Check engine codes p0135 & p0141 - AcuraZine Community
AcuraZine Acura Forums HomeAcura CL ForumsAcura MDX ForumsAcura NSX ForumsAcura RDX ForumsAcura RL ForumsAcura RSX ForumsAcura TL ForumsAcura TSX ForumsAcuraZine Regional DiscussionAcuraZine Off Topic Discussion
Go Back   AcuraZine Community > AcuraZine TL Community > First Generation TL (1996-1998)
Welcome to Acurazine.com!
Welcome to Acurazine.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Acurazine.com community today!
Old 10-25-2009, 6:39 PM   #1
Yoyon
Registered User
Trader Rating: (0)
I have those codes on my 96 Acura TL, can somebody tell me what to do?
P0135
41
Primary HO2S Heater Circuit Malfunction
P0141
65
Secondary HO2S Heater Circuit Malfunction
This ad is not displayed to registered or logged-in members.
Register your free account today and become a member on Acurazine!
Yoyon is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-25-2009, 6:47 PM   #2
tmnhs81
Registered User
tmnhs81's Avatar
Trader Rating: (0)
replace both O2 sensors.
__________________
1997 Acura 3.2TL.
Quote:
Originally Posted by FiftyFive View Post
LMAO = Lick My Anal O
tmnhs81 is offline   Reply With Quote
Old 10-26-2009, 12:35 PM   #3
Yoyon
Registered User
Trader Rating: (0)
Wow they are like $ 200 each. Do u know where I can get them cheap or if they can be fixed?
Old 10-26-2009, 12:41 PM   #4
TexasHonda
Registered User
Trader Rating: (0)
Check ebay for used or new at much lower cost. I have installed both used and aftermarket, and all worked well.
The universal O2 sensors are the lowest cost, but will require splicing the wires from old harness to new sensor wires. Not hard, but does require crimping tool and care to get right wires matched. Most sensors provide guidance to wiring.
I would also suggest checking your wiring harness to make sure you don't have damaged wiring. Unlikely for both to be damaged, but also unlikely for both to fail at same time. You might also check your alternator's output voltage. Excess voltage might burn them out.
good luck
__________________
1997 Acura 2.5 TL
2007 Honda Accord LX/SE
1994 Honda Accord
I don't drive em, just fix em.
TexasHonda is offline   Reply With Quote
Old 10-26-2009, 12:45 PM   #5
tmnhs81
Registered User
tmnhs81's Avatar
Trader Rating: (0)
How about I get you a price quote from my sources tomorrow as I'll be working all day today and won't be back untill midnight..
EDIT: Listen to TexasHonda.. He's the TL tech....great info TH...
__________________
1997 Acura 3.2TL.
Old 10-26-2009, 3:53 PM   #6
Yoyon
Registered User
Trader Rating: (0)
good luck
Thanks for the info, I'll check that out
Old 10-26-2009, 3:54 PM   #7
Yoyon
Registered User
Trader Rating: (0)
Thanks I'll appreciate that, you are in the bay area right?
Old 10-26-2009, 4:06 PM   #8
Yoyon
Registered User
Trader Rating: (0)
good luck
You think this will fit:
http://www.autopartswarehouse.com/sk...%26+Drivetrain
It says front or rear, I saw some wih2 and 4 cables, do u know which one I need?
Thanks
Old 10-26-2009, 7:40 PM   #9
main70072
Registered User
main70072's Avatar
Trader Rating: (0)
Check out http://www.rockauto.com/ or http://www.sparkplugs.com/
If you decide to go with the universal sensors, they are cheaper but require splicing of the wires like others have mentioned above. The OE identical sensors are direct plug in. I would recommend getting NGK or Denso.
main70072 is offline   Reply With Quote
Old 10-26-2009, 8:32 PM   #10
TexasHonda
Registered User
Trader Rating: (0)
Thanks
Yes, it will fit either front or rear.
good luck
__________________
1997 Acura 2.5 TL
1994 Honda Accord
Old 10-27-2009, 1:34 AM   #11
Yoyon
Registered User
Trader Rating: (0)
good luck
Just one Question I am a Noob in this, where are the sensors located?
There is one before and one after the Cat. right?
Old 10-27-2009, 7:58 PM   #12
TexasHonda
Registered User
Trader Rating: (0)
Primary is on the exhaust manifold underneath the battery. Secondary is aft of the catalytic converter. Check autozone for online manual help.
good luck
__________________
1997 Acura 2.5 TL
1994 Honda Accord
Old 11-08-2009, 12:01 PM   #13
utterman
Registered User
Trader Rating: (0)
I just replaced both oxygen sensors for my 98 Acura TL 2.5.
I got my oxygen senors from http://www.oxygensensors.com. I was cheap and got the ones that needed to be spliced. They use crimped connectors and heat shrink around the connections.
Pre-cat sensor
-The sensor is located between the battery heat shield and under the engine at the exhaust manifold
-I had to remove my battery and the heat shield to get to the senor
-Get a Oxygen sensor socket at a place like Autozone. I was able to "rent" the tool by paying ~$25 and getting a full refund when I return the socket set. The socket is required because it as a gap to allow the wires to pass through so you can reach the bolt that goes around the sensor
-I used my breaker bar and was able to loosen the sensor
-The wires to the sensor travel down to be right behind the passenger tire/under the passenger door
-I removed the connector from the old senor and used it on the new one
-Installation is the reverse order
Post-Cat sensor
-The sensor is location around mid-section of the car after the cat
-There is a heat shield around the converter that I wasn't able to remove because the four bolts were rusted. You need to take off the heat shield to get to the sensor.
-I took it to Midas and for ~$34 they took off the heat shield
-Take the sensor off using a breaker bar and the oxygen senor socket
-The wires go up to the interior of the car and connect right under the passenger seat
utterman is offline   Reply With Quote
Tags
1999, 97, accord, acura, cl, codes, fixing, heater, ho2s, honda, location, p0135, p0141, po141, rear, rl, tl
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
