ISC Coilover Settings
#42
Here's my current settings
Height (Ground-Fender)
FL 24-3/4" FR 24-3/4"
RL 24-3/4" RR 24-3/4"
Dampening
F 22/32
R 16/32
I was feeling a little bouncy and adjusting the firmness up front by 6 clicks really seems to have helped with that.
Dampening
F 22/32
R 16/32
#43
I'm about to get these installed. I've seen a couple of your pictures, and it seems like it's functional low, not too low, which I like (clears fender gap). Do you scrape going straight over mall speed bumps? Do you find yourself driving like a snake on roads? lol
#44
How low is that typically from stock? 2 inches? You have a Type S right? I haven't measured the stock height ground to fender yet.
The only time I have any issues with scraping is when I have to turn up a steep incline at full lock. My tires rub slightly up front. Other than that, I just take my time over speed bumps (no scraping) and try to avoid the monster inclines that just about anyone with any type of drop would fall victim too.
#45
Spring Rate = 12/8
Preload Setting = 178mm
Dampening Front = 16 (begin with..)
Dampening Rear = 16 (to begin with..)
Collar to Collar Distance Front = N/A"
Collar to Collar Distance Rear = N/A"
Distance Ground to Fender Achieved Front = 25"
Distance ground to Fender Achieved Rear = 25.25"
I have slight bounciness in the front so I am going to adjust to maybe about 20 and see what happens..
Keep you posted..
Keep you posted..
Spring Rate: 12/8
Preload Setting = ~173mm (went 1-2mm over the recommended setting)
Dampening Front = 21
Dampening Rear = 16
Distance Ground to Fender Achieved Front = ~24.9"
Distance ground to Fender Achieved Rear = ~24.9"
Dampening Rear = 16
4drviper
09-23-2015 07:42 PM
