Type-S Torque Sensitive power steering - AcuraZine Community
Welcome to Acurazine.com!
Welcome to Acurazine.com.
Old 02-11-2001, 11:30 PM   #1
Guest
Posts: n/a
Question Type-S Torque Sensitive power steering
The March 2001 Car&Driver article (pg 83) states:
"The crowning touch, we think, is the replacement of the TL's speed-sensitive power-steering assist with a torque-sensitive system that offers much better road feel to the enthusiast driver."
What is "Torque-sensitive" power steering? How will it work? I assume at low engine torque times, the power assist will be high, and then at high torque times it will be less assisted. (Parallel parking, low engine torque, high power steering assist.) Is that right?
But what about when you are coasting down a hill, foot not even on the gas pedal, high vehicle speed, but low engine torque. In that situation, would power assist be high? (Eeeek!! A slight turn of the wheel, and you drift off the road.) Conversely, when I am turning onto the street, low vehicle speed, but high engine torque, then the power steering assist would be low, hard to turn the wheel. That doesn't sound good either.
Anyone know how this system really works, because I am an engineer, and this has me stumped.
Sponsored Links
Old 02-12-2001, 8:31 AM   #2
Road Rage
Not a Blowhole
Road Rage's Avatar
Post
I to am an engineering type, and this smells of the marketing folks' ignorance. I am sure they mean speed-sensitive.
Road Rage is offline   Reply With Quote
Old 02-12-2001, 9:08 AM   #3
jhalderman
Registered User
Post
The torque-sensing is the torque you the driver is applying to the steering wheel-not the engine torque.GM calls their version Magasteer.
jhalderman is offline   Reply With Quote
Old 02-12-2001, 8:44 PM   #4
Guest
Posts: n/a
Post
OIC. Now that is so obvious. Thanks! I never thought it would mean THAT torque, since that is what is assisted by the power steering feature. Must be some type of "looped" circuit. Cool!
Old 02-15-2006, 11:13 PM   #5
zibadun
Registered User
I'm still lost. Can somebody explain in idiot terms the difference between Torque-sensing and speed-sensing steering? tnx
zibadun is offline   Reply With Quote
Old 02-15-2006, 11:57 PM   #6
Leviathan
Holdin it down for MS
Leviathan's Avatar
Five year old thread revived!
Leviathan is offline   Reply With Quote
Old 02-15-2006, 11:58 PM   #7
Pure Adrenaline
Dragging knees in
Pure Adrenaline's Avatar
From what I remember...
On speed-sensitive, the power steering assist boost is relative to the vehicle speed.
On torque-sensitive, the power steering assist boost is relative to the engine speed (RPM).
It's all possible by a variable-ratio power steering pump that can vary the force of hydraulic pressure to increase or decrease steering assist.
But I'm not 100% sure, so don't quote me.
Pure Adrenaline is offline   Reply With Quote
Old 02-16-2006, 10:29 AM   #8
zibadun
Registered User
Or does torque-sensitive mean there is a sensor to detect how much resistance wheels get from road surface while turning?
Old 02-16-2006, 3:20 PM   #9
03CoupeV6
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
Here is the explanation of speed-sensitive:
http://www.canadiandriver.com/articles/jk/at_010327.htm
Here is the explanation of torque-sensitive from Honda:
Rack and Pinion Steering With Improved Stability and Reduced Kickback
The Accord's well-weighted and highly responsive power rack-and-pinion steering system provides an exceptionally linear and consistent feel regardless of pavement conditions. The Accord's power assist is steering-torque sensitive; hydraulic boost is applied to the system in direct proportion to the amount of force (torque) created between the tire and the road as the wheel is steered.
As the force increases, the system increases the amount of power assist accordingly. Regardless of speed, an increase in effort is countered by an increase in boost (for example, if the wheels encounter a rough surface with a greater coefficient of friction).
Source: http://www.hondanews.com/CatID2006?m...36652&mime=asc
Now maybe this 5 year old thread can
03CoupeV6 is offline   Reply With Quote
Old 02-16-2006, 9:12 PM   #10
zibadun
Registered User
Thanks 03C, it now makes the perfect sense. I guess I wasn't using the right search terms. RIP
Old 01-11-2008, 4:56 PM   #11
k9500winmag
i eat ricers
all i know is that in my 96 TL when i hit the gas (even at speed) i get torque steer pretty bad. especially noticable on the interstate when i drop a gear and stomp it. course it also breaks traction to the front tires half the time when i do this...
k9500winmag is offline   Reply With Quote
Old 01-11-2008, 7:42 PM   #12
Gfaze
Registered Evil Monkey
2000 Acura TL
My Garage
Gfaze's Avatar
Almost 7 year old thread brought back from the dead.....a 2nd time!
Gfaze is offline   Reply With Quote
01, power, sensitive, speed, steering, tl
