G-031: [DIY] Accord Fogs with Type-S Grills on '04-'06 TL
Old 12-07-2011, 06:55 AM
  #161
rockstar143's Avatar
^^^AGREED...in rereading the thread, I don't even remember how I ended up fixing my problem. But I did!
Old 12-07-2011, 08:08 AM
  #162
Watermelon913's Avatar
Thanks Guitarplayer16 and Rockstar143, It took me a while to get the aimming right because at first I mounted the driver side too high, now its too low. Im gonna fix that lol
Guitarplayer16
- I noticed how your fog lights was flushed on the outer edge. For myself I put the outer behind the bumper to give it a cleaner look, then pushed the inner side in. Although, when doing that your grill won't look right so you have to dremel at an angle to make it look flush. I remember reading a post about aiming them so it wouldn't blind any on coming drivers, that was my number one goal, so I wouldn't get flashed at =P
Again thank you for all of your help
Old 12-07-2011, 08:09 AM
  #163
well kudos cause you did an amazing job.
Watermelon913 (12-08-2011)
Old 12-08-2011, 02:54 PM
  #164
Hey guys, I went on like a 10minute trip with the fogs on and I noticed that they were really really hot. It's going to snow later on tonight and I'm worried that since it's soo hot that if snow got on the lenses, it might crack the lenses.
Has anyone encountered a problem with the glass lenses?
Old 12-08-2011, 05:35 PM
  #165
guitarplayer16's Avatar
You bought OEM fogs right?
And what bulbs did you put in them?
The fogs DO get really hot lol
It's nothing to worry about.
It's not your bulbs either because I had the stock bulbs that came with it in for like a few months and it was hot back then too.
Old 12-08-2011, 05:45 PM
  #166
My HIDS get hot as FK too!
OH...and if I could turn back time I'd HIGHLY recommend buying some clear overlay putting it on the OEM glass STAT! I did it...but only after a rock (or two) cracked my passenger side glass.
Old 12-08-2011, 10:29 PM
  #167
Yes, I have OEM glass lenses.
I have 2500k nokya running at 55w, I was going to re-align the driver side with the passenger so it's level, and touched it and burned my index finger a little.
Btw the isnt the overlay just a thin layer?
Old 12-08-2011, 10:33 PM
  #168
Nokya Yellows 55watt are what I run too!
You won't run into any problems with the heat.
Just wait for it to cool before handling.
Old 12-08-2011, 10:49 PM
  #169
2500K FTW... lol
I can understand why they are really hot, Im worry about the winter cold and what if cold water splashes on it, cracking the lenses.
Old 12-09-2011, 07:34 AM
  #170
The overlay is a thin layer, but it'll keep the glass from cracking when rock fly at them at 100MPH or more.
I like the yellow fog look, but since the fogs don't shoot PERFECTLY, I got matching HID's so they blend in with the factor lows better. Actually, I have a DRL module with yellow nokyas in my oem fogs (in the headlight housing).
Old 12-09-2011, 08:06 AM
  #171
Okay thanks, Ima invest in some overlays then lol
My 6500k Kaixen low beams actually wash out the nokya's, except for the sides
btw what drl module are you using? I want drl! lol
Old 12-09-2011, 10:09 PM
  #172
Post some day shots, I wanna see the fitment =)
Old 12-10-2011, 08:48 PM
  #173
TLZUM's Avatar
Thanks to this DIY guide I just finish wiring my fogs.
Which BULBS do you guys recommend to match the low beam hid? I know Nokya has different types of whites but I dont know which one to get? I would run yellow nokyas but I already have them on the inner fogs.
Thanks again Guitarplayer16 and to those who contribute.
Old 12-10-2011, 09:23 PM
  #174
No problem!
Please, post up some pictures!
To truely match the low beams, you'd have to get HIDs.
If you're looking at bulbs, give H11 Nokya Arctic White bulbs a try!
Old 12-11-2011, 10:25 PM
  #175
Dannieboi07's Avatar
help plz
I just wanna know what year accord foglights those r and where did u get those grills from? thank u in advance for your response
Old 12-11-2011, 10:35 PM
  #176
They are 03-05 Accord Sedan Foglights.
Buy it from this guy:
http://www.ebay.com/itm/ws/eBayISAPI...#ht_500wt_1180
$40 for OEM. Better than $300 from Honda.
I got my Type-S grills from oemacuraparts.com
Old 12-11-2011, 10:40 PM
  #177
CesarRod's Avatar
Is there a DIY in removing the front bumper on a 08 type s? All i can find is base models.
Old 12-11-2011, 10:48 PM
  #178
Lucky for you, it's the same process IIRC =)
Just don't forget to unplug the fog light connectors before running off with the bumper.
Old 12-11-2011, 10:52 PM
  #179
CesarRod's Avatar
So the video you posted about taking off the bumper is 100% correct? I thought the type s had more nuts/screws
Old 12-11-2011, 10:57 PM
  #180
Yup it's 100% correct.
That's why all 3G bumpers are interchangeable.
The dude even states that it's the same except you have to disconnect the fog lights (which I told you before) lol
Old 12-11-2011, 11:16 PM
  #181
great info
can you send me a direct link or something to the grilles? What year type s is it?
MESH, FR. BUMPER GRILLE *NH533* (BUMPER DARK GRAY) < is it this one?
Old 12-11-2011, 11:18 PM
  #182
there are no pics of the grilles on this website so i dont know what to get ...
Old 12-11-2011, 11:19 PM
  #183
N i didnt notice any lower grilles being included with that other grille
Old 12-11-2011, 11:21 PM
  #184
Doesn't matter what year Type-S; 07 or 08.
For the lower grills:
https://www.oemacuraparts.com/index....ponent=BUMPERS
You'll need:
#49 (Passenger lower grill), #53 (Passenger lower chrome grill bar), #51 (Driver lower grill), #54 (Driver lower chrome grill bar)
For the front center grill: (looks like you found it okay)
https://www.oemacuraparts.com/index....FRONT%20GRILLE
#11.
Add those 5 parts into your cart and you're on your way to having a badass TL.
Cheers!
Old 12-11-2011, 11:46 PM
  #185
Thank you very much
Cheers!!!!
You'll need:
#11.
Cheers!
Old 12-13-2011, 10:17 AM
  #186
Wow I bought from that guy on Ebay for $49 shipped and when I bought it, it only said he had 3 left.
LOL this guy has connections!
Old 12-13-2011, 02:09 PM
  #187
VicTL06's Avatar
I wish I had the skills/confidence to pull off this mod. Guitarplayer, I'm almost tempted to jump on the Trans Canada and beg you to do it...although I'd feel guilty putting those kind of kms on the car!
Mind you, if anyone from BC to Mexico was willing to do it (and has done it on their own TL), I'd be willing to drive down and pay for it.
Old 12-13-2011, 02:21 PM
  #188
mY sLOW UA6's Avatar
Nice job for sure, but you won't see me doing that any time soon.
Old 12-13-2011, 02:47 PM
  #189
Yeah haha he seems to get lots of them.
I feel like buying a few sets off him just to do local's TLs and have a backup set.
Haha VicTL06,
It was my first time ever using a dremel, AND taking off the front bumper LOL
If you ever decide to do it yourself, I can help you out via IM.
Haha - it's honestly an easy process.
It just takes a lot of time.
1. Cut behind bumper
2. Cut fog light housing to shape
3. Mount it.
4. Wire it.
Old 12-13-2011, 09:58 PM
  #190
CometVR4's Avatar
I followed this install and it worked. I get to the wiring and I have trouble.
Fogs won't turn on
-I tapped into my parking light using the blue wire off the switch
-I extended the green wire through the firewall and once in the engine bay I was able to connect it to the other green wire off the thin brown clip with only 2 wires leading to it.
-I Used the other brown connection and plugged in to the BLACK relay.
-I plugged in the fog lights to the connectors and cut of ring terminal off.
-I took that ring terminal and connected it to the negative on the battery and used the other side to into the inline fuse.
-Last I connected the blue/red wire into other side of the inline fuse.
When I turn on the parking lights, I get a green indicator that tells me they should be on, but they are not.
Where did I go wrong?
Old 12-13-2011, 10:17 PM
  #191
Fogs won't turn on
Looks like you have your signal wires and everything is good from inside the cabin.
It's definitely your powering and grounding that's messed up in the engine bay.
You're supposed to take the ring terminal you cut off, and extend it using like 2 feet of wire. So essentially you're just extending that ring terminal which goes to the ground bolt, not negative on the battery lol.
Then you're supposed to buy another ring terminal and attach it to the inline fuse. The red/blue wire to inline fuse is good.
Old 12-14-2011, 06:23 AM
  #192
CometVR4's Avatar
Ok, just to make sure I'm following you correctly, that ring terminal I cut off just extend with a longer wire to a ground bolt to the body of the car? And I'm supposed to purchase another ring terminal to go on the other side of the inline fuse? But where does that ring terminal suppose to go? Thanks for your quick reply!
Old 12-14-2011, 03:10 PM
  #193
You got it!
The ring terminal that goes to the other end of the inline fuse goes to the power.
So you can hook the ring into the positive terminal on your battery, or you can hook the ring on the bolt in the fuse box like I did (refer to picture to see which bolt to hook to).
CometVR4 (12-14-2011)
Old 12-14-2011, 09:54 PM
  #194
CometVR4's Avatar
Did what you said. Extended the wire with butt connectors and ring terminal to body of car and other one to that screw in fuse box. Fog lights are working! I am so happy to accomplish this. Couldn't have done without your help. Ive been wanting to do this mod for years and Your review made it easy for me to understand because I have no wiring experience at all.
My only gripe is I thought I mounted them straight but the fogs point way outwards. But
Old 12-14-2011, 10:10 PM
  #195
Glad everything worked out okay!
The wiring is actually really simple eh?
Post some pictures of your install =)
The light does point outward on most peoples install because of how our bumper curves.
Old 12-15-2011, 04:16 PM
  #196
CometVR4's Avatar
Yeah the wiring was not as hard I was thinking once you sit down and break down what needs to be done.
After looking at your photos again. I realized mine are not quite as flush as yours. My beams point out like cornering lights. I'll just position them once I get my A-spec. The stock bulbs that are in there are weak anyway.
Old 12-15-2011, 10:46 PM
  #197
Yeah definitely fix it after the lip kit.
I found my stock bulbs to be pretty bright LOL
Maybe that's because they shined 5 feet off the ground and blinded people lol
Old 02-08-2012, 08:56 PM
  #198
Fiction725's Avatar
Glad I found this post, just ordered everything can't wait to get some fog's on her. Thank you for the wonderfully detailed walk-through!
Old 02-08-2012, 08:57 PM
  #199
No problem buddy!
Welcome to Acurazine!
Old 02-08-2012, 10:01 PM
  #200
2004 Acura TL
navarretg's Avatar
Well tomorrow I'm going to tackle the fog lights. I've read over 15 Pages worth of information so I will have something to refer to. Hopefully all goes smoothly!
Quick Reply: G-031: [DIY] Accord Fogs with Type-S Grills on '04-'06 TL
