magnetic oil drain plugs - AcuraZine Community
AcuraZine Acura Forums HomeAcura CL ForumsAcura MDX ForumsAcura NSX ForumsAcura RDX ForumsAcura RL ForumsAcura RSX ForumsAcura TL ForumsAcura TSX ForumsAcuraZine Regional DiscussionAcuraZine Off Topic Discussion
Go Back   AcuraZine Community > AcuraZine TL Community > Second Generation TL (1999-2003)
Welcome to Acurazine.com!
Welcome to Acurazine.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Acurazine.com community today!
Old 11-07-2009, 5:08 AM   #1
III.II
Registered User
Trader Rating: (0)
Anyone using an magnetic oil drain plug on here?
Are these useful in any way?
OR
Are they a complete waste of money?
This ad is not displayed to registered or logged-in members.
Register your free account today and become a member on Acurazine!
III.II is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-07-2009, 5:49 AM   #2
I Go To Costco
I Go To Costco's Avatar
Trader Rating: (0)
Of course. It'll keep all the metal shavings, if any from circulating back through your engine. The sump filter usually won't block all of the tiny stuff.
__________________
Quote:
Originally Posted by Gnate View Post
It's so cute when women step out of the kitchen and try new things.
I Go To Costco is offline   Reply With Quote
Old 11-07-2009, 10:04 AM   #3
Rajca
CL-S6 on steroids
Rajca's Avatar
Trader Rating: (3)
oem drain plug. never had a problem.
__________________
02 SSM TL-S:: When ever driver, gots a sound system
03 SMR CL-S6::track car:: way too many parts to list, most of them custom
Rajca is online now   Reply With Quote
Old 11-07-2009, 12:13 PM   #4
01tl4tl
Registered User
Trader Rating: (0)
I got `stick like` magnets at harbor freight- $1 each, and slap 2 on the outside of the oil filter
They are made to be used inside the filter but are too long for the TL
Everything you can do will help- including run a cleaner like seafoam thru the oil before change- the sludge on tv is real~
__________________
Its fine until the tcs lights on and D5 flashing and the car barely will pull. I have to shut it off and it will be fine until it does it again. Is this a problem?
01tl4tl is offline   Reply With Quote
Old 11-07-2009, 6:40 PM   #5
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
Quote:
x2
but now if you had some serious issues with your engine, they might help, but the best thing you can do for your engine is change your oil every 3,000 miles and put in quality oil (valvoline, castrol, etc) with a quality filter (especially one that has a antidrain back valve in it, so it builds pressure faster)
__________________
2003 NBP TL-S, H&R springs, Bilstein shocks, Ingall's rear alignment kit, Eibach rear sway bar, UR crank pulley, P2R intake spacers, Comptech intake, Comptech headers, Apexi exhaust, Alpine dvd radio, Alpine 500w amp, JL W6 12" sub, OEM body kit, tint, Hayden tranny cooler, Goodridge G-force braided brake lines, and MORE TO COME...
friesm2000 is offline   Reply With Quote
Old 11-07-2009, 8:18 PM   #6
Rajca
CL-S6 on steroids
Rajca's Avatar
Trader Rating: (3)
^o man. i feel another thread jacked about oil.
some ppl go to 7500 and some go to 10000. all personal preference. i go no more past 3500 or 3 month. but i drive my cl hard.
__________________
Old 11-07-2009, 8:23 PM   #7
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
__________________
Old 11-07-2009, 8:49 PM   #8
01tl4tl
Registered User
Trader Rating: (0)
for the average driver- the TL is set up to go 7500 between changes, thats why the oil minder is set for 7500,,starting at about 6500 till you reset it
Extreme temps or driving style, lots of short trips.. do merit changing sooner
get an oil analysis done and see what you can be doing for oil life and exactly what metal bits are in the oil- all parts wear and certain amounts are expected- while others indicate trouble in the works
Its my opinion that car makers and oil makers are in colusion and the standard is set at 7500-so oil is made to last 8000 then certain needed additives wear out
Old 11-07-2009, 8:54 PM   #9
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
the average driver should follow the severe maintence scheadle, especially with stop and go traffic (cause they would fit the descripton very well)
__________________
Old 11-07-2009, 11:12 PM   #10
ANC297
Registered User
ANC297's Avatar
Trader Rating: (0)
I too throw a 2 3/4 inch by 3/4 inch magnet onto the side of the filter...They are a few cents at radioshack, so I guess it can't hurt. I check every once in a while, if it falls off which has yet to happen, I will put another one on.
__________________
2002 WDP Tl-S.
NiteShop knows NO LIMIT
" Successes have many fathers, failures have none.”
ANC297 is offline   Reply With Quote
Old 11-08-2009, 2:14 PM   #11
nhn23
I live in
nhn23's Avatar
Trader Rating: (0)
where would the metal shavings come from in the first place?
nhn23 is offline   Reply With Quote
Old 11-08-2009, 3:47 PM   #12
Rajca
CL-S6 on steroids
Rajca's Avatar
Trader Rating: (3)
wear and tear, dry starts.
__________________
Old 11-08-2009, 9:35 PM   #13
fsttyms1
Mega Moderator
2000 Acura TL
fsttyms1's Avatar
Trader Rating: (0)
Quote:
Oh please. 3k is way to often and a waste of money. My car would idle all day with tons of fast stop and go. If that wasnt severe i dont know what was. i went 8k on average (with regular oil) and the oil life was fine (had oil tested)
fsttyms1 is offline   Reply With Quote
Old 11-08-2009, 9:53 PM   #14
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
Quote:
then why did my engine not have the brown tint (looked brand new with oil just on it) on the front bank when i just adjusted the valves at 104k (pictures through oil fill); back had some brown tint due to running hotter being at the back of the engine compartment
btw : that was the first time the valve covers have been off since new/built over 6 years ago and i am not taking them off again just for pictures
__________________
Old 11-09-2009, 3:49 AM   #15
tmnhs81
Registered User
tmnhs81's Avatar
Trader Rating: (0)
YOu can also add a little bit of any ATF every other oil change OR a few (hundred) miles before oil change. Its a great degreaser and lubricant.
__________________
1997 Acura 3.2TL.
Quote:
Originally Posted by FiftyFive View Post
LMAO = Lick My Anal O
tmnhs81 is offline   Reply With Quote
Old 11-09-2009, 12:56 PM   #16
probmxstyle
Registered User
probmxstyle's Avatar
Trader Rating: (0)
Mine look the same with 110K miles and 7500K oil changes. Honda says 7500k, what is your reason for not trusting them on that? Have you run your oil to 7500k and have issues?
__________________
H/U: Pioneer Z1
Front stage: Polk SR6500
Front stage amp: Kicker SX500.2
Acc: Kicker SXRC network controller
Subs: MTX 9512-44
Sub Amp:MTX TE1501D
Battery: Optima yellow top
Sound Dampening: Dynamat extreme
probmxstyle is offline   Reply With Quote
Old 11-09-2009, 1:05 PM   #17
CJITTY
Jeri Curl Drippin In My
2003 Acura TL TYPE-S
CJITTY's Avatar
Trader Rating: (0)
been doing 10K oil changes with Mobil 1 and K&N Filter..oem plug, no issues. Started using Castrol Full Syn just for the helluvit, still no issues
__________________
2003 Acura TL Type S - NAVI WDP / OEM Body Kit / OEM Honda 19x8 HFP Wheels (55 Offset) / 235/35/19 General Exclaim UHP Tires / EBC Ultimaxx Dashed Rotors / Akebono ProACT Brake Pads / H&R Sport Springs part #50103 / CTE Icebox / UR SC Crank Pulley / Ingalls Rear Camber Kit #38720 / HID Front and Rear Fog Lights / 15% Door 5% Rear Tint / De-Badged / Trunk Lip Spoiler
CJITTY is offline   Reply With Quote
Old 11-09-2009, 1:54 PM   #18
Neejay
Registered User
Neejay's Avatar
Trader Rating: (1)
Might have to try the magnet trick. I just did an oil change yesterday, and was also curious about a magnetic drain plug.
I use 5w-30 Mobil 1 Syn + NAPA Gold (Wix) filter.
__________________
- 2003 TL-S - WDP w/ Black interior | Tokico HP/H&R Sport | CAI/AEM Dryflow filter | 3000k HID Fogs | Mid-muffler delete| Option Underdrive pulley | Comptech Rear sway bar/ES poly D-bushings | Rotora slotted rotors/pads (front)
- 1991 Nissan 240sx, RB25DET Series-II - stuff
Neejay is offline   Reply With Quote
Old 11-09-2009, 3:16 PM   #19
hANDYcaptd
I drive slow in my
2002 Acura TL Type-S
hANDYcaptd's Avatar
Trader Rating: (4)
OEM plug here. No issues.
hANDYcaptd is online now   Reply With Quote
Old 11-09-2009, 5:03 PM   #20
nhn23
I live in
nhn23's Avatar
Trader Rating: (0)
why are people using 5.30 when our cars call for 5.20? well atleast mine calls for that (2002)
Old 11-09-2009, 5:11 PM   #21
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
Quote:
because 5W-30 offers better protection
and the biggest reason why honda specced 5W-20 was to squeeze out that last bit of mileage (and less emissions) when they did the EPA testing and fuel economy testing
__________________
Old 11-10-2009, 3:50 AM   #22
01tl4tl
Registered User
Trader Rating: (0)
in reality- the engine oil has a nice big filter thats replaced every time, so it should be catching all the metal particles
the trans uses a magnetic plug because it doesnt have the same type filter system, so a magnet holds whatever comes past it instead
__________________
Old 11-10-2009, 5:02 AM   #23
. N B P .
Nighthawk Black Pearl
. N B P .'s Avatar
Trader Rating: (0)
^ is this what you guys do?
My oil change is coming up and was looking into this oil filter magnets.
__________________
2002 TL-P NBP
. N B P . is offline   Reply With Quote
Old 11-10-2009, 8:28 AM   #24
hANDYcaptd
I drive slow in my
hANDYcaptd's Avatar
Trader Rating: (4)
^ Some put it on the inside, some put it on the outside.
Old 11-10-2009, 10:29 AM   #25
01tl4tl
Registered User
Trader Rating: (0)
on the old chevy truck filter it fits inside like the pic, so thats where I ran it with no issues
The TL filter is shorter than the magnet and wont fit inside fully without snapping in half--which is easy to do but leaves a rough edge--does breaking it affect the magnet?- I dont know-
So they now go on the outside of the filter at full length
No problem with falling off- also use them on the bike (which happens to use a TL filter)
and gets a lot more road debris damage potential and bumps trying to throw it off
In theory they should be working thru the can- at least we can feel that we are going the extra step
Just like you dont need synthetic oil but it makes you feel better
Old 11-10-2009, 10:59 AM   #26
friesm2000
Registered User
2003 Acura TL
Trader Rating: (1)
i would say thru-can one's are proably not as effective, because they have a greater distace to attract metal particles, and will attract to the filter itself housing first, but if it is has sufficent strength it should still attract metal particles
but the funny thing is there are alot non-ferrios (exp. aluminuim ) metals in engines now a days, so maybe not as effective now, then back in the day, (crankshaft, rods, oil pump, cams, rockers ,springs, etc., etc. are still ferrious though), so a quality filter is still a must
__________________
Old 11-10-2009, 7:22 PM   #27
'02_TL-S
Rollin' in a
2002 Acura TL
'02_TL-S's Avatar
Trader Rating: (0)
Hmm..I'm liking this magnet idea for the tranny filter. Help that little plug magnet out some cuz I can't imagine such a small magnetic area is catching everything. Thanks for the idea guys!!
'02_TL-S is offline   Reply With Quote
Old 11-11-2009, 10:41 AM   #28
AMGala
Smiley Storyteller
2003 Acura TL
AMGala's Avatar
Trader Rating: (2)
What if you put some of those magnets on the bottom of the oil pan?
__________________
2003 TL-P in WDP: Supercomputers Pedals & Door Sills | Comptech Headers & Cat-Back Exhaust | RT Cat | Kaixen 6000K HID Lows & Fogs | OEM Kit w/ WW Spoiler | Neuspeed Strut Bar | Eibach Springs on Tokico HPs | Rotora Slotted Rotors & Ceramic Pads | 225/50/17 Goodyear ResponsEdges on CL-S Rims | 10mm Kics Project Spacers | 3G 6MT 20mm RSB | UR UD Pulley | Comptech SS Brakelines | More...
AMGala is online now   Reply With Quote
Old 11-11-2009, 1:09 PM   #29
01tl4tl
Registered User
Trader Rating: (0)
yes you can do that too, but you want the stuff to drain out so remove it before oil change
A filter of any decent quality- meaning more than a roll of toilet paper in a can-
is catching the particles--or acura would use a magnetic drain plug
There is still wear on parts that will be attracted to a magnet- and if its captured in the can to its inner edge- thats cool by me
My concern on using a broken-to-fit magnet was adding micro particles from its rough edge into the system- creating a problem where none existed
Old 11-11-2009, 2:15 PM   #30
hANDYcaptd
I drive slow in my
hANDYcaptd's Avatar
Trader Rating: (4)
And I would slide the magnets to the drain plug, then removing them. That way you'll get the particles closer to the drain to be flushed out.
Tags
1999, acura, acurazine, drain, generation, mid, oil, plug, reset, tl
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Acurazine.com content, comments, or advertising. Acurazine.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Acurazine.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
