DIY: door handle LEDs
Old 10-10-2010, 10:27 PM
  #161
Hello Officer
It's Clutch's Avatar
I had the same issue after messing up my dome light, so you can just run a switch to whatever you tapped into. Thats if you want to control them, but to each his own.
Old 12-26-2011, 11:55 PM
  #162
UA5TL's Avatar
looks really good, props!
Old 12-27-2011, 01:19 AM
  #163
whoknows's Avatar
the write up was right on!! i followed it 100% and not one issue!! I also added trunk lights. 5 total and mine never popped any fuses. I tapped all lights to the wires mentioned in the write up for dome light connection.
I drilled a little hole inside each handle to mount the led into, its very easy and accessible from inside the door or outside. Just start small and work your way up until the led barley can squeeze thru the hole...
[IMG]http://i59.photobucket.com/albums/g318/serealve/fd25a29c.jpg[/IMG
sorry big pics...
Old 01-14-2012, 04:36 AM
  #164
aznccnsh's Avatar
Question. This wiring instructions could also work for installing puddle lights right? Like the on and dime off as you use your key fob since its connected to the dome light.
Old 01-14-2012, 07:52 PM
  #165
floored4door's Avatar
I did mine on the back side.... also further up so you cant see them as well. I wanted them to illuminate the inside of the handle. Mine turn on/off when the car is in Or out of park. People Jock the shit out of them.
Old 01-15-2012, 11:38 PM
  #166
whoknows's Avatar
yes to the puddle lights. I wired 5 led's to the roof of the trunk following the navi wiriing. it lights it up very nicely, and you cant see the led's there pretty concealed.
I had no issues with fuses popping, if peoples fuses are popping they are prolly grounding out the wire somewhere durring the install. I added a total of 9 off the factory circuts and fuses. So you shouldnt have any issues with the puddle lights... where would you plan on mounting/securing the puddle lights?
Old 02-14-2012, 01:14 AM
  #167
ibs
ibs's Avatar
Do you think once i complete this project that I can make it flash whenever I unlock and lock my car? Because that would be sick. and those are just normal led lights right? like the ones you would put as a headlight?
Old 02-14-2012, 06:17 PM
  #168
ibs
ibs's Avatar
nevermind just finished reading through all the pages. but what i was really thinking, what happens if you want to go get your car detailed... you don't think that washing the car or somebody with dirty hands mess it up?
Old 02-16-2012, 08:40 PM
  #169
Gabru678's Avatar
You probably could seal around the LED with some silicon type thing. protecting it from whatever may go through the hole and water/dirt-proofing it.
Old 07-21-2012, 02:39 AM
  #170
speedemon90's Avatar
Originally Posted by 1134
After rereading the instructions for the tenth time, I can only conclude that the DIY lists 2 different ways to wire these lights. Either by tapping into the door lights (first method shown), or tapping directly into the dome light (second method shown), can anyone confirm this for me? I don't want to end up tapping into more wires than I have too.
this is what i keep thinking too? Can anyone confirm, i may be interested in doing this.
Old 08-14-2012, 06:20 PM
  #171
BIGmeech's Avatar
Great write up hope i can find the time to do this sometime soon
Old 08-27-2012, 02:02 PM
  #172
WW-GSR's Avatar
Cool looking mod for sure! After reading through all the pages, I didn't see anyone pose this question though: since the LED's are tapped into the dome light, if you turn your dome light on for example while driving, does that make the door handle LED's light up as well?
Old 08-27-2012, 03:21 PM
  #173
AznWay's Avatar
NO, The LED light will not turn ON without the door being open. By setting it with dome light to ON position the LED does few cool trick.
1. Locked an Unlocked door with keyless remote will turn ON/OFF LED
2. The LED do cool fade turn off after you shut the door.
3. Always cool have door not complete shut to show off light at night ( car shows)
WW-GSR (08-27-2012)
Old 04-13-2013, 01:18 AM
  #174
Carson-TL's Avatar
I spent all day today doing this DIY
Along the way I blew the courtesy light fuse on accident a couple times.
Problems:
there is no response to unlock, lock, or the trunk button on my remote.
Engine turns and sounds healthy like always but does not catch (sometimes after like a minuet it may catch but requires me to give it gas but then it shuts off again. then my garage is left with the smell of gas.)
Maintenance light is on.
Checked all fuses but I didn't see anything unusual, I'll check again tomorrow though. What fuses should I check?
Can't be the battery, I threw in a new battery and nothing changed.
Any recommendations? Don't tell me to search, I already did and every time I try it gives me worthless shit like "what oil should I use" or "why is everyone hating the RLX?
Please help me. Too tired to explain details.
Old 04-15-2013, 09:26 PM
  #175
Carson-TL's Avatar
Just a heads up guys. Don't touch the wires you tapped into on the driver side door to the metal frame next to all the fuses. My ECU is fried, the injectors are shorted out and stuck open, and the fuel pump is stuck feeding FAR too much gas. My engine wouldn't turn over because There was so much gas in it that the pistons couldn't even move.
New ECU = $1300 + labor......I just want to stick my head in a bear's mouth right now.
Old 04-16-2013, 11:39 AM
  #176
NBP
Skeete32's Avatar
carson tl you should have read my post I warned you guys about that..
Old 04-16-2013, 11:42 AM
  #177
NBP
Skeete32's Avatar
To be safe just run wires from dome light to the door handles , requires lots of wire but safer mine work beautifully, only did front doors made more sence that way pics will be up soon have been very busy ..
Old 04-16-2013, 09:45 PM
  #178
Tri State ViP Crew
CAB NY's Avatar
i had the LEDS for a long time and every summer i plan on doing it so whats the post you are referring to and can you wire the back too also if you turn on you dome light do they light with the door closed
Old 04-17-2013, 08:53 AM
  #179
NBP
Skeete32's Avatar
Just look up my name. Yes you can wire the back and anywhere else you can think of. Yes the should light up because its connected to it. So if you drive with your dome light on at night it will also be on. I bought waterproof leds of ebay cut them only need 3 leds and it turned out great, fore light and I put them up high so that you can only see the glow not the led it self. I will post pics after 10 days on my weekend off work.
Old 04-29-2013, 04:48 PM
  #180
NBP
Skeete32's Avatar
Old 04-29-2013, 05:01 PM
  #181
NBP
Skeete32's Avatar
Old 04-29-2013, 05:13 PM
  #182
NBP
Skeete32's Avatar
This is better I believe more light water proof cut to any size of three
Old 05-26-2014, 01:11 PM
  #183
MrMoAcuraPar's Avatar
Thread Revival! !! Is it possible to do this by simply powering the leds off the dome wires running down the pillar?? Why hook it up twice when all you need is to the dome light, as I would think it would do the fade in & out simply by being powered by the circuit that does it... any ideas???
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
blacktsxwagon
10-27-2015 10:12 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: DIY: door handle LEDs
