p2r manifold spacer
you'll see a itty bitty torque increase!
Looking at 5 and up to 10 wtq on the powerband. At the cost of 1-2 HP. I'll share the dyno pix once I get the PC up and running again.
as promised. This is from an accord v6 6spd. TL will probably see similar if not more power.
ALL credit goes to Cubanob247
I also want to correct myself. You lose top end tq and a few top end HP. You gain midrange HP and gain low-mid range tq
2G TLX-S
What does a space do in terms of performance ?
Edward'TLS (08-28-2014)
2G TLX-S
any air tuning is done in the intake manifold and not before it, thus why throttle spacers dont do anything.
however, the intake manifold spacer goes after the intake manifold!
throttle body --> Intake manifold --> intake manifold spacer --> injector runners --> heads.
the spacer most likely aids in air tuning by creating more volume before it enters the cylinders.
Edward'TLS (08-29-2014)
It effectively makes the individual runners longer. Do a internet search on intake runner length tuning. What year MDX had a stock spacer?
The MDX spacer is a little tight for an Accord, TSX, or TL.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-mdx-pilot-odyssey-spacer-install-749688/
rp_guy
07-16-2017 07:33 AM
