Transmission fluid question
finally got my TL shipped here to me in San Diego! I dont know when the transmission fluid was last serviced.....is thisd something i should just do or if its clean leave it alone? im at about 90k
If you have no knowledge about how the transmission was maintained I would recommend changing it just to be safe. I will be doing my second drain and fill tomorrow with redline D4 assuming your car is auto.
Welcome to San Diego. The normal change interval is 60k miles so perhaps it was changed then or never. I would change the ATF if I were you. The tip about changing the pressure sensors is good since you'll already be doing the fluid. It's easier to pull the driver's wheel to get to the sensors.
mada51589
05-03-2022 08:54 PM
Mike Bertram
09-10-2015 09:27 AM
