Acura Forums HomeAcura CL ForumsAcura MDX ForumsAcura NSX ForumsAcura RDX ForumsAcura RL ForumsAcura RSX ForumsAcura TL ForumsAcura TSX ForumsAcuraZine Regional DiscussionAcuraZine Off Topic Discussion
Go Back   AcuraZine Community > AcuraZine TL Community > First Generation TL (1996-1998) > Problems & Fixes
Welcome to Acurazine.com!
Welcome to Acurazine.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Acurazine.com community today!
Old 10-14-2009, 9:38 AM   #1
TLin401
iSwindle™
1996 Acura TL
TLin401's Avatar
Trader Rating: (0)
Front end noise
Sooooo.....
This morning I'm leaving my house and I come to a stop at the end of my street and I hear two cycles of popping, one right after the other.
The noise only occurs when the car is coming to a stop and the needle is around 5-10 mph. I have never noticed it before. I also felt the vibrations in my foot on the pedal.
I hear the noise coming from the front driver's side wheel.
This popping continued until the car warmed up a little bit and then it went away.
Any ideas?
This ad is not displayed to registered or logged-in members.
Register your free account today and become a member on Acurazine!
__________________
.......got Swindle??
Quote:
Originally Posted by Mr. Maker View Post
my point is that this is an open forum..everything is a matter of opinion...some enjoy hard shell tacos while others like soft...
TLin401 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-14-2009, 11:32 AM   #2
96TL_X
Registered User
96TL_X's Avatar
Trader Rating: (0)
I have this problem too, couple months ago I took it to the shop(not because of this problem) and the guy told me I should change the axle for some reason. Idk if this is the reason.
96TL_X is offline   Reply With Quote
Old 10-14-2009, 12:48 PM   #3
TexasHonda
Registered User
Trader Rating: (0)
Inspect your drive shaft boots. A broken boot loses the grease and begins to make noise, usually when turning, but might do also when decelerating.
Other possibilities are loose ball joints; upper, lower, tie-rod bj's.
good luck
__________________
1997 Acura 2.5 TL
2007 Honda Accord LX/SE
1994 Honda Accord
I don't drive em, just fix em.
TexasHonda is offline   Reply With Quote
Old 10-14-2009, 12:57 PM   #4
TLin401
iSwindle™
1996 Acura TL
TLin401's Avatar
Trader Rating: (0)
I just had my ball joints replaced in august.
I'll check them out and let you all know.
It also makes the noise when I turn to the left. When I turn to the right it is fine.
But no matter what, when I stop before the car warms up, it makes a popping noise once and then again. Kind of like a shift down.
__________________
Old 10-14-2009, 9:55 PM   #5
Go90go
大日本帝国
Go90go's Avatar
Trader Rating: (0)
^ My brakes do that before they're warmed up to the proper temp. Maybe it's the same thing?
~Cheers~
Go90go is online now   Reply With Quote
Old 10-14-2009, 10:12 PM   #6
TLin401
iSwindle™
1996 Acura TL
TLin401's Avatar
Trader Rating: (0)
So this is a common problem.
how long has yours been doing this?
__________________
Old 10-14-2009, 11:24 PM   #7
tmnhs81
Registered User
tmnhs81's Avatar
Trader Rating: (0)
__________________
1997 Acura 3.2TL.
Quote:
Originally Posted by FiftyFive View Post
LMAO = Lick My Anal O
tmnhs81 is offline   Reply With Quote
Old 10-14-2009, 11:26 PM   #8
TLin401
iSwindle™
1996 Acura TL
TLin401's Avatar
Trader Rating: (0)
You have this problem too?
__________________
Old 10-14-2009, 11:49 PM   #9
tmnhs81
Registered User
tmnhs81's Avatar
Trader Rating: (0)
No. I am bored and nothing to say about this problem so I thought why not just say hi to ya people... This is what happens when you get a day off from work after almost a month and have nothing to do because your brain doesn't work anymore... 1G side was dead from last few days.
__________________
1997 Acura 3.2TL.
Old 10-23-2009, 1:39 AM   #10
Troyble2
Registered User
Trader Rating: (0)
Check your drive shafts and bearings
I replaced both drive shafts, because of the shimmy. I assume you'd know if was the CV's. Mine were fine, so I replaced the whole drive train.Not only the shafts but the front wheel bearings. They're guaranteed for life but they were dry and rattling. When I test drove I drove around the Wal Mart parking lot. All good. Went to the stop sign and had nothing. They lock in and I kinda knew that I didn't see the left side through. So, jack her up, finally click the axle and away I went.
If I had of diagnosed it correctly, I'da known that it was the bearings. But I replaced both drive axles anyway. Cost me fifty dollars each. But with 230,000 and counting it was money well spent. Look to your front wheel bearings, and if you decide to do it yourself, understand that you must press them to a certain pressure. THere are DIY's here for this.
Troy
96' TL 2.5 One Owner
Troyble2 is offline   Reply With Quote
Old 11-03-2009, 5:14 PM   #11
TLin401
iSwindle™
1996 Acura TL
TLin401's Avatar
Trader Rating: (0)
Bump...
I believe that I have figured out the problem.
Since it only happens when it brakes, I am suspecting this noise to be coming from a "frozen" caliper.
It makes sense since when the car warms up it goes away.
All of the symptoms make sense to me.
What do you all think?
__________________
Tags
2000, acura, axle, end, front, hard, honda, left, mdx, noise, noises, popping, tl, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
