| Welcome to Acurazine.com! |
Thread Tools |
#1 | |||||
Registered User
91 Ocatane ?
| Sponsored Links | ||
#2 |
Registered User
Just use the 94 octane, or, if you are a bit anal, use half 89 and half 94.
#3 |
Smitty's Moral Police
Come out west and you'll never see more than 91 from any company..
#4 |
Administrator
The manual calls for 91 octane, so that is the minimum you should use.
#5 |
You touch my tra la la...
I heard the West Coast only has 91 octane due to some stupid limits on octane levels. For example, Mobil sells 93 octane except on the west coast where the same name gas is only 91.
#6 |
Registered User
Even here on the east coast Sunoko has stopped making 94 ultra and is now 93 ultra.
#7 |
Registered User
I'm not a chemist, but I did hear an explanation once of what the point is with the octane rating. I believe the only issue is that the higher the octane, the higher the 'threshhold of combustion'. Raising this prevents the gas/air mixture from igniting before the spark fires due to the compression in the cylinder. If you use low octane gas on a car with high compression (like the TL), you'll tend to get 'pre-ignition', which means the gas explodes before the spark fires (i.e. before the piston gets to the top of the cylinder). This is a bad thing because it tries to push the piston back down, when it's still coming up. It results in a metallic pinging sound on hard acceleration.
Somehow (I don't know how), Acura modifies something about the way the engine runs (maybe the spark timing?) to compensate if you're not using the correct gas. Summary: If the car doesn't need high octane gas, it doesn't buy you anything (i.e. you're wasting your money). If the car needs it, you should use it, but you needn't use anything higher than what's required. If you use higher than what's required, you still achieve the desired result. So if you use 91, 92, 93, 94 or higher in the TL, it works fine. If you use 91 in a non-type S RSX, you're wasting money. If there's someone out there who knows more about this, please correct me. I believe, however, that this is a materially correct answer. |
#8 | |
Lurker
#9 |
Wow. How much did it cost?
#10 | |
Lurker
IMO, if you liven in a moderately cool climate, don't live in hilly terrain which puts a long consitant load on the car, you should be able to get away with running 89 without detonation. However, you also have to ask yourself this. Just how much are you saving. Here in SoCal, gas prices are typically .10-.15 per grade with say 87 at $2.15, 89 at $2.25 and 91 at $2.35. So if you fill up on with 14-15 gallons, you're only looking at $1.50 to $3.00 per tank difference to run 91. Then comes how much to you fill up. I commute 50 each way to work so I'm filling up way more frequently than most people and it still comes out to about $6/wk extra for 91. |
#11 | |
Lurker
In SoCal I've seen it for as cheap as $2.75 if you buy it by the drum (when prem 91 was $2.17/gal) and that's not bad at all. But then they get nearly as much again for delivery if you don't pick it up yourself. But from my understanding ConocoPhillips which bought the Unocal refineries and I think even their service stations is no longer making these "race" grades anymore. |
#12 |
Registered User
#13 |
Registered User
In case you didn't realize, airplanes run on 100 octane Low Lead. That Unocal stuff was probably aviation fuel.
#14 |
Or it just had the same octane.
#15 | |
What's a TL?
2006 BMW M3- SMG, Navi, Competition Package, Premium Package SOLD: 3rd Gen/WDP/AT/Non-Navi Injen Intake, Decklid Spoiler, Comptech Springs, Gunmetal Emblems, 19" Volk LE37t Wheels, Smoked Headlights |
#16 |
Registered User
Amoco, Mobil and Exxon all sell 93 octane in the Northeast.
#17 |
Registered User
Stations around here have 87, 89 or 93 octane. I remember years ago that Sunoco had a switch on the pumps that would blend the grades, depending on what octane you wanted. Seemed like a good idea since only 2 grades would be required and the desired octane could be anywhere between the low and the high.
#18 |
Registered User
Isn't 89 fine....in the grand scheme of things???
#19 |
Team Camel, VP for Zaino
Why does higher octane cost more? Does it take more time to refine it?
#20 | |
Registered User
#21 | |
Registered User
Anybody know something about this? |
#22 | |
Team WD Member
FWIW, if you're in the neighborhood cheapest Premuim at $1.22/gal at 76 station at DuPont exit off I-5. Price goes up if you're not in the neighborhood.
2004 TL 5AT Navi, White Diamond Pearl/Quartz Team WD Ambassador to Freedonia XM Channels: 07, 46, 70, 71, 72, 73, 110 1960 Nash Metropolitan K7JF |
#23 | |
Lurker
#24 | |
04TL, Anthracite/Ebony, 5AT/Non-Navi, Body kit, 18" OEM wheels, Injen CAI, Comptech rear sway bar |
#25 | |
Team Anthracite
#26 |
Registered User
Cleaner
Burning higher octane fuel has all the benefits mentioned in prev. threads... However, in burning lower octane fuels - when it detonates prematurley, it leaves very high carbon deposits on the cylinder wall and piston heads.
Not Good.... |
#27 | |
Mega Moderator
Quick Q. I thought the same thing, but ever heard that Sunoco uses two tanks (high and low) and mix together to have all their octane oils... Anyone knows this? Thanks. |
#28 |
Finally filled my car up today driving home from lunch after my AP Biology exam :p
I had to buy 93 octane at Mobil and it was about 2.40 a gallon ![]() |
#29 |
The differences in the octane of the west coast vs the east coast are because of altitude differences. The west coast is closer to sea level and therefore the air pressure is higher. The air here in the east coast is generally thinner and combusts much more easily therefore requiring a higher octane rating. Remember octane retards combustion.
I'm not completely sure my explanation is correct but I know its because of altitude. Exceptions are due to the actual elevation you are at. You can be in the mountainous regions of california and have higher octanes there. |
#30 | |
Lurker
#31 | |
Registered User
#32 | |
Team Anthracite Member
Maybe the base stock is part of it, since I do know that compared to other parts of the country you'll seldom find a car exhaust that has the rotten egg smell in the upper midwest. But other areas... pew ![]()
Ted 04 TL 6MT Anthracite/Quartz Navi Truth is a three edged sword... |
#33 |
Registered User
i was driving to las vegas yesterday from san diego...saw 100 octane from a 76...didn't get it =)
#34 | |
TL-S - Rocks
2010 Acura TL |
AV-Gas
2010 TL SH-AWD Black/Ebony / 6MT / Tech NAVI |
#35 | |
Lurker
#36 | |
Registered User
Yep, west coast (CA at least) has only 91 as premium. Nothing higher than that. It used to be 92 a few years back. I've been driving for 15 years here and don't recall ever seeing 93/94.
2004 TL - Abyss Blue/Quartz/AT/Navi 2006 Ody - Ocean Mist/Ebony/Touring/Nav |
#37 | |
04 TL 6MT NAVI ABP/Q
Now that I know the TL reccomends 91, I'm gonna have to remind him to call me everytime he "drops a load" in Simi Valley where I live. I wonder how much a 50 gallon drum and a hand pump costs.... |
#38 | |
#39 | |
Registered User
I recently saw 100 octane gas at a Mobil station in Connecticut. It was $5.00+ per gallon. It was called CAM2 or something and was labeled "racing fuel." I'm pretty sure that putting this in the TL would not improve performance at all and could actually, over a long period of time, damage the engine that is not made to "handle" such high octane fuel. I was tempted to put some in to see what happened, but then I started thinking rationally. Don't waste your money.
04 TL 5AT SSM/Ebony E-Shift Pro Cats AEM Cold Air Intake UR Underdrive Crank Pulley Outlaw Engineering ThermoBlok Spacers Comptech Rear Sway Bar Underbody Spoiler Kit Wheels: 18x8 Sport Edition E1 Tires: Pirelli PZeroNero M+S Pending: Comptech Cat-Back Exhaust Rotora BBK Also: 2006 Toyota Sienna XLE AWD Previously: 2004 Toyota Highlander V6 4WD 1996 Honda Civic EX Coupe 1985 Toyota Camry 1982 Toyota Celica GT |
#40 |
Registered User
91 Octane is dependant of what elevation of the city is at. Out here in SLC, UT, we don't have anything higher than 91. You will probably find the same situation in cities like Denver also. I don't recall what is the specific reason for this, but I think the higher octane is not as efficient burning in the high elevation because of the lack of oxygen. Also quarter mile times are lower up here because of the lack of oxygen compared at sea level.
| Thread Tools | |
