LED (blue) dash conversion... work in progress
Old 06-16-2007, 10:52 PM
  #121
woooo!!
subtledreamer's Avatar
Originally Posted by VoLLy_1llusioNz
I know about the defroster button (i read your posts thuroughly), I was asking about the temperature knob. Can I keep the red on the right side of the knob?
same solution - use a white LED instead to retain the red
Old 06-27-2007, 01:13 PM
  #122
Meridian
VoLLy's Avatar
I FINALLY DID IT!
Took me about an hour to do:
I used the white LED for the odometer, it shows the opened doors/trunk clearly, not hard to see at all.
Old 06-28-2007, 06:17 PM
  #123
mmmmmbarb's Avatar
So you put white leds in the defroster and the odometer? it seems like it is pretty blue.
So... for the whole setup so far, you're getting 5 blue leds for the climate, 3 white for odometer?, and 1 white led for the clock. (I'd rather not put leds into the turns and I have gauges so I won't need leds for the gauges). Is that correct?
And these bulbs are all 74's, the same ones used in the shiftgate? Best deal is at v-leds, here http://frickinbrite.com/catalog/index.php?cPath=69?
Lastly, what is the opinion of these replacement LEDS? Is there a big problem with the hotspots?
If there are no size replacements for the other buttons, I think I'd have to get them from LEDautomotive and get them soldered from the guy there... My sunroof bulbs went out, and I need to replace them. Would it look pretty bad if I had a mix of the replacement wedge leds and the LEDautomotive leds? For the cost, is it better to buy them at ledautomotive?
Old 07-05-2007, 05:27 PM
  #124
woooo!!
Ding ding ding! Good news!!
I've found a way to fit the wedge LED bulbs into the AC temp/mode display without soldering but do need some shaving of the sockets.
However, the downside: the display is SUPER bright and a no-no for night time. Solution I could think of at the moment - some sort of light-deterring film (aka tint?) to lay over the clear plastic cover. Once I've found the right material I'll let you guys know & post some pics
Old 07-06-2007, 12:43 AM
  #125
Meridian
VoLLy's Avatar
oH nice! Can you show me how you did it (shaving bulbs)? And did you also find out the 2 bulbs that go on the top of the climate controls and fan speed?
As for the fricken bright display, i heard you can use a permanent marker to diffuse some of the light. try to see if that works.
Old 07-20-2007, 09:49 PM
  #126
pjoseph's Avatar
how long does a job like this take?
Also does anyone have some pics with a different color, how do you think the white would look?
Old 08-21-2007, 12:35 PM
  #127
JoBiggs's Avatar
hot...
Old 08-21-2007, 03:08 PM
  #128
Meridian
VoLLy's Avatar
Any update of the wedge bulb that fits in the A/C display?
Old 10-04-2007, 05:21 PM
  #129
illjuan3's Avatar
autolumination.com wedge type A 8mm bulb will fit perfect
Old 10-04-2007, 06:51 PM
  #130
Prick of the month
02TLSfan's Avatar
Got a direct link for this? There are many wedge bulbs on their site. Makes no difference to me since I don't use the bulb holders any more, but I'm sure others would appreciate it.
Old 11-12-2007, 01:16 PM
  #131
Rich
Rsoetidjo's Avatar
Hey guys, I know this it an old thread.
I just got the silver reverse glow gauges for my wife car.
And now they don't match with the rest of the dash.
I'm thinking do the LED on the dash.
What do you guys think about this guy.
http://www.ledautomotive.com/OrderIn...03TL/index.asp
Should I get the hyper white or the blue LEDs?
Old 02-25-2011, 10:03 PM
  #132
Studflucker's Avatar
sub, for teh future reference
Old 02-26-2011, 10:44 PM
  #133
Old 03-02-2011, 12:13 AM
  #134
riTLce's Avatar
Hey, so I did the climate control and dash all great, still working on the fogs & dimmer switch. After I unplugged the gauges to do the leds in them, when i plugged it back in the turn signals do not light up, on the inside or outside. The high beams only stay on when I hold down the bar. The fuses are fine, does anyone know what the reason could be for this?
Old 03-10-2011, 08:36 PM
  #135
Ruyguy331's Avatar
the site seems to have changed the products around. will these bulbs fit from autoillumination? or does anyone know where i can get the ones that will fit?
Japanese OEM Neo - Wedge LED Instrument Panel Bulbs Type A, B & C
Type A (T3)
39397-SA5-003
8mm= 5/16"
thanks
Old 06-02-2011, 06:21 PM
  #136
IceCube's Avatar
Upgraded dash LED's
Just changed out all my dash lights to blue solder less LED's, purchased from LEDautomovite.com. I love it now, looks so much better than before. The climate control is super bright...so I'm not too sure if it will become a bit of an eye sore during night driving. The whole thing took me about 2.5 hours. Just had to test everything and make sure the bulbs lit up...some of them just needed to be flipped around, not too difficult, but still time consuming.
The only problem that I have is that my clock display is quite dim. I can still see some blue light emanating from it, but everything else is 10 times brighter than it and I can't figure out what the problem is! Anyone have any suggestions?
Old 06-02-2011, 06:49 PM
  #137
Unregistered Member
Karanx7's Avatar
What bulbs did you use for the turn signals? I don't think LEDautomotive.com sells those.
How was the Odometer led fitting? My center LED was pretty loose, but it fit in.
Old 06-02-2011, 07:14 PM
  #138
IceCube's Avatar
So I answered my own question....saw Subtledreamer's clock fix with the foil, worked like a charm.
The turn signal bulbs I used were #74SP from LEDautomotive.com, pretty much plug and play like the odometer. All three of mine were a little snug to get in, maybe yours was changed in the past and they could have loosed the hole a little. I'm sure once it's in there it should be good, you could always put some electrical tape over it just in case it decides to shift.
I didn't have a problem with any of them being loose...but some of them were super tight to get in. Which cause some problems if the polarity wasn't correct and I had to preform surgery to wedge it out and turn it.
Old 06-04-2011, 07:19 PM
  #139
skilzz's Avatar
great write up i just completed mine. all white bulbs and filter removed from the clock. the small wedge bulbs the OP couldnt find numbers for are 3mm neo wedge, you need 4 for the climate control or 6 if you want to do the cruise button. i ordered all my bulbs from superbrightleds.com. i didnt order the 3mm neo wedge in my first purchase so ill order those next week. oh and fix the leds in the auto/off buttons lol i just realize they aren't workin. now for the crap pix
Old 02-07-2012, 01:09 PM
  #140
Es617's Avatar
Can someone correct me if im wrong but aren't the bulbs
6 T4 Led Bulbs 5 for climate control and 1 for the clock
9 74 type Blubs for the Cluster and Odometer
and T1 bulbs for the display? im trying to make a list to order all the bulbs at once but seems to keep poping up with different awnsers
Old 01-30-2013, 09:39 AM
  #141
fog80's Avatar
hey fellas, a lot has changed in the 6 years since this thread has started. Can someone update the thread with the cheapest bulb deal to replace the climate control and instrument cluster gauge lights?
Theres like a million #74 bulbs at each of these sites now.
Thanks.
Old 01-31-2013, 01:17 PM
  #142
@Mikeshlong On IG
mikebikelife's Avatar
i know the neowedge 3~5 bulbs DO NOT work .
Old 03-25-2013, 06:08 PM
  #143
fog80's Avatar
anyone?
Old 03-27-2013, 09:20 AM
  #144
Es617's Avatar
Thanks.
6 T4 Led Bulbs 5 for climatecontrol and 1 for the clock
As for the ac display and the bottone T3 Bulbs i did my whole dash for less that $35 beasts paying close to 100 for the kit
Dont buy them from those sites there over prices and are butt raping with shipping. all type 74/t5 bulbs are the same just some copanies bulb looks differnt. No one has updated this because the information is there. Just look them up in ebay and save yourself some money
The following 3 users liked this post by Es617:
brianmystery (11-13-2021), fog80 (03-27-2013), GK03TL (10-16-2015)
Old 03-27-2013, 10:03 AM
  #145
fog80's Avatar
Thank you!
Old 03-27-2013, 10:53 AM
  #146
fog80's Avatar
Ok so i went to the superbrightled site where i got my 74 bulbs from and they dont have anything labeled T4.....is there another name for them?
Old 03-27-2013, 12:51 PM
  #147
Es617's Avatar
Dude save your Money and buy them off ebay. they have them for a set of 10 for $1 and 5 dollars shipping your paying 3 + shipping for each one on that site
hamburglar490 (03-27-2013)
Old 03-28-2013, 10:05 AM
  #148
fog80's Avatar
wow, and there is no difference in quality? I'll probably return these and get some from ebay.
Old 03-31-2013, 03:17 PM
  #149
fog80's Avatar
checking ebay and i dont see any "kits" for the acura dash/climate control
Old 04-14-2013, 06:42 AM
  #150
robertzanzerkia's Avatar
Bulbs for MDX?
Hi,
I am trying to figure out which bulbs to order for MDX cluster LED upgrade.
I need 5 of below:
35505-SJ4-003 (14V 3W) - for techo, speedo etc.
length = 19mm, large diameter head.
I need 3 of below:
78181-S0K-A21 (9.5V 1.14W) - for odometer display.
length = 16mm, thin head.
I do have twist/out plastic base for each so I could just insert new ones in the old base.
I noticed that for odo display TL users are using same bulbs as the rest of the cluster... Mine is definately shorter...
What will be equivelent LED bulbs and where do I get from?
Thanks,
Robert
Old 04-25-2013, 07:23 PM
  #151
jaycaro28's Avatar
fresh!!
im diggin it... but has anyone done it in red? i wonder how tht looks....
Old 04-27-2013, 11:05 PM
  #152
JasonLively's Avatar
Es617, could you please link to ebay for us the colors, styles, etc? thankyou
Old 06-20-2013, 02:47 PM
  #153
9th Gear
Josue Montoya's Avatar
I'm totally gonna do all this... anybody try different colors???? would love to see possible option other than white or blue... (nothing against the colors)
Old 06-21-2013, 08:56 PM
  #154
Chris Silva's Avatar
What a great mod. I'm a bit nervous about picking it up myself but if it's all mostly plug and play than this is definitely worth it.
Old 01-06-2014, 01:38 AM
  #155
Gil'sUA5's Avatar
This is a complete plug and play job when it comes to all of the bulbs
Old 07-07-2014, 01:46 PM
  #156
RMoody18's Avatar
Good ish..I will be attempting this soon.
  #157
RMoody18's Avatar
Good ish..I will be doing this soon...hopefully
Old 07-07-2014, 01:49 PM
  #158
RMoody18's Avatar
Thanks for this DIY. I will def be doing this soon...hopefully
Old 07-07-2014, 01:50 PM
  #159
RMoody18's Avatar
My bad for the 3 same posts..cpu is screwing up
Old 07-08-2014, 01:03 AM
  #160
Alexlee337's Avatar
Looks great
Quick Reply: LED (blue) dash conversion... work in progress
