G-031: [DIY] Accord Fogs with Type-S Grills on '04-'06 TL
Old 02-29-2012, 10:54 PM
  #241
04TL4P3's Avatar
Already did haha
Old 02-29-2012, 10:55 PM
  #242
guitarplayer16's Avatar
Sweet...
If you figure it out please show me how you wired your whole switch harness and I'll post it up in the DIY, with credit to you of course.
Old 03-01-2012, 04:10 AM
  #243
Chapter Leader (Houston)
TLDude876's Avatar
+1 my fogs are arriving today
Old 03-01-2012, 12:21 PM
  #244
04TL4P3's Avatar
Will do, i just ordered my hid kit for the fogs today so Ill be testing for ignition power in the fuse box to tap into and ill see if i can figure out this plug situation too...
Old 03-01-2012, 01:01 PM
  #245
Good luck to the both of ya!
Old 03-01-2012, 01:55 PM
  #246
04TL4P3's Avatar
I think i got it! My harness has a small plug with a single red wire on it and i beleive this is the ground for illumination. Im wiring it now and will post pics when its done and tested
Old 03-01-2012, 05:32 PM
  #247
04TL4P3's Avatar
Success! Got everything working and cleaned up all of the extra wiring under the hood. I found a few slots in the fuse box that are open and have power with ignition on but dont know why on some slots the power comes from the top pin and others the bottom pin? Anyone? Anyways I think Im just going to use an add a fuse and use the spot for the front 12v outlet as a trigger when I get the hid's... heres the pics!
red plug on the harness which needs to be grounded to illuminate. I was going to cut off the plug and extend the wire to ground but I cut it near the switch and grounded it to the same point as the other ground.
fog switch final wiring
Here are the pics from the wire cleanup...basically all you are doing is getting rid of the plug that goes to the extra relay that we dont use along with the other unused brown plug. The only thing I had to connect to make it work was the two black ground wires coming from the foglights that went to the extra plug (the blue one).
original wiring before cleanup
ground from fog lights connected
blue plug removed (i didnt get a pic of the brown plug but its the one that has two wires going to it.
Final wiring after cleanup
Old 03-01-2012, 06:09 PM
  #248
Looks good buddy!
So what did you end up doing in the cabin?
Just plugging in the blue connector into the empty slot on the fuse box?
And you tapped into the parking lights right?
Old 03-01-2012, 08:07 PM
  #249
04TL4P3's Avatar
Looks good buddy!
Heres the break down for the inside wiring...
from plug that plugs into the fog switch:
1. Green wire extended to engine bay relay
2. Blue wire tapped into parking light wire
3. Solid red wire grounded for illumination
4. Black wire grounded (already has a terminal on the end)
Plug in the blue connector into the accessory slot above the fuse panel and ur done!
*just a note, the red/black wire gets the illumination power when you plug in the blue plug*
Old 03-01-2012, 08:16 PM
  #250
WOW super easy.
Thanks a million dude!
So basically it's the same setup as mine except:
1. You just plug in the blue connector into the fuse box.
2. Instead of tapping the positive and negative wire for the switch illumination, you just ground the solid red wire to a nearby grounding point.
Am I correct?
Everything else would be the same; blue wire to parking light for trigger, green wire to engine bay, black wire to ground point.
So all it does is saves you from tapping wires to the VSA for switch illumination. Genius!
I'll update the DIY when I can! =)
I'm wondering if the switch illumination works if you tap into say the wiper motor wire (independant; constant ON if the key is in).
Would that mean the switch would illuminate if the key was in the ignition?
Old 03-01-2012, 08:49 PM
  #251
04TL4P3's Avatar
WOW super easy.
Am I correct? Yes Sir!
Would that mean the switch would illuminate if the key was in the ignition? Yep in theory, but I havent tried it. The red/black wire only has power when the parking lights or headlights are on.
Old 03-01-2012, 09:01 PM
  #252
Originally Posted by 04TL4P3
Thanks dude!
So I guess this method is only good if you're using the parking lights as the trigger.
Otherwise, for people with independant fog lights, their button will be lit ALL THE TIME when the key is in the ignition, which would look a little funny lol
I'll be sure to mention it!
I guess people who wired their fogs to be independant will still have to tap into the VSA as a trigger for the switch illumination heheh
Old 03-01-2012, 09:06 PM
  #253
TLDude876's Avatar
So I can use both wires from #4 to go to engine bay right? (BLUE to go to motor wire) Instead of tapping from right where the harness goes into switch.
Old 03-01-2012, 09:22 PM
  #254
You're installing HIDs right?
I would AVOID using the parking lights as a trigger.
Use the low beam fuse or make your fogs independant and use the wiper motor wire.
Everything else is correct!
EDIT: Just read your last sentence about using the blue wire that's beside the green wire and YES that's correct!
So 100% you were correct and know what you're doing!
My bad.
Cut that damn connector off the green and blue wire (the connector at the top of the pic), and connect them to new white wires (or whatever colour of wires you bought) and run them through the engine bay.
Old 03-01-2012, 09:31 PM
  #255
TLDude876's Avatar
My bad.
Exactly what I was thinking.
Old 03-01-2012, 09:39 PM
  #256
You gonna try to install it tonight?
Old 03-01-2012, 09:44 PM
  #257
TLDude876's Avatar
Tempted but no light Remember I have my non oem fogs installed so all I have to do is the wiring. For the ground for fog connectors where you extended the wires, is that necessary? Cant I just find a near ground point?
Old 03-01-2012, 10:04 PM
  #258
04TL4P3's Avatar
Thanks dude!
no I misunderstood when you said that about tapping into the wiper motor wire i thought u meant for the illumination. Tapping into the wiper motor or any other ignition power source as a trigger will not have any effect on the illumination of the switch so u can tap whatever you want for the relay trigger.
Old 03-01-2012, 10:07 PM
  #259
Yeah, you can find any ground point.
I didn't know where to ground it and was like screw it I'm just gonna ground it where the battery gets grounded LOL
I'm positive you can just ground it to a good point on the body.
I think you can knock the wiring off in an hour or two.
The hardest part is fishing the wire(s) through the firewall LOL
Old 03-01-2012, 10:10 PM
  #260
Wait so what you're saying is that accessory fuse will turn on the switch illumination, even though you tap into the wiper motor wire for a trigger?
How would that work, though?
Unless that accessory fuse is somehow wired to the parking lights, I don't get how it would tell the switch to turn on the switch illumination when the fogs are triggered to the wiper motor wire
Old 03-01-2012, 10:13 PM
  #261
04TL4P3's Avatar
Im not sure the wires from #4 are the same as the ones going to the switch plug but if they are then you should be good. The blue wire from #5 is the wire you want to extend to your wiper motor in your case since you want your fogs to be independent from the parking lights.
#1 is the illumination power that you plug in the port in the fuse panel and #6 is the solid red wire from the switch plug that you ground for illumination.
Old 03-01-2012, 10:18 PM
  #262
We'll find out how the switch illumination works out for people with independant fogs soon heheh
Old 03-01-2012, 10:19 PM
  #263
04TL4P3's Avatar
you are correct sir, the accessory port has 5 or 6 pins and one of them (the one that the red/black wire connects to) only has power when the lights are on so the power for the illumination is completely seperate from the trigger regardless of what you use as a trigger.
Old 03-01-2012, 10:27 PM
  #264
So that means that the switch illumination will come on even in the daylight LOL
Old 03-01-2012, 10:38 PM
  #265
04TL4P3's Avatar
yep if your lights are on it will illuminate along with everything else in the car that illuminates lol
Old 03-01-2012, 10:42 PM
  #266
Independant = no lights have to be on for your fogs to be on therefore the only thing lit up in your car is the fog switch LOL (assuming parking lights and low beam are set to off, but fogs turned on)
I can imagine most people turning on their fogs at night anywho, though lol
Great DIY none-the-less, but tapping into the VSA wires for switch illumination is the most OEM method if you have independant fogs lol
Old 03-01-2012, 10:52 PM
  #267
04TL4P3's Avatar
ok we are getting our terms mixed up lol
when i say illumination i mean the white light that lights up the little fog light emblem jut like the vsa button has the white vsa letters that light up. if you have wired like i did then your fog switch will illuminate exactly as the oem things in the car do when your parking lights or headlights are on. Its independent from the foglight power whether they are triggered to the parking light, wiper motor, or any other trigger source.
Old 03-01-2012, 10:58 PM
  #268
When I mean independant fogs I mean that when you stick your key in the ignition and turn your car on, you can turn on and off the fogs just by using the switch, and it does not rely on your parking lights being on or your headlights being on lol
So many confusing terms LOL
So say you cut your blue wire. It's not connected to anything. No trigger. It's not connected to your parking lights anymore.
You flick on your parking lights or low beams, and all the buttons in your car light up. Your fog switch emblem illumination is supposed to light up too?
That's what I don't get unless there's something inside the accessory fuse slot that is hooked up to the parking lights itself
Old 03-01-2012, 11:07 PM
  #269
04TL4P3's Avatar
There is! Lol thats what i explained here^^^
I know what u meant by independent fogs cuz thats what i did with my oem fogs in the headlight by wiring them to the wiper motor.
Old 03-01-2012, 11:17 PM
  #270
Ugh my eyes are failing me.
Face palm to self.
Cheers for the DIY!
Old 03-02-2012, 12:19 PM
  #271
NSXCessive's Avatar
Weird.
If you wired your switch harness as explained through my DIY, all you need to do to illuminate the switch is to tap some wires to the VSA switch.
https://acurazine.com/forums/showpos...2&postcount=80
OR follow NSXCessive's switch harness wiring guide.
Read over it carefully, as I have not tried wiring mine this way LOL
https://acurazine.com/forums/showpos...&postcount=123
Hi, sorry I do not visit Zine that often... Do you mean you have no illumination, or no green light indicating switch is in on position?
For illumination you have to ground 2 wires in the accord switch. Some have tapped the VSA wires, honestly I would no tap and wires with those crappy 3m temporary tap connectors unless you plan on having problems down the road with bad connections etc.
Post#118 I explained the connections to made with out interfering with VSA or any other 'hacking' of OEM wiring.
"....Interior hooked up to switch is: RED/BLK (Parking light trigger used for aftermarket alarms etc) goes to 6-Pin accessory harness which I mentioned above to illuminate it. BLU on trigger I connected to the BLK/YELLOW. Since my car has a Viper autostart /alarm so we grabbed ignition trigger from there you can grab wherever you want. Some people grabbed power from the wipers or other accessories. It’s a small turn on current anyway so should have any problems using that to trigger the supplied Black relay from the Accord kit. RED + BLK were taken to ground, and green is the trigger going out to the accord relay in the engine bay. I ran a new wire into the engine bay thru the rubber grommet near the brake reservoir that connects to the GRN at the relay...."
PM NSXCessive?
Done! lol
Old 03-02-2012, 12:41 PM
  #272
TLDude876's Avatar
Just got done! Thanks for all the help guys! I did not extend the ground wires on the fog harness, I took off that plastic underguard and bolted it there.
Old 03-02-2012, 04:44 PM
  #273
04TL4P3's Avatar
Congrats!
Old 03-08-2012, 07:25 PM
  #274
21 Acura RDX Aspec
JayVee's Avatar
subscribing...Project of my own coming soon
Old 03-08-2012, 07:30 PM
  #275
Keep us updated!
Old 03-08-2012, 07:35 PM
  #276
21 Acura RDX Aspec
JayVee's Avatar
Keep us updated!
U know I do G~PLAYER via my PROGRESS thread I just text MONDO to see if he has TLS grilles available and back up posted on FS thread for a pr of TLS grilles in the BM.
...BTW, AWESOME FREAKIN write up A+
Old 03-15-2012, 09:30 PM
  #277
2004 Acura TL
navarretg's Avatar
Does anyone have a part # for the black relay? I think mine is faulty and now my fogs do not turn on?
Old 03-15-2012, 09:33 PM
  #278
Did you check the fuse and all wiring connections?
Old 03-15-2012, 09:52 PM
  #279
2004 Acura TL
navarretg's Avatar
yes the fuse are properly working, I changed them out with the new ones to be sure. It might be the ground wire but I will work on the car again tomorrow.
The only reason I believe its the relay because it makes a weird clicking noise when holding the ground wire to any piece of metal. And I was having the same problems before and I just unplugged the relay and plugged it back it and the fogs worked. I am really stumped.
Old 03-15-2012, 09:56 PM
  #280
TLDude876's Avatar
If the relay clicks that means its working. I'd double check the wiring
Quick Reply: G-031: [DIY] Accord Fogs with Type-S Grills on '04-'06 TL
