Rough Engine
Old 11-16-2006, 11:05 PM
mrlifts's Avatar
Rough Engine
I have a 97 3.2 and when the engine reaches 1,500 rpms, it starts to sound like a diesel engine. However, it runs just fine at all other RPMS. The Dealer says it is normal for all 97 TLS. If I put the car in neutral and rev to 1,500, it starts to run rough. Does anyone else have this problem? If so, what cured it?
Thanks,
Mrlifts
Old 11-16-2006, 11:14 PM
Ken1997TL's Avatar
Received 2,328 Likes on 1,308 Posts
Its normal. Its a 90 degree V6, which tends to be rougher than a 60 degree. The 3.5 RL's engine has a balancer which smooths this out. Our engines dont obviously.
Old 11-17-2006, 01:53 PM
Tri State ViP Crew
96teeluxury's Avatar
Originally Posted by mrlifts
I have a 97tl diesel engine
imagine.
Old 11-17-2006, 02:35 PM
pi1996's Avatar
my car sounds rough in drive.. when i rev it in park its fine..
its 2.5..
maybe my bypass valve on the intake is stuck..
but, then it would be same in park.
i do have one clip missing where air filter cap is.
would that do it?
anyway.. any ideas anyone?
Old 11-17-2006, 02:50 PM
Acura Vet
alphason'sac's Avatar
its 2.5..
would that do it?
Anyone? I have the same problem with my 2.5. She sounds/feels rough at a stand still while I am in, but when I put her in neutral it's smooth as silk. Other than the fact that she is 10 years old, I wonder what causes that. It hasn't always been that way.
Old 11-19-2006, 05:24 PM
TexasHonda's Avatar
A new set of plugs, wires, distributor rotor, and distributor cap from the one time factory emissions service made my 2.5TL purr like a kitten, under load or not.
I've heard of damaged engine and transmission supports causing vibration. This would be consistent w/ vibration w/ the engine in gear and stopped.
good luck
Old 11-20-2006, 10:27 AM
crucial24's Avatar
am is it normal going off topic a little when my TL 96 2.5L is in park or stop its rpm is lil under 1 is that sound correct to you or is there a power issue?
Old 11-20-2006, 12:03 PM
TexasHonda's Avatar
Mine runs about 750 rpm at idle. If you're at 1000 rpm, you may have a slight air leak in the intake system somewhere. It should definitely be in the range 750-850 rpm when fully warm.
It may help to clean the EACV and throttle plate w/ throttle body cleaner.
good luck
Old 11-22-2006, 10:12 AM
crucial24's Avatar
oh ok thx 4 da info
Old 11-23-2006, 11:43 AM
crucial24's Avatar
good luck
but do you have a sound sytem in your car aftermarket or some sort of electronics that use quite a bit of power??
Old 11-23-2006, 11:53 AM
meazz1's Avatar
Make sure the exhust manifold is not cracked.
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
gator90065
10-08-2015 10:14 AM
Frathora
09-28-2015 11:29 PM
IlliniAcura
09-19-2015 09:31 PM
Caddy
1G RDX (2007-2012)
09-18-2015 12:44 PM
Quick Reply: Rough Engine
