The 3G TL Garage: FAQ for 3G TL Newbies.....
Old 06-22-2004, 05:08 PM
Moderator Alumnus
rets's Avatar
Exclamation The 3G TL Garage: FAQ for 3G TL Newbies.....
Please always use SEARCH feature prior to your posts. Thanks.
NOTICE
POSTED 21 APR 2017
DUE TO CIRCUMSTANCES BEYOND OUR CONTROL, MOST OF THE LINKS IN THE 3G GARAGE DO NOT WORK.
It appears that the non-working links were deleted or otherwise corrupted.
There are some that work so we hope that the topic you are interested in is still available. If not, we apologize for the circumstances but there is no way to get it corrected.
Ron A
Administrator
AcuraZine.com
TO FIND THINGS MORE EASILY IN THIS THREAD:
1. CTRL + F
2. TYPE IN YOUR KEY WORD (JUST ONE WORD WILL WORK BETTER)
3. PRESS ENTER UNTIL YOU FIND IT OR DON'T FIND IT
4. TRY ANOTHER KEY WORD IF NECESSARY
DIY VIDEO:
These DIY Videos are also posted in their appropriate sections but are compiled here for easy access.
A-125: DIY VIDEO: Valve Adjustment Procedure/Scans Post #6
https://acurazine.com/forums/3g-tl-problems-fixes-114/125-valve-adjustment-procedure-scans-714317/
A-128: DIY VIDEO: Axle Replacement/Transaxle Replacement 5AT/6MT
https://acurazine.com/forums/showthr...8#post13001718
B-001: DIY VIDEO: Uninstalling OEM Intake & Installing Cold Air Intake
https://acurazine.com/forums/third-generation-tl-2004-2008-93/diy-video-uninstalling-oem-intake-installing-cold-air-intake-3g-garage-b-001-a-628372/
B-002: DIY VIDEO: Throttle Body Spacer Install
https://acurazine.com/forums/showthread.php?t=169891
https://acurazine.com/forums/showthread.php?t=172288
E-080: DIY VIDEO: Removing Your FRONT bumper
https://acurazine.com/forums/showthread.php?t=169101
E-095: DIY VIDEO: Removing Your REAR bumper
https://acurazine.com/forums/ramblings-12/denise-richards-plaboy-pics-%2Anws%2A-160358/
F-051: DIY VIDEO: Removing Center Console, Glove Box, Lower Dash
https://acurazine.com/forums/3g-tl-2004-2008-93/f-051-diy-video-how-remove-center-console-lower-dash-glove-box-733555/
LISTING OF MAJOR TOPICS
A.
  • Engine
    • Drivetrain
      • Transmission
        • ECU
B.
  • Intake
    • CAI
C.
  • Fuel
    • Oil
      • Filters
D.
  • Tires
    • Wheels
      • Springs
        • Suspensions
          • Brake
E.
  • Exterior
    • Exhaust
F.
  • Interior
    • Console
      • MID
        • HVAC
G. Lighting
H.
  • Car Care
    • Clear-bra
I.
  • Audio
    • Electronics
      • Navi
        • Bluetooth
          • iPod
            • MP3
              • Alarm
                • Radar
J.
  • TSB
    • Manual
      • Safety
K.
  • Windows
    • Tint
      • Trunk
L. Miscellaneous
M.
  • Performance
    • Drag
      • Charts
        • Statistics
Ctrl + F could help look for keywords in this threadA. Engine (engine bay)/Drivetrain/Transmission/ECU
A-001: Break-in
https://acurazine.com/forums/showthread.php?t=88638
A-004: Name:  o.gif
Size:  1,019 Bytes Click/Thump/Flap/Clunk Noise
https://acurazine.com/forums/showthread.php?t=107082
https://acurazine.com/forums/wash-wax-23/new-bf-2-ordering-now-85426/
https://acurazine.com/forums/showthread.php?t=83071
https://acurazine.com/forums/showthread.php?t=88521
A-007: Clunk Sound When shifting into R, on slope
https://acurazine.com/forums/showthread.php?t=92839
https://acurazine.com/forums/showthread.php?t=109636
A-010: Name:  i.gif
Size:  1,018 Bytes Driveline vibration
https://acurazine.com/forums/showthread.php?t=90614
https://acurazine.com/forums/showthread.php?t=94301
A-013: Knock sensor wire chewed by a mouse
https://acurazine.com/forums/showthread.php?t=86162
https://acurazine.com/forums/car-parts-sale-361/2000-tl-forsale-173982/ DIY
A-016: Does M/T has cruise control?
https://acurazine.com/forums/showthread.php?t=91276
A-019: Fuel efficiency on Highway by 6MT
https://acurazine.com/forums/ramblings-12/hahaha-check-out-82207/
A-022: Optimal speed for best MPG?
https://acurazine.com/forums/showthread.php?t=94398
A-025: Is initial lag in acceleration normal?
https://acurazine.com/forums/showthread.php?t=79782
A-028: Name:  o.gif
Size:  1,019 Bytes Malfunction Indicator Lamp (Check Engine Light)
Before 12xxx, software/firmware update is required.
Crankshaft position sensor/valve controller/O2 sensor/Coil packs/Exhaust Gas Recirculating Valves/ECM (PCM) software incorrectly interprets sensors inputs could be the factors, too.
https://acurazine.com/forums/ramblings-12/lexus-gs-300-400-webpage-84633/
https://acurazine.com/forums/car-talk-5/pic-axis-se7en-mod-350z-81019/
A-031: Name:  o.gif
Size:  1,019 Bytes TSB: 04-020, Safety Recall: 2004TL Automatic Transmission Second Gear Inspection
https://acurazine.com/forums/showthread.php?t=154245
https://acurazine.com/forums/ramblings-12/have-you-guys-seen-new-mitsubishi-commerial-new-outlander-87113/
https://acurazine.com/forums/showthread.php?t=86798
https://acurazine.com/forums/showthread.php?t=85737
A-034: Name:  o.gif
Size:  1,019 Bytes Have any Canadian TL owners received their transmission recall notices?
https://acurazine.com/forums/showthread.php?t=88639
A-037: Put your auto trans into neutral for traffic lights?
https://acurazine.com/forums/audio-video-electronics-navigation-22/video-special-check-out-88066/
A-040: Shifting between N and D... good or bad?
https://acurazine.com/forums/religion-politics-18/human-shields-around-iraqi-power-plant-98273/
A-043: Name:  o.gif
Size:  1,019 Bytes Hard to start the engine
https://acurazine.com/forums/showthread.php?t=85300
https://acurazine.com/forums/acurazine-clubs-meets-15/track-meet-sat-byron-il-april-12-a-100058/
A-046: Name:  i.gif
Size:  1,018 Bytes Nitrous...
https://acurazine.com/forums/ramblings-12/if-you-tech-support-you-will-love-%3Dp-91677/
https://acurazine.com/forums/moderators-only-20/johntypes-i-think-its-time-filter-his-e-mails-94095/
https://acurazine.com/forums/ramblings-12/ever-had-really-bad-day-96934/
A-049: Name:  o.gif
Size:  1,019 Bytes Key not turning to off position?
https://acurazine.com/forums/showthread.php?t=108557
https://acurazine.com/forums/ramblings-12/peter-cunningham-abandons-integra-goes-nissan-101933/
A-052: HP/Torque question
https://acurazine.com/forums/showthread.php?t=100949
A-055: Do you need Black Plastic Covers on your engine?
https://acurazine.com/forums/acurazine-clubs-meets-15/houston-meet-100627/
A-058: Chain Drive Cams or Belt??
https://acurazine.com/forums/automotive-news-6/land-rover-development-technology-news-101905/
A-061: Sportshift Comparison btwn TL/RL/TSX
https://acurazine.com/forums/showthread.php?t=103299
A-064: Engine block heater
https://acurazine.com/forums/showthread.php?t=70105
https://acurazine.com/forums/car-parts-sale-361/cls-mufflers-wanted-110481/
A-067: Name:  o.gif
Size:  1,019 Bytes Car slows down itself... engine braking... Grade Logic Control System
https://acurazine.com/forums/showthread.php?t=109735
https://acurazine.com/forums/ramblings-12/just-saw-juice-vh1-77329/
A-070: Burnt smell came in through the vents?
https://acurazine.com/forums/showthread.php?t=110324
A-073: Battery cover under hood
https://acurazine.com/forums/car-parts-sale-361/fs-18-inch-chromes-w-tires-111825/
https://acurazine.com/forums/showthread.php?t=113917
A-076: Name:  i.gif
Size:  1,018 Bytes DIY: Cooling system service (coolant/antifreeze drain and refill) and thermostat replacement
https://acurazine.com/forums/showthread.php?t=138131
A-080: Cold Engine = Hi Rev
https://acurazine.com/forums/showthread.php?t=114279
A-083: SAE new horsepower rating system (posted January 17, 2006)
https://acurazine.com/forums/ramblings-12/you-know-youre-balla-when-129954/
A-086: Comptech Short Shifter Install/pics
https://acurazine.com/forums/showthread.php?t=130713
A-089: Optima batteries
https://acurazine.com/forums/showthread.php?t=141425
A-092: 6MT Clutch Adjustment
https://acurazine.com/forums/showthread.php?t=93697
A-093: Clutch pedal replacement, clutch master cylinder replacement, and clutch slave cylinder replacement
https://acurazine.com/forums/audio-video-electronics-navigation-22/street-stylin-any-audiophile-ill-need-advise-185074/
A-094: 3G Acura TL - Mega Squeaky Clutch Repair Thread - All solutions, Low cost
https://acurazine.com/forums/problem.../#post15633203
A-095: 2004 Service manual Clutch Plate, Disk, and Release Bearing Replacement Scans
https://acurazine.com/forums/dating-relationships-14/ok-i-dated-woman-124229/
A-098: Name:  i.gif
Size:  1,018 Bytes DIY: UR Crank Pulley info
https://acurazine.com/forums/showthread.php?t=153549
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/04-08-tl-07-08-tl-s-crank-pulley-install-diy-lots-pics-098-a-836369/
A-101: Name:  i.gif
Size:  1,018 Bytes DIY: Complete guide to battery relocation
https://acurazine.com/forums/showthread.php?t=168353
A-104: Name:  i.gif
Size:  1,018 Bytes DIY: Power Steering Fluid Flush/Change/Serving (Factory Scans with photos!)
https://acurazine.com/forums/3g-tl-2004-2008-93/104-diy-power-steering-fluid-flush-761094/
https://acurazine.com/forums/car-parts-sale-361/anybody-got-cl-type-s-rims-sale-trade-173686/
A-105: Name:  i.gif
Size:  1,018 Bytes DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/ - With Pics and Service Manual Scans
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/ - PS Whine Fix (O-Ring Replacement)
A-107: Name:  i.gif
Size:  1,018 Bytes DIY: Seafoam on 3rd gen TL
https://acurazine.com/forums/3g-tl-2004-2008-93/107-diy-seafoam-3rd-gen-tl-06-5at-specifically-638069/
A-110: Name:  i.gif
Size:  1,018 Bytes DIY: Guide to replacing 3rd & 4th gear pressure switch for 3G TL
2004 - 2006: https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
2007 - 2008 (with Type S): https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
A-113: Name:  i.gif
Size:  1,018 Bytes DIY: Removal of Slave Cylinder checkvalve
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/113-removal-slave-cylinder-check-valve-734300/
A-116: Name:  i.gif
Size:  1,018 Bytes DIY: Transmission Cooler for 5AT with Filter
https://acurazine.com/forums/3g-tl-2004-2008-93/116-diy-transmission-cooler-5at-magnefine-filter-lots-pics-754752/
A-119: Name:  i.gif
Size:  1,018 Bytes DIY: EGR Replacement With Service Manual SCANS
https://acurazine.com/forums/3g-tl-problems-fixes-114/119-diy-egr-replacement-770698/
A-122: Name:  i.gif
Size:  1,018 Bytes DIY: 105K Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-06-tl-spark-plugs-changed-%40-92k-866781/ - Spark Plug Change Tips
https://acurazine.com/forums/showthread.php?t=714317
A-129: DIY: Hood Strut Replacement
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-garage-129-diy-replacing-factory-hood-struts-862266/
A-130: DIY: to fix "Tighten Fuel Cap" message
https://acurazine.com/forums/3g-tl-problems-fixes-114/130-diy-fix-tighten-fuel-cap-message-915682/
B. Intake/CAI
B-004: Name:  i.gif
Size:  1,018 Bytes DIY: Stock CAI Tech
https://acurazine.com/forums/ramblings-12/ps2-online-challenge-me-78890/
B-007: DIY: Intake CAI Tech Resonator Removal
https://acurazine.com/forums/ramblings-12/you-guys-guys-complain-about-pricey-mods-78904/
B-010: DIY: CAI
https://acurazine.com/forums/showthread.php?t=109840
B-013: INJEN CAI vs. AEM CAI
https://acurazine.com/forums/ramblings-12/yo-quick-submit-sh-t-awesome-76157/
B-016: DIY: Bye Bye Intake Silencer
https://acurazine.com/forums/car-talk-5/driver-side-seat-replaced-rsx-loaner-85337/
B-019: K&N filter recalls
https://acurazine.com/forums/showthread.php?t=79098
B-022: OLD and NEW K&N OEM FILTERs
https://acurazine.com/forums/ramblings-12/patent-law-103497/
B-025: TornadoFuelSaver / CycloneFuelSaver
https://acurazine.com/forums/car-talk-5/turbo-z06-135982/
B-028: AEM CAI Installation
https://acurazine.com/forums/showthread.php?t=110471
https://acurazine.com/forums/motorsports-news-7/wrc-some-one-maybe-back-130633/ (with pictures)
B-031: AEM CAI V2 fitment in the 3G TL
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/b-031-intake-review-part-ii-look-aem-v2-683367/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/b-031-my-aem-v2-upgrade-692443/
B-034: Hole in AEM CAI, Vibramount Broke Off
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/b-034-sigh-aem-cai-%5Bexplitive-deleted%5D-kennedy-right-sigh-644889/
B-037: AEM CAI vs. FUJITA CAI
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/b-037-comparison-thread-aem-vs-fujita-641086/
C. Fuel/Oil/Filters
C-001: DIY: Fuel filter regulator/filter/injectors/quick disconnect/int man scans
https://acurazine.com/forums/ramblings-12/i-cant-stand-seeing-my-parents-141280/
C-004: DIY: Oil Change Checklist with Service Manual Scan
https://acurazine.com/forums/showthread.php?t=80273
https://acurazine.com/forums/showthread.php?t=139528 with pictures
C-007: DIY: 04TL oil filter
https://acurazine.com/forums/ramblings-12/am-i-only-one-80570/
C-010: DIY: Mobil 1 Oil
https://acurazine.com/forums/showthread.php?t=87225
C-012: DIY: 5AT tranny fluid change and fluid level check procedure
https://acurazine.com/forums/ramblings-12/anybody-good-xp-89064/
C-013: DIY: 6MT tranny fluid change
https://acurazine.com/forums/ramblings-12/valentines-day-haiku-93452/
https://acurazine.com/forums/car-talk-5/omg-audi-a4-1-8t-114948/
https://acurazine.com/forums/showthread.php?t=120619
https://acurazine.com/forums/showthread.php?t=146299
C-016: 91 Octane
https://acurazine.com/forums/showthread.php?t=80062
https://acurazine.com/forums/audio-video-electronics-navigation-22/ps2-cls-89432/
C-019: Mileage and Octane
https://acurazine.com/forums/ramblings-12/just-got-back-court-104380/
C-022: Brands of premium gas
https://acurazine.com/forums/showthread.php?t=94846
C-025: DIY:The RR Journals: ATF drain and refill (Automatic Transmission Fluid Change)
https://acurazine.com/forums/third-generation-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
C-026: DIY: ATF drain and refill (Automatic Transmission Fluid Change)
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/ - w/Pictures; DIY Video Added
https://acurazine.com/forums/3g-tl-2004-2008-93/optimal-percentage-racing-atf-834299/ - Optimal Racing ATF Percentage
C-028: Oil change!? by MID or miles
https://acurazine.com/forums/showpost.php?p=1156549&postcount=7
https://acurazine.com/forums/showpost.php?p=1157383&postcount=5
https://acurazine.com/forums/showpost.php?p=1156932&postcount=10
C-031: Name:  i.gif
Size:  1,018 Bytes First Oil Change/Plus Blackstone Oil Analysis
https://acurazine.com/forums/ramblings-12/great-trance-track-111490/
C-033: DIY: Oil Pan removal and Re-installation Scans
https://acurazine.com/forums/3g-tl-2004-2008-93/c-033-replacement-oil-pan-708260/
C-036: DIY:5AT Automatic Transmission Filter Change/Replacement
https://acurazine.com/forums/3g-tl-2004-2008-93/c-036-diy-transmission-filter-replacement-pics-787078/ - Pictures inside!
https://acurazine.com/forums/3g-tl-problems-fixes-114/c-036-transmission-filter-change-how-pics-789433/ - Pictures inside!
C-037: DIY:Gear Position Sensor Replacement (aka "transmission range switch")
https://acurazine.com/forums/third-g...switch-892223/
D. Tires/Wheels/Springs/Suspensions/Brake
D-001: DIY: Brake Line Replacement
https://acurazine.com/forums/showthread.php?t=178131
D-002: Brake Fluid - Specs, Change/Flush
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-002-tl-compatible-brake-fluids-boiling-point-specs-793891/ - Fluids & Specs
D-004: Proper Match Mounting of Tires without a Hunter
https://acurazine.com/forums/ramblings-12/could-i-any-dumber-105278/
D-007: Name:  o.gif
Size:  1,019 Bytes Brake Pedal Position Switch
https://acurazine.com/forums/showthread.php?t=92622
D-010: Tires
Old Turanza EL42: OB6N PVC, 0404 or before
New Turanza EL42: OB6N TU2, 0604 or after
https://acurazine.com/forums/showthread.php?t=84545
D-013: Tires pressure
https://acurazine.com/forums/showthread.php?t=88188
D-016: Falken Ziex ZE 512
https://acurazine.com/forums/showthread.php?t=69061
D-019: Pirelli Pzero Nero M&S
https://acurazine.com/forums/showthread.php?t=103015
D-022: DIY: Tein Basic Installed, Review
https://acurazine.com/forums/showthread.php?t=158414
D-025: Tire Mounting - the dot
https://acurazine.com/forums/showthread.php?t=102224
D-028: 18 inch wheels - worth it? decreased mileage?
https://acurazine.com/forums/automotive-news-6/future-cl-102610/
D-031: Got my FALKEN Koblenz on Brembos
https://acurazine.com/forums/ramblings-12/12-down-4-go-103503/
D-034: Wheel speed sensor
https://acurazine.com/forums/showthread.php?t=105757
D-037: Reliable Test for LSD
https://acurazine.com/forums/showthread.php?t=107174
D-040: Serious questions about Brake
https://acurazine.com/forums/religion-politics-18/just-funny-107187/
D-041: Brakes-front/rear caliper overhaul, front/rear pad replacement, brake bleeding, brake disc specifications, parking brake adjustment
https://acurazine.com/forums/3g-tl-2004-2008-93/brakes-caliper-o-h-pad-repl-hoses-bleed-disc-specs-park-brake-adj-3g-garage-d-041-a-578017/
Size:  1,018 Bytes DIY: https://acurazine.com/forums/3g-tl-2004-2008-93/replacing-brakes-pictures-3g-garage-d-041-a-770166/
D-042: 3G Rear Extended Stud Install - Pics inside
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/d-042-3g-front-rear-extended-stud-install-843718/
D-043: Name:  i.gif
Size:  1,018 Bytes Swaybar FAQs
https://acurazine.com/forums/ramblings-12/road-trip-music-time-again-107322/
https://acurazine.com/forums/ramblings-12/well-i-did-111093/
D-046: Wheel sensor may affect your VSA?
https://acurazine.com/forums/showthread.php?t=107892
https://acurazine.com/forums/ramblings-12/anyone-eles-drunk-wen-thur-night-111004/
D-049: Rotors warped (for second time) .. need to buy slotted/drilled front rotors...
https://acurazine.com/forums/showthread.php?t=108061
D-052: Name:  q.gif
Size:  1.0 KB Should we use VSA going up a steep hill?
https://acurazine.com/forums/showthread.php?t=107905
https://acurazine.com/forums/showthread.php?t=111119
D-055: Name:  o.gif
Size:  1,019 Bytes TL unstable with passengers
https://acurazine.com/forums/ramblings-12/longshot-request-help-108368/
D-058: DIY: Self installed A-Spec suspension
https://acurazine.com/forums/showthread.php?t=108545
https://acurazine.com/forums/showthread.php?t=113935
D-061: Name:  o.gif
Size:  1,019 Bytes Comptech Sway Bar 6MT
https://acurazine.com/forums/showthread.php?t=109453
D-064: DIY: Comptech Swaybar
https://acurazine.com/forums/ramblings-12/avi-movie-help-110867/
https://acurazine.com/forums/showthread.php?t=108602
https://acurazine.com/forums/showthread.php?t=109725
https://acurazine.com/forums/ramblings-12/every-parents-worst-nightmare-115191/
D-070: Official RAYS ENGINEERING/VOLK RACING wheel thread
https://acurazine.com/forums/ramblings-12/pop-up-stoppers-109612/
D-073: Parking brake question, e-brake
D-076: Offset explained
https://acurazine.com/forums/showthread.php?t=109978
D-079: Wheel Alignment
https://acurazine.com/forums/showthread.php?t=114226
D-082: Wheel touch-up paint colors
https://acurazine.com/forums/car-parts-sale-361/stuff-sale-az-131352/
https://acurazine.com/forums/showthread.php?t=135775
D-085: Front and rear Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
https://acurazine.com/forums/religion-politics-18/world-opinion-132940/
D-088: Official Acura A-Spec Wheel Colors and Part Number List
https://acurazine.com/forums/acurazine-clubs-meets-15/san-diego-cl-tl-meet-sunday-may-2nd-138794/
D-091: DIY:Front and rear damper/shock spring replacement
https://acurazine.com/forums/car-parts-sale-361/fm-modulators-group-purchase-173827/ - Service Manual Scans
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/ - w/Pics and including Rear Seat Removal
D-094: DIY:Brembo Brake Pad Replacement + Rear Brake Pad Replacement
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/3g-garage-d-094-brembo-hawk-pad-replacement-w-pics-579140/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/diy-2007-tl-s-brake-pad-replacement-629428/
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-how-replace-brake-pads-acura-tl-s-733637/
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-complete-brake-job-pics-624404/ - Rear Pads as well
D-097: DIY: Painting the Factory Brembo's
https://acurazine.com/forums/3g-tl-2004-2008-93/d-097-diy-painting-factory-brembos-red-white-acura-logo-640092/ - DIY w/pics
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-097-brembo-caliper-color-combos-not-56k-829109/ - DIY & Color Combos
D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/d-100-official-does-wheel-tire-fit-my-car-thread-642526/
D-103: Standard brakes to 6spd/TL-S Brembo Brakes Swap Part List
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-103-tl-s-brembo-swap-parts-list-716463/#post10669446
D-106: DIY: Painting the Rotor Hubs
https://acurazine.com/forums/3g-tl-2004-2008-93/d-106-painting-rotor-hub-diy-726854/
D-109: Lug Nuts/ Wheel Lock Broke Off!
https://acurazine.com/forums/3g-tl-2004-2008-93/d-109-lug-nuts-wheel-lock-broke-off-help-624329/
E. Exterior/Exhaust
E-001: DIY: headlight, front bumper, inner fender,w/wash tank,HID bulb
Note: This is for scans only. If you are looking for some posts on how to do something, search further.
https://acurazine.com/forums/showthread.php?t=127531
E-002: DIY:A-Spec Bodykit Installation
https://acurazine.com/forums/technology-16/bluetooth-car-kit-153237/
https://acurazine.com/forums/ramblings-12/nws-words-happy-new-year-funny-fat-kid-165135/ 07TL front lip with lots of pictures
E-004: DIY: Fixed the bodykit gaps w/ 3M Scotch Heavy Duty foam tape
https://acurazine.com/forums/ramblings-12/strange-times-new-england-84445/
E-005: DIY:Filling in the "ACURA" letters on the front bumper (Front Bumper Paint Job)
https://acurazine.com/forums/3g-tl-2004-2008-93/front-bumper-paint-job-3g-garage-e-005-a-614483/
E-007: Body Side Moulding
https://acurazine.com/forums/showthread.php?t=76675
E-010: Name:  p.gif
Size:  1.0 KB Colors
https://acurazine.com/forums/ramblings-12/bought-fender-74135/
E-013: Colors Codes
https://acurazine.com/forums/showthread.php?t=78596
E-016: DIY: Emblems and badges-removing and replacing
https://acurazine.com/forums/car-parts-sale-361/cl-body-kit-85353/
https://acurazine.com/forums/showthread.php?t=121019 (with scans for locations of emblems)
https://acurazine.com/forums/showthread.php?t=122040 (from 2G TL)
E-019: Door Edge Guard
https://acurazine.com/forums/car-parts-sale-361/fs-hks-exhaust-88947/
E-022: DIY: Driver side door lock MOD
https://acurazine.com/forums/showthread.php?t=82775
https://acurazine.com/forums/audio-video-electronics-navigation-22/quick-question-aftermarket-hu-125597/
E-025: DIY: Gunmetal Emblems
https://acurazine.com/forums/car-parts-sale-361/1998-tl1000r-bike-sale-80744/
E-028: DIY: Where to jack
https://acurazine.com/forums/showthread.php?t=85473
E-031: Plugs for license plate screw holes
https://acurazine.com/forums/showthread.php?t=138710
E-034: DIY:Removing aluminum strip above rear license plate & trunk liner?
https://acurazine.com/forums/showthread.php?t=84489
E-035: DIY:Removing Trunk Liner and Reverse Light Bulbs PHOTOS!
https://acurazine.com/forums/3g-tl-2004-2008-93/e-035-diy-how-remove-trunk-liner-pics-763693/
E-037: Mirror tilt in Reverse
https://acurazine.com/forums/showthread.php?t=83310
https://acurazine.com/forums/ramblings-12/went-shooting-today-79015/
E-043: Outside rear view mirror adjustments for improved rear view visibility
https://acurazine.com/forums/showthread.php?t=83972
E-045: Outside rear view mirror repair and replacement
https://acurazine.com/forums/showthread.php?t=113317
https://acurazine.com/forums/3g-tl-problems-fixes-114/3g-mirror-repair-pictures-3g-garage-e-045-a-832020/
E-046: Rusty Exhaust Tips
https://acurazine.com/forums/ramblings-12/solar-eclipse-pics-large-72202/
https://acurazine.com/forums/showthread.php?t=81614
E-049: How to use Touch-Up Paint
https://acurazine.com/forums/ramblings-12/what-happened-subscribed-thread-search-92488/
E-050: Paint peeling?
https://acurazine.com/forums/showthread.php?t=115658
E-052: Screech at full-lock turn
https://acurazine.com/forums/ramblings-12/new-way-smuggling-95338/
E-055: My grill insert "mod"....pics inside
https://acurazine.com/forums/showthread.php?t=98149
E-061: DIY: Chrome Strip Lower Grille Kit, Queens TL owners...come and see
https://acurazine.com/forums/showthread.php?t=101254
E-064: Blackened Exhaust tips
https://acurazine.com/forums/automotive-news-6/cadillac-xlr-news-%2A%2Aproduction-end-page-3-%2A%2A-100565/
E-067: Front spoiler/Plastic piece underneath front of car keeps scraping
https://acurazine.com/forums/showthread.php?t=102174
https://acurazine.com/forums/showthread.php?t=100938
https://acurazine.com/forums/showthread.php?t=101955
E-070: What's that steel bar doing there behind the bumper? Damper!?
https://acurazine.com/forums/showthread.php?t=102499
E-073: DIY: Bumper Mesh Grille (Instructions and Pics)
https://acurazine.com/forums/ramblings-12/initial-d-102566/
https://acurazine.com/forums/3g-tl-2004-2008-93/e-073-diy-custom-grill-mod-cutting-adding-grill-mesh-lots-pics-748647/ - PHOTOS!
E-076: Knocking Noise- Question
https://acurazine.com/forums/car-talk-5/like-cl-tsx-new-tl-100131/
E-077: Windshield cowl cover removal (under the windshield wipers)
https://acurazine.com/forums/3g-tl-2004-2008-93/e-077-windshield-cowl-cover-removal-under-windshield-wipers-891269/
E-078: Windshield washer fluid tubes/lines and reservoir removal
https://acurazine.com/forums/showthread.php?t=170030
E-079: Front bumper removal, Windshield washer reservoir removal
https://acurazine.com/forums/car-parts-sale-361/fs-stock-99-2-3-cl-parts-108963/
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-how-take-off-front-bumper-3g-garage-e-079-photos-807850/ - with photos
E-082: COMPTECH Exhaust SoundByte (Audio Clip)
https://acurazine.com/forums/audio-video-electronics-navigation-22/power-cap-108753/
E-085: Wind Noise on Driver side
https://acurazine.com/forums/car-parts-sale-361/wtb-1st-gen-cl-rims-109157/
E-088: 2004TL underbody pictures
https://acurazine.com/forums/ramblings-12/wat-files-needed-play-counterstrike-109238/
E-091: Rear Parking Assist (backup sensors)
https://acurazine.com/forums/showthread.php?t=109726
E-094: How do I remove the rear bumper, side sill panels, and tail lights
https://acurazine.com/forums/showthread.php?t=109191
https://acurazine.com/forums/ramblings-12/ahahah-got-ur-ass-beat-128733/
https://acurazine.com/forums/showthread.php?t=160358
E-097: Install Mudguards/splash guards
https://acurazine.com/forums/automotive-news-6/spy-video-audi-rs4-111585/
E-100: Roof Rack?
https://acurazine.com/forums/showthread.php?t=115025
E-103: Front fender removal
https://acurazine.com/forums/showthread.php?t=145806
E-106: DIY HOW TO Pre-Cat Delete DIY
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/e-106-official-pre-cat-delete-how-diy-642953/
E-109: DIY Tail Light Install + Removal of Rear Bumper w/ Aspec Lip kit
https://acurazine.com/forums/3g-tl-2004-2008-93/e-109-07-tail-install-bumper-removal-aspec-lip-609883/
E-112: License Plate Garnish Removal
https://acurazine.com/forums/3g-tl-problems-fixes-114/e-112-license-plate-problem-ideas-needed-708335/
E-115: DIY Installing 07 Blinking Mirrors onto 04-06 TL
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/e-115-07-mirrors-06-fyi-637014/
https://acurazine.com/forums/3g-tl-2004-2008-93/e-115-diy-improved-installing-07-08-mirrors-06-tl-779015/ - New With Photos and VIDEO!
E-118: DIY Removing Double Sided Stick Tape
https://acurazine.com/forums/3g-tl-2004-2008-93/e-118-how-remove-double-sided-tape-w-ease-714513/
E-121: DIY Installing Type-S Rear A-spec Lip onto Earlier Models
https://acurazine.com/forums/3g-tl-2004-2008-93/e-121-diy-installing-type-s-aspec-rear-lip-base-tl-bumper-709992/
E-124: ATLP V2 vs RV6 V2 *pics/comparisons*
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/e-124-atlp-v2-vs-rv6-v2-%2Apics-comparisons%2A-737152/
E-127: DIY Reverse Light Switch (Tailgater Switch)
https://acurazine.com/forums/showthr...6#post11592166
E-130: DIY Oxygen Sensor (O2 Senor/02 Sensor) Replacement
https://acurazine.com/forums/3g-tl-problems-fixes-114/e-130-diy-oxygen-o2-sensor-installation-rear-upstream-f-aka-p2251-811823/ ---> Pictures Inside!
F. Interior/Console/MID/HVAC
F-001: Headliner, vanity/antenna module/XM antenna replacement/front and rear map light/vanity light
https://acurazine.com/forums/showthread.php?t=180141
F-004: Name:  o.gif
Size:  1,019 Bytes Hit the horn hard, now I can see the seam for Airbag Deployment line; Ripped Steering Wheel.
https://acurazine.com/forums/showthread.php?t=96367
F-007: Acura Alarm?
https://acurazine.com/forums/showpost.php?p=914478&postcount=24
F-010: Shut off the Auto A/C
https://acurazine.com/forums/showthread.php?t=94670
F-013: Air bag removal and replacement scans and related scans
https://acurazine.com/forums/ramblings-12/mercedes-153339/
F-016: DIY: Front/rear door panel/handles/wstrip/glass/window regulator removal
https://acurazine.com/forums/car-talk-5/my-car-super-street-143797/
https://acurazine.com/forums/ramblings-12/trance-list-93985/
F-019: Musty smell from A/C
https://acurazine.com/forums/showthread.php?t=87078
https://acurazine.com/forums/audio-video-electronics-navigation-22/diy-crossovers-filters-78151/
https://acurazine.com/forums/showthread.php?t=103735
F-022: A/C during startup?
https://acurazine.com/forums/ramblings-12/kind-animals-you-better-think-twice-86743/
F-025: Name:  i.gif
Size:  1,018 Bytes Autolock feature & Double-lock beep
https://acurazine.com/forums/showthread.php?t=102632
https://acurazine.com/forums/showthread.php?t=79132
https://acurazine.com/forums/showthread.php?t=85147
F-028: Heads Up Display (HUD)?
https://acurazine.com/forums/ramblings-12/im-nervous-91328/
F-031: Instrument Lighting Defaults to Maximum?
https://acurazine.com/forums/showthread.php?t=78585
F-034: Name:  i.gif
Size:  1,018 Bytes Oil Life reset
https://acurazine.com/forums/ramblings-12/when-you-mods-close-advertising-threads-91245/
https://acurazine.com/forums/audio-video-electronics-navigation-22/subwoofer-help-90084/
F-040: DIY: Rattle Fix - Upper Door / Window Trim
https://acurazine.com/forums/acurazine-clubs-meets-15/belated-photos-la-meet-84527/
F-041: DIY: I finally got rid of the b-pillar rattle...
https://acurazine.com/forums/showthread.php?t=130207
F-043: DIY: Rattle Fix - Glove Compartment
https://acurazine.com/forums/showthread.php?t=83788
https://acurazine.com/forums/car-parts-sale-361/2001-tails-86178/
https://acurazine.com/forums/acurazine-clubs-meets-15/internation-auto-salon-4-26-2003-los-angeles-conv-center-101293/
F-044: DIY: Passenger Seat Rattle Clicking FIXED
https://acurazine.com/forums/audio-video-electronics-navigation-22/infinity-perfect-6-1-does-not-fit-125087/
F-046: DIY: 3rd Braking Light Cover Removal
https://acurazine.com/forums/showthread.php?t=102009
F-049: DIY: Fallen Headliner
https://acurazine.com/forums/car-parts-sale-361/f-s-racing-seats-w-adjustable-rails-83756/
https://acurazine.com/forums/showthread.php?t=79379
https://acurazine.com/forums/showthread.php?t=733555
F-052: DIY: how to remove the center dash and the 2 aluminum strips in the center console
https://acurazine.com/forums/showthread.php?t=90964
and here's another thread that's already in the garage (A-086) but will help here
F-055: Cup Holder
https://acurazine.com/forums/showthread.php?t=93165
F-058: Removing the center storage bins
https://acurazine.com/forums/ramblings-12/have-you-guys-played-cnn-3d-model-aircrafts-100036/
F-061: Name:  o.gif
Size:  1,019 Bytes Miles to Empty, Low Fuel Warning, and Fuel Tank Capacity
https://acurazine.com/forums/showthread.php?t=84730
https://acurazine.com/forums/acurazine-clubs-meets-15/location-ideas-next-large-northeast-meet-71425/
https://acurazine.com/forums/ramblings-12/made-switch-86945/
https://acurazine.com/forums/showthread.php?t=107341
F-064: Overhead Console Removal
https://acurazine.com/forums/ramblings-12/wonder-where-our-tax-money-go-89551/
F-067: DIY: Remove the front seat
https://acurazine.com/forums/ramblings-12/anyone-going-vegas-howard-stern-show-130390/
F-068: Driver and passenger seat wiring diagram for 3g TL
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/driver-passenger-seat-wiring-diagram-3g-tl-3g-garage-f-068-a-757435/
F-070: DIY: How to remove the back seats to put the suspension?
https://acurazine.com/forums/showthread.php?t=107568
F-073: Name:  o.gif
Size:  1,019 Bytes *** Seatbelt warning cannot be disabled ***
https://acurazine.com/forums/showthread.php?t=91391
F-076: Solar Sensing Climate Control in Navi
https://acurazine.com/forums/showthread.php?t=67377
https://acurazine.com/forums/car-parts-sale-361/headers-4-sale-77634/
F-079: DIY: Fix for center speaker rattle and scans for removal of all speakers
https://acurazine.com/forums/showthread.php?t=82055
https://acurazine.com/forums/showthread.php?t=124360
https://acurazine.com/forums/ramblings-12/word-origin-110412/
https://acurazine.com/forums/ramblings-12/1st-legit-pic-anakin-episode-3-a-114465/
F-082: Warm Steering Wheel
https://acurazine.com/forums/ramblings-12/100-bucks-joke-85937/
F-085: Name:  i.gif
Size:  1,018 Bytes Acura info on Temp Sensor Logic + Calibration
https://acurazine.com/forums/ramblings-12/i-just-got-transformers-67481/
F-088: Name:  q.gif
Size:  1.0 KB Has anyone had the Outside Temp Display go flatline? Maximum temp: 115
https://acurazine.com/forums/audio-video-electronics-navigation-22/recommended-power-tap-source-trunk-92288/
F-094: Wood Interior
https://acurazine.com/forums/showthread.php?t=79862
https://acurazine.com/forums/showthread.php?t=80508
F-097: Leather
https://acurazine.com/forums/showthread.php?t=94387
F-100: Speaking of leather replacement.. Also need advice re: damage caused by dealer (Pict)
https://acurazine.com/forums/showthread.php?t=99198
F-103: Visor area rattle (removal of SunVisor, map light console, front/rear map light)
https://acurazine.com/forums/showthread.php?t=100981
F-106: Headlight Chime Mute
https://acurazine.com/forums/car-talk-5/weres-04-tl-99484/
F-109: Acura All Weather Mats 2004/2005TL
https://acurazine.com/forums/showthread.php?t=102228
F-112: Aluminum pedals
https://acurazine.com/forums/showthread.php?t=134884
https://acurazine.com/forums/showthread.php?t=102590
F-113: DIY: DIY: Aluminum custom pedal install
https://acurazine.com/forums/showthread.php?t=148768
F-115: coin holder
https://acurazine.com/forums/showthread.php?t=92756
F-118: Can I remove the pass-through?
https://acurazine.com/forums/showthread.php?t=103558
F-121: Rattles located and fix's. LOOK
https://acurazine.com/forums/showthread.php?t=103822
F-124: Review view mirror "auto" setting (Auto-Dimming rearview mirror)
https://acurazine.com/forums/showthread.php?t=99624
F-127: Body Seal leaking makes interior WET
https://acurazine.com/forums/car-parts-sale-361/fs-eibach-prokit-spring-106084/
F-129: DIY: Replacing Engine Air Filter
https://acurazine.com/forums/3g-tl-2004-2008-93/air-filter-replacement-3g-garage-f-129-a-571611/
https://acurazine.com/forums/3g-tl-2004-2008-93/f-129-diy-2008-tl-engine-air-filter-replacement-pics-745216/ - detailed photos!
F-130: DIY: Replacing Cabin Air Dust & Pollen Filter
https://acurazine.com/forums/showthread.php?t=87494
https://acurazine.com/forums/ramblings-12/firewall-help-123884/ Good pictures here
https://acurazine.com/forums/showthread.php?t=131831 Replace the filter without removing the entire glove box
https://acurazine.com/forums/3g-tl-2004-2008-93/f-130-diy-2008-tl-cabin-air-filter-replacement-pics-745341/ Good detailed photos's
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-cabin-filter-replacement-3g-garage-f-130-a-822307/ - With Pics
F-133: DIY: 05 TL left tweeter rattle solved
https://acurazine.com/forums/showthread.php?t=108367
F-136: Inner fender removal
https://acurazine.com/forums/showthread.php?t=108963
F-139: Name:  o.gif
Size:  1,019 Bytes Need help isolating rattle
https://acurazine.com/forums/showthread.php?t=109846
F-142: Hand brake cover staples, Cheap e brake boot
https://acurazine.com/forums/ramblings-12/american-wedding-110002/
F-145: Zeroed Out Mileage
https://acurazine.com/forums/ramblings-12/say-happy-birthday-86495/
F-148: Rattle from left heater vent
https://acurazine.com/forums/ramblings-12/dajuice27-hows-back-110355/
F-151: To make the rear seats fold down? Pass-through
https://acurazine.com/forums/moderators-only-20/avatars-111700/
F-154: Sunroof area vibration? (rubber strip/felt seal)
https://acurazine.com/forums/showthread.php?t=111728
F-157: How to reset the MID and Does resetting the MID in the middle of the Oil Cycle reset other services?
https://acurazine.com/forums/showthread.php?t=90084
F-160: Steering wheel switches (cruise and radio) and air bag removal
https://acurazine.com/forums/showthread.php?t=146748
F-163: Steering wheel removal, cable reel replacement, air bag removal
https://acurazine.com/forums/showthread.php?t=153341
F-167: DIY: Heater /Water/ Coolant Control Valve Replacement
https://acurazine.com/forums/3g-tl-2004-2008-93/f-167-heater-water-coolant-control-valve-diy-747304/#post11381436
F-170: DIY: 3M Di-Noc Carbon Fiber Trim
https://acurazine.com/forums/3g-tl-2004-2008-93/f-170-diy-3m-di-noc-carbon-fiber-grille-interior-diy-page-4-a-765483/
F-173: DIY: REAR seat heaters INSTALLED
https://acurazine.com/forums/3g-tl-2004-2008-93/f-173-rear-seat-heaters-installed-632415/
F-176: DIY: Interior Door Lock Mod (Cut Lock Button)
https://acurazine.com/forums/3g-tl-2004-2008-93/f-176-new-mod-door-lock-button-586146/
F-179: DIY: Passenger Door Lock Actuator Replacement
https://acurazine.com/forums/3g-tl-problems-fixes-114/f-179-diy-pass-door-lock-actuator-replacement-w-pics-764241/ ---> Pictures Inside!
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
Last edited by thoiboi; 06-08-2017 at 08:38 AM. Reason: Added Gear Position Sensor/ Transmission Range Switch to Garage
rets is offline
The following 8 users liked this post by rets:
4drviper (09-12-2011), AyFeltaTL (06-26-2012), mdburbank (05-10-2014), nchein (01-26-2015), RaViaTonga (06-22-2013), silvrbreez (01-23-2013), stackitt (08-26-2015), tlsslt (05-09-2013) and 3 others liked this post. (Show less...)
Old 03-17-2005, 04:47 PM
Moderator Alumnus
rets's Avatar
Exclamation 10k...
Continued...
G. Lighting
G-001: DIY: headlight, front bumper, inner fender,w/wash tank,HID bulb
https://acurazine.com/forums/third-g...-001-a-587181/
G-004: Removal of HID bulbs
https://acurazine.com/forums/third-g...-004-a-598853/
G-007: Name:  i.gif
Size:  1,018 Bytes Headlight Adjustment
https://acurazine.com/forums/third-g...-007-a-558380/
G-010: Do you need to replace Xenon headlights?
https://acurazine.com/forums/third-g...lights-551065/
G-013: Name:  i.gif
Size:  1,018 Bytes HID BULB 10000k (Violet Purple) vs 4300k (White)
https://acurazine.com/forums/third-g...e-tint-557563/
G-019: DIY: Complimentary Door/Dome Blue Light Mod
https://acurazine.com/forums/third-g...-019-a-562093/
G-028: new fog light bulbs
https://acurazine.com/forums/third-g...-bulbs-563216/
G-029: DIY: Making fog lights come on independent of HID's
04-06: https://acurazine.com/forums/third-g...switch-772633/
07-08: https://acurazine.com/forums/third-g...ht-mod-845798/
07-08 for HID Fogs: https://acurazine.com/forums/third-g...switch-798978/
G-031: DIY: So you want lower grill valance fog lights on your TL huh? <PICS>
https://acurazine.com/forums/third-g...-031-a-563090/
G-031: DIY: DIY Accord foglight mod without removing A-Spec and bumper
https://acurazine.com/forums/third-g...bumper-717204/
G-031: DIY: Accord Fogs with Type-S Grills on 04-06 TL
https://acurazine.com/forums/third-generation-tl-2004-2008-93/g-031-%5Bdiy%5D-accord-fogs-type-s-grills-04-06-tl-817615/
G-040: LED signal taillight
https://acurazine.com/forums/showthread.php?t=94990
G-043: DIY: Side Marker can blink
https://acurazine.com/forums/3g-tl-2004-2008-93/g-043-blinking-sidemarker-diy-guide-suitable-3g-garage-703668/
G-046: DIY: Clearing Headlight
https://acurazine.com/forums/third-g...e-g046-589746/
https://acurazine.com/forums/third-g...-046-a-597188/
https://acurazine.com/forums/third-g...lights-571162/
G-049: Back up lights too dim!
https://acurazine.com/forums/third-g...oo-dim-566283/
G-052: DIY: Replacing License Plate and backup light Bulbs
https://acurazine.com/forums/third-g...-052-a-584870/
G-055: Headlight and HID bulb replacement
G-058: Removing center console bulb and license plate bulbs
https://acurazine.com/forums/third-g...-bulbs-566648/
G-061: How do I remove the front turn signal and side marker lamps?
https://acurazine.com/forums/showthread.php?t=110182
G-064: DIY: Modifying Front Side Marker Lights
https://acurazine.com/forums/third-g...-064-a-572135/
G-067: DIY: DIY installation of Daytime running lights***with detailed pictures***
https://acurazine.com/forums/third-g...-067-a-596398/
G-070: DIY: White Cold Cathode License Plate How-TO!!!!
https://acurazine.com/forums/third-g...-070-a-605201/
G-073: How to remove front and rear side marker (sidemarker) lights
https://acurazine.com/forums/third-generation-tl-2004-2008-93/how-remove-rear-side-markers-3g-garage-g-073-a-624808/
G-076: The definitive LED thread: all you'll ever need to know about LED's
https://acurazine.com/forums/third-generation-tl-2004-2008-93/definitive-led-thread-all-youll-ever-need-know-about-leds-3g-garage-g-076-a-633045/
G-077: 3G Acura TL bulb sizes list
https://acurazine.com/forums/third-g...-077-a-691135/
G-079: DIY: How to Install LED resistors (lots of pictures)
https://acurazine.com/forums/third-generation-tl-2004-2008-93/how-install-led-resistors-lots-pictures-3g-garage-g-079-a-637923/
G-082: DIY:Name:  o.gif
Size:  1,019 Bytes Yellow Fog Light Mod (2007-2007 Factory lower grille fogs)
https://acurazine.com/forums/third-g...od-diy-643146/
G-085: DIY: Restoring Hazed/Cloudy Headlights
https://acurazine.com/forums/third-g...lights-710313/
G-088: DIY: Clearing Your Taillights
https://acurazine.com/forums/third-g...lights-618762/
https://acurazine.com/forums/third-g...ht-mod-734158/
G-091: HID D2C, D2S and D2R bulbs explained
https://acurazine.com/forums/third-g...c-bulb-710926/
G-094: DIY: Tail light Removal (Type-S swap DIY)
https://acurazine.com/forums/third-generation-tl-2004-2008-93/g-094-diy-installing-type-s-tail-lights-716996/
G-097: DIY: 3rd Brake Light not working
https://acurazine.com/forums/3g-tl-problems-fixes-114/g-097-2004-need-help-acura-tl-3rd-brake-light-doesnt-work-716677/
G-100: DIY: LED Lighting For your TL!
https://acurazine.com/forums/third-g...gs-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/third-g...onsole-746609/ - Part 1 Map Light Console
https://acurazine.com/forums/third-g...e-leds-746947/ - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/third-g...odules-763640/ - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/third-g...-vents-747870/ - Part 4 Center Vents
https://acurazine.com/forums/third-g...-bunch-747874/ - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/third-g...le-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/third-g...le-led-750671/ - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/third-g...or-etc-750880/ - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/third-g...itches-755070/ - Part 9: Heated Seat Switches
https://acurazine.com/forums/third-g...nation-755388/ - Part 10: Cupholder Illumination!
G-103: DIY: HID's in Reverse Lights
https://acurazine.com/forums/third-generation-tl-2004-2008-93/g-103-diy-hids-reverse-lights-766410/​​​​​​​
G-106: Turn DRL's Off While Idling?
https://acurazine.com/forums/third-g...t-tl-s-787219/
G-109: DIY: Eliminate LED bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
https://acurazine.com/forums/third-g...istors-815219/
H. Car Care/Clear-bra
H-004: Bird Crap
https://acurazine.com/forums/showthread.php?t=93421
H-007: Getting Clear-bra
https://acurazine.com/forums/showthread.php?t=86629
H-010: Gasoline & Paint
https://acurazine.com/forums/showthread.php?t=90274
H-013: DIY: Wax & Claybar
https://acurazine.com/forums/showthread.php?t=76259
H-016: DIY: Zaino & Non-Zaino
https://acurazine.com/forums/wash-wax-23/how-zaino-detail-process-247622/
https://acurazine.com/forums/showthread.php?t=74255
H-019: Cold Weather Car Wash suggestions
https://acurazine.com/forums/ramblings-12/help-garage-door-repair-108379/
H-022: Brands of cleaning/maintenance products
https://acurazine.com/forums/third-g...oducts-573174/
I. Audio/Electronics/Navi/Bluetooth/iPod/MP3/Alarm/Radar
I-001: DVD Disc reading error-Try cleaning the disc
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/dvd-disc-reading-error-3g-garage-i-001-a-690561/
I-004: Navi Display Wires
https://acurazine.com/forums/showthread.php?t=98492
I-007: DIY: AV Electronic Install Guide w/ Audio Install Guide
https://acurazine.com/forums/showthread.php?t=97123
I-010: DIY: An alternative to AV Electronics
https://acurazine.com/forums/showthread.php?t=95309
I-013: DIY: My CarPuter Install on a non-navi
https://acurazine.com/forums/showthread.php?t=99102
I-016: Name:  i.gif
Size:  1,018 Bytes 3G TL Bluetooth Phone Compatibility
https://acurazine.com/forums/showthread.php?t=89299
I-019: DIY: Escort 8500 & Smartcard Mounting
https://acurazine.com/forums/car-parts-sale-361/sale-1999-honda-civic-type-r-japan-76187/
I-022: DIY: Stealth Escort 8500
https://acurazine.com/forums/ramblings-12/any-one-heard-new-craig-david-84529/
https://acurazine.com/forums/car-parts-sale-361/wtb-acura-type-s-rims-asap-93502/
I-025: DIY: Radar Hardwire Install
https://acurazine.com/forums/4g-tl-a...l-pics-936750/
I-028: DIY: V1 Hardware Install into Gauge
https://acurazine.com/forums/showthread.php?t=106799
https://acurazine.com/forums/showthread.php?t=111792
I-031: DIY: Power wires
https://acurazine.com/forums/car-talk-5/what-great-year-end-price-tl-s-need-help-asap-89682/
I-034: DIY: V1 remote display installation
https://acurazine.com/forums/third-g...isplay-541856/
I-037: DIY: Valentine 1 Hardwire, remote display + Extra Mute button install
https://acurazine.com/forums/showthread.php?t=99523
I-038: DIY: Viper 5901 with Remote Start install
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/very-detailed-install-viper-5901-remote-start-706816/
I-040: DVD-A lists
https://acurazine.com/forums/showthread.php?t=87311
I-043: DVD-A additional tracks
https://acurazine.com/forums/showthread.php?t=109125
I-046: Buy DVD-A
https://acurazine.com/forums/showthread.php?t=75725
https://acurazine.com/forums/showthread.php?t=83369
I-049: How do you get HomeLink to work?
https://acurazine.com/forums/showthread.php?t=106070
https://acurazine.com/forums/showthread.php?t=80367
https://acurazine.com/forums/ramblings-12/omega-james-bond-watch-question-80659/
https://acurazine.com/forums/showthread.php?t=119425
I-052: Improve your ELS system
https://acurazine.com/forums/showthread.php?t=67912
https://acurazine.com/forums/moderators-only-20/alright-ive-calmed-down-69528/
I-055: THE definitive iPod thread
https://acurazine.com/forums/audio-video-electronics-navigation-22/stock-system-hum-buzz-116290/
https://acurazine.com/forums/ramblings-12/website-online-music-77951/
https://acurazine.com/forums/showthread.php?t=84962
https://acurazine.com/forums/ramblings-12/weird-chevy-sold-japan-87388/
I-058: iPOD Integration - Peripheral Unit/s
https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/showthread.php?t=698771&quot;&quot;&quot;&quot;&qu ot;&quot;]https://acurazine.com/forums/showthread.php?t=698771 - For TL's With NAV-TRAFFIC[/url]
https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/showthread.php?t=697728&quot;&quot;&quot;&quot;&qu ot;&quot;]https://acurazine.com/forums/showthread.php?t=697728 - For TL's Without NAV-TRAFFIC[/url]
I-059: DIY: Integrated my MP3 player to my 2004 TL: pics inside
https://acurazine.com/forums/ramblings-12/girlfriend-broke-up-me-110413/
https://acurazine.com/forums/ramblings-12/best-advice-needing-run-home-theater-sub-woofer-cable-112654/
I-061: LoJack
https://acurazine.com/forums/showthread.php?t=82023
I-064: MP3 do play in TL?
https://acurazine.com/forums/showthread.php?t=84519
I-067: DIY: Installation of AVelectronic unit and DVD player
http://acura-tl.com/forums/showthread.php?t=94981
I-070: Bummer! Back-up DVD navi disc doesn't work
https://acurazine.com/forums/ramblings-12/who-has-allergies-101921/
I-073: Disc - Disc + buttons
https://acurazine.com/forums/ramblings-12/new-look-forum-87384/
I-076: Navi color options, Navi setup screen 3
https://acurazine.com/forums/showthread.php?t=92172
I-079: Navi falling behind?
https://acurazine.com/forums/showthread.php?t=84486
I-082: Quick guide for Voice/Navi commands
https://acurazine.com/forums/car-parts-sale-361/wanted-cl-tl-type-s-rims-tires-76813/
https://acurazine.com/forums/ramblings-12/vote-most-worthless-member-here-95671/
I-085: PHONE displays on my dash every time I get into the car!
https://acurazine.com/forums/ramblings-12/more-hot-pics-tsx-91189/
I-088: Two of phones work OK in TL?
https://acurazine.com/forums/showthread.php?t=86979
I-091: Radio Code
https://acurazine.com/forums/showthread.php?t=83025
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/radio-code-solution-here-3g-garage-i-091-a-469527/
I-094: Remote Starter
https://acurazine.com/forums/showthread.php?t=78031
I-097: DIY: Window roll up module install instructions and pictures
https://acurazine.com/forums/third-g...-097-a-596643/
I-103: From XM to Sirius?
https://acurazine.com/forums/showthread.php?t=99135
https://acurazine.com/forums/showthread.php?t=82059
https://acurazine.com/forums/ramblings-12/whats-up-sopranos-114901/
I-106: DIY: Escort Passport Laser Jammer Install ZR3 Instructions
https://acurazine.com/forums/car-parts-sale-361/f-s-alpine-7894-had-month-105764/
I-109: Horrible "popping" noise from CD; DTS CD
https://acurazine.com/forums/showthread.php?t=106790
I-112: Aftermarket navi solution
https://acurazine.com/forums/religion-politics-18/oh-what-tangled-web-silver-killer-weaves-104276/
I-124: Doing remote starter install myself -- need wiring manual
https://acurazine.com/forums/car-parts-sale-361/fs-19-axis-hagens-pics-101401/
I-127: DIY: DVD/Audio upgrade
https://acurazine.com/forums/acurazine-clubs-meets-15/orlando-saturday-aug-9th-110349/
I-130: No DSP Mode Button on Canadian TLs
https://acurazine.com/forums/religion-politics-18/%91chemical-ali%92-captured-iraq-111772/
I-133: Name:  o.gif
Size:  1,019 Bytes Phone In-Use lock up/HFL is in use constantly. Cannot disengage!
https://acurazine.com/forums/showthread.php?t=111854
https://acurazine.com/forums/ramblings-12/avatar-72564/
I-136: Nav Module installed!!! (With Video and Pics)
https://acurazine.com/forums/showthread.php?t=108869
I-139: DIY:Name:  o.gif
Size:  1,019 Bytes Modify your navigation system
https://acurazine.com/forums/automotive-news-6/s4-cabriolet-112677/
https://acurazine.com/forums/showthread.php?t=21434
I-142: DIY:Name:  o.gif
Size:  1,019 Bytes Completed TL non-navi to navi conversion
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/im-soo-excited-just-completed-my-non-navi-navi-conversion-diy-included-747456/ Added 10/14/2009 More scans and photos
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-142-yet-another-non-navi-navi-conversion-success-story-640304/ --- detailed photos and guides, RECENT!
https://acurazine.com/forums/wash-wax-23/zaino-zfx-humidity-112822/
https://acurazine.com/forums/religion-politics-18/israel-had-plot-kill-saddam-hussein-124638/
I-145: Burn CD issue - The real cause
https://acurazine.com/forums/showthread.php?t=103641
I-148: DVD+R or DVD-R
https://acurazine.com/forums/showthread.php?t=114095
I-151: How to charge your cell phone battery while the car is off
https://acurazine.com/forums/showthread.php?t=125938
I-154: DIY:Name:  o.gif
Size:  1,019 Bytes Rear camera installed... (lotsa pics)
https://acurazine.com/forums/showthread.php?t=132654
I-157: DIY:Name:  o.gif
Size:  1,019 Bytes Dom's Pnp W/ Pictures!!!
https://acurazine.com/forums/ramblings-12/predators-red-wings-137415/
I-160: DIY:Name:  o.gif
Size:  1,019 Bytes Intalling the USA-SPEC HON2Y Ipod/Aux adapter
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-160-usa-spec-install-633080/
I-163: Aftermarket Sub Issues, Sub constantly on, TL-S - PROBLEM SOLVED
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-163-amp-sub-installed-08-tl-s-amp-not-getting-signal-when-doors-shut-700991/
I-166: Weak Signal Range, Keyless Entry
https://acurazine.com/forums/3g-tl-problems-fixes-114/i-166-weak-signal-range-keyless-entry-712615/
I-169: DIY: Install 6" Headrest Monitors
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-169-diy-install-6-headrest-monitors-792793/
J. TSB/Manual/Safety
J-001: Name:  o.gif
Size:  1,019 Bytes Owner's Manuals-All Acuras and Hondas since 1990
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
It looks like Acura has changed this to a subscription service, so if the link doesn't work for you, https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;https://acurazine.com/forums/&quot;http://owners.acura.com/&quot;&quot;&quot;&quot;&quot;] Click here [/url] and you can register your car (if not already done) and download your owner's manual.
Alternate Link to 3G TL Owners Manuals: https://acurazine.com/forums/3g-tl-2004-2008-93/j-020-3g-acura-tl-owners-manual-navi-manual-warranty-booklet-pdfs-851625/
J-004: Name:  o.gif
Size:  1,019 Bytes LSD, ABS, EBD, VSA, TCS...
https://acurazine.com/forums/showthread.php?t=90263
J-007: LATCH (Lower Anchors And Tethers For Children)
TL and baby (car) seat
https://acurazine.com/forums/ramblings-12/ne1-know-when-updated-nav-disk-come-out-83594/
https://acurazine.com/forums/car-parts-sale-361/wtb-02-03-cl-type-s-exhaust-mufflers-89828/
J-010: Released Data on Rollover Risk
https://acurazine.com/forums/showthread.php?t=90021
https://acurazine.com/forums/ramblings-12/everyone-safe-tonight-90059/
J-013: Safest Acura ever?
http://www.safercar.gov/
http://www.nhtsa.dot.gov/NCAP/Cars/2004Full.html
http://www.iihs.org/vehicle_ratings/ce/html/0404.htm
http://www.iihs.org/vehicle_ratings/...ide/s0410.htm#
https://acurazine.com/forums/showthread.php?t=77205
https://acurazine.com/forums/ramblings-12/anyone-have-motorola-v60-cell-83394/
https://acurazine.com/forums/showthread.php?t=101361
J-016: Name:  i.gif
Size:  1,018 Bytes TSB
J-019: Service Manual
https://acurazine.com/forums/showthread.php?t=88615
https://acurazine.com/forums/showthread.php?t=82175
https://acurazine.com/forums/showthread.php?t=85233
J-020: 3G TL Owners Manual, Navi Manuals & Warranty Booklet Links
https://acurazine.com/forums/showthread.php?t=851625
J-022: TL owners packet/leather binder
https://acurazine.com/forums/car-parts-sale-361/wanted-tuner-style-lugs-104327/
K. Window/Tints/Trunk
K-001: Legal Tint Limits and Information
https://acurazine.com/forums/showthread.php?t=164732
K-004: Name:  q.gif
Size:  1.0 KB Loud noise with back windows open
https://acurazine.com/forums/showthread.php?t=89849
K-007: Closing doors w/windows half way down Rattle?
https://acurazine.com/forums/showthread.php?t=81266
K-010: Leaking Photons?
https://acurazine.com/forums/showthread.php?t=88941
K-012: DIY: DIY Moleskin install step-by-step with pics
https://acurazine.com/forums/ramblings-12/how-set-up-transactional-web-sites-139437/
K-013: Name:  i.gif
Size:  1,018 Bytes Window tinting-Moleskin/felt-Information and Installation Instructions
https://acurazine.com/forums/car-parts-sale-361/nokia-5100-6100-series-access-88957/
https://acurazine.com/forums/showthread.php?t=90330
https://acurazine.com/forums/showthread.php?t=109439
https://acurazine.com/forums/wash-wax-23/black-fade-112578/
K-016: Wiper Blade Replacements
https://acurazine.com/forums/showthread.php?t=93447
https://acurazine.com/forums/showthread.php?t=109241
Best windshield wipers ever?
https://acurazine.com/forums/ramblings-12/sweet-imma-start-making-some-money-107997/
K-019: Rating of Factory Window Tint (OEM)
https://acurazine.com/forums/showthread.php?t=82005
K-025: Front Windows Stop Automatically
https://acurazine.com/forums/showthread.php?t=107838
K-028: DIY: Metal clicking noise in the trunk area
https://acurazine.com/forums/ramblings-12/just-wanted-say-87531/
K-031: Deck Lid Spoiler Install/Trunk Lid Spring Question
https://acurazine.com/forums/showthread.php?t=107914
K-034: Scratch on my windshield; hit; chip
https://acurazine.com/forums/motorsports-news-7/zanardi-may-drive-germany-102240/
https://acurazine.com/forums/showthread.php?t=108372
https://acurazine.com/forums/showthread.php?t=109158
K-040: Windshield fluid - frozen, fuse?
https://acurazine.com/forums/car-parts-sale-361/fs-hp-ze1250-laptop-1-6ghz-amd-107775/
K-043: Windshield fluid sprays too high
https://acurazine.com/forums/ramblings-12/couple-new-movie-trailers-109274/
K-046: Windows and alarm have minds of their own; roll down?
https://acurazine.com/forums/car-parts-sale-361/wts-advan-model-5-18x8-107971/
https://acurazine.com/forums/showthread.php?t=110083
K-049: CRACKED WINDSHIELD - OEM REPLACEMENT w/o ACURA LOGO
https://acurazine.com/forums/3g-tl-2004-2008-93/k-049-cracked-windshield-oem-replacement-w-o-acura-logo-817643/
L. Miscellaneous
L-001: Have you found any New Features??
https://acurazine.com/forums/showthread.php?t=73974
https://acurazine.com/forums/3g-tl-2004-2008-93/have-you-found-any-new-features-summary-post-1-3g-garage-l-001-a-540216/ - Summary in Post #1
L-007: Name:  i.gif
Size:  1,018 Bytes How to post your favorite pics & Avatar???
https://acurazine.com/forums/showthread.php?t=90613
L-010: What inspections before delivery of TL?
https://acurazine.com/forums/showthread.php?t=99246
L-013: Advice with Dealers/Sales
https://acurazine.com/forums/showthread.php?t=94221
L-016: Name:  q.gif
Size:  1.0 KB Will the dealer really allow you to order "any" color combo?
https://acurazine.com/forums/showthread.php?t=101311
L-019: 04TL System/Component Charts
http://www.acuraparts247.com/sunnyside/jsp/catlistallcomp.jsp?inputstate=3&catcgry1=TL&catcgr y2=2004&catcgry3=4DR+TL&catcgry4=LM&catcgry5=PEDAL &ListAll=All
L-022: Acura Build Sheet
https://acurazine.com/forums/showthread.php?t=94018
L-025: Blind Spots??
L-028: Name:  q.gif
Size:  1.0 KB Black box??
https://acurazine.com/forums/showthread.php?t=78651
https://acurazine.com/forums/showthread.php?t=83664
https://acurazine.com/forums/ramblings-12/there-anyone-here-can-host-video-101067/
L-031: Name:  i.gif
Size:  1,018 Bytes Free Image Uploader
http://photobucket.com/
http://www.imageshack.us/
http://www.freepgs.com/bruno/
L-034: What age are TL drivers?
https://acurazine.com/forums/showthread.php?t=74215
L-037: How long after the build date did it take you to get your TL?
https://acurazine.com/forums/ramblings-12/dont-you-hate-40-year-old-toughguys-84853/
L-040: Name:  i.gif
Size:  1,018 Bytes Cargo Net
https://acurazine.com/forums/showthread.php?t=65547
L-043: DIY: Horn Confirmation for locks
https://acurazine.com/forums/wash-wax-23/buying-brand-new-state-art-detail-shop-need-ideas-82841/
L-046: Price Paid
https://acurazine.com/forums/car-parts-sale-361/brand-new-venom-400-box-never-used-cheap-72321/
https://acurazine.com/forums/showthread.php?t=102604
L-049: MSRP vs. Invoice
https://acurazine.com/forums/showthread.php?t=90128
L-052: Extended Warranty
https://acurazine.com/forums/showthread.php?t=96414
https://acurazine.com/forums/showthread.php?t=67503
https://acurazine.com/forums/showthread.php?t=71087
https://acurazine.com/forums/car-parts-sale-361/1-97-99-16-chrome-wheel-66619/
https://acurazine.com/forums/showthread.php?t=70021
https://acurazine.com/forums/showthread.php?t=81382
L-055: E-Zpass
https://acurazine.com/forums/ramblings-12/proof-girls-evil-77347/
https://acurazine.com/forums/car-parts-sale-361/aem-intake-83102/
https://acurazine.com/forums/showthread.php?t=93648
L-058: Essence of Key fob & remote
https://acurazine.com/forums/ramblings-12/spiderman-dvd-85181/
https://acurazine.com/forums/ramblings-12/new-movie-trailers-daredevil-etc-85509/
L-061: What is your occupation/how do you afford the TL?
https://acurazine.com/forums/3g-tl-2004-2008-93/what-your-occupation-how-do-you-afford-3g-tl-merged-threads-587211/
L-067: Surprised by AAA guy on our TL's security!
https://acurazine.com/forums/showthread.php?t=108946
L-070: Has anyone bought out a lease?
https://acurazine.com/forums/ramblings-12/anyone-see-packer-game-88709/
L-073: Name:  i.gif
Size:  1,018 Bytes Comprehensive List of 2004 TL Reviews
https://acurazine.com/forums/wash-wax-23/do-i-have-start-scratch-again-73970/
L-076: Special Photos
https://acurazine.com/forums/ramblings-12/prostitute-oranges-85626/
L-079: Programming the remote transmitter/keyfob
https://acurazine.com/forums/third-g...-079-a-556315/
L-082: Significant drop in resale price?
https://acurazine.com/forums/showpost.php?p=867245&postcount=5
https://acurazine.com/forums/showthread.php?t=87033
https://acurazine.com/forums/showthread.php?t=97700
L-085: What does the "TL" stand for?
https://acurazine.com/forums/ramblings-12/hey-chicago-phoenix-atlanta-crews-91212/
L-088: What is VIN?
https://acurazine.com/forums/showthread.php?t=87908
L-091: How to Decipher VIN
https://acurazine.com/forums/showthread.php?t=67654
https://acurazine.com/forums/showthread.php?t=131067
L-094: The Black TL on the top frame
https://acurazine.com/forums/showthread.php?t=91914
L-097: Brushed or Satin? Anti-Slip or Not?
https://acurazine.com/forums/showthread.php?t=103471
L-100: Acura TLC services
https://acurazine.com/forums/ramblings-12/balla-without-dolla-rich-famous-92318/
L-103: Who's parking their TL in Winter?
https://acurazine.com/forums/car-parts-sale-361/f-s-2001-acura-cl-s-only-16k-miles-%2423-299-a-96469/
L-106: Name:  i.gif
Size:  1,018 Bytes SH-AWD
https://acurazine.com/forums/ramblings-12/i%92m-getting-hammered-klez-virus-attempts-90126/
L-109: What happen to society?
https://acurazine.com/forums/ramblings-12/anyone-feel-earthquake-67213/
L-112: Name:  o.gif
Size:  1,019 Bytes The RR Journals
https://acurazine.com/forums/search.php?query=The+RR+Journals&searchuser=Road+R age&exactname=1&starteronly=1&forumchoice=0&childf orums=1&titleonly=1&showposts=0&searchdate=0&befor eafter=after&sortby=lastpost&sortorder=descending& replyless=0&replylimit=0&searchthread=0&searchthre adid=0&saveprefs=1
https://acurazine.com/forums/car-talk-5/tl-cl-video-105573/
L-115: Name:  p.gif
Size:  1.0 KB The Jerky POLLs
https://acurazine.com/forums/search.php?query=Poll&searchuser=jerky&exactname=1 &starteronly=1&forumchoice=0&childforums=1&titleon ly=0&showposts=0&searchdate=0&beforeafter=after&so rtby=lastpost&sortorder=descending&replyless=0&rep lylimit=0&searchthread=0&searchthreadid=0&savepref s=1
https://acurazine.com/forums/search.php?query=poll&searchuser=jerky&exactname=1 &starteronly=1&forumchoice=0&childforums=1&titleon ly=0&showposts=0&searchdate=0&beforeafter=after&so rtby=lastpost&sortorder=descending&replyless=0&rep lylimit=0&searchthread=0&searchthreadid=0&savepref s=1
https://acurazine.com/forums/ramblings-12/view-all-jerky-polls-masters-collection-272492/
L-118: List of Acura Dealers
https://acurazine.com/dealers.php
L-121: Name:  i.gif
Size:  1,018 Bytes Vibration Issues - Lemon Law?
https://acurazine.com/forums/showthread.php?t=111823
L-124: Name:  q.gif
Size:  1.0 KB Jump-Start Concerns
https://acurazine.com/forums/ramblings-12/you-would-think-half-billion-dollars%85%85%85-113502/
L-127: You're too high to fit into the driver seat?
https://acurazine.com/forums/showthread.php?t=115555
L-130: Made in Japan vs. USA
https://acurazine.com/forums/wash-wax-23/where-can-i-find-aerodynamic-body-kit-2001-cl-73415/
L-133: Providing Mobility: Foot-Steering
https://acurazine.com/forums/car-parts-sale-361/microsoft-visual-studio-net-professional-4-sale-116302/
L-136: The Acura Service Consultant Illustrated Technical Guide
https://acurazine.com/forums/showthread.php?t=130040
L-139: DIY: Switchblade Key Battery Replacement
https://acurazine.com/forums/3g-tl-2004-2008-93/l-139-diy-replace-battery-switchblade-key-760967/
L-142: Wat does the Acura Certified Pre-Owned Warranty Cover?
https://acurazine.com/forums/3g-tl-2004-2008-93/l-142-what-does-certified-pre-owned-cover-787736/
M. Performance
M-001: Trips to drag
https://acurazine.com/forums/car-parts-sale-361/headers-112887/
M-004: Performance Bolt-Ons 101 - What you should know
https://acurazine.com/forums/ramblings-12/anyone-play-any-instruments-here-113901/
M-007: 3G Comptech Supercharger Part Database Thread
https://acurazine.com/forums/ramblings-12/well-there-used-road-there-154361/
M-010: Putting the TL on a diet!
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/m-010-putting-tl-diet-update-links-post-1-a-610974/
2.53
edit
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
File Type: gif
rets is offline
The following 15 users liked this post by rets:
4drviper (09-12-2011), AcNoob (01-01-2013), Ayalltheabove (09-08-2014), AyFeltaTL (06-26-2012), CannaDude (01-17-2012), cokorote (08-02-2013), daredevil0610 (02-10-2014), Jaxo (05-22-2013), JustusJs (10-23-2013), LoveMyTL-S (07-06-2012), NBP-UA6 (10-17-2011), peekay81 (12-28-2012), talmadgeryan (10-18-2012), Turbocoop (03-10-2012), Undying Dreams (08-16-2012) and 10 others liked this post. (Show less...)
Old 11-07-2011, 08:59 PM
WOT in the new ATLP V2s!
Izzy-Type-S's Avatar
Omg amazing.
Izzy-Type-S is offline
Old 11-07-2011, 09:44 PM
P1zzaman's Avatar
Originally Posted by Izzy-Type-S
Omg amazing.
Should bumping a 6 year old thread be part of the newbie guide too?
P1zzaman is offline
Old 01-01-2013, 06:31 PM
AcNoob's Avatar
Not sure how I came across this....but truly amazing man. If you are ever in Indianapolis let me know I will buy you a beer or 5.
AcNoob is offline
Old 01-01-2013, 09:50 PM
csmeance's Avatar
It's part of the 3G service dept/garage that's sticked on the top of the forums! That big thing that says click for full listing of topics is this!
If you need things added, or would like to see them added PM me with a link!
csmeance is offline
GreenMonster
Money & Investing
04-09-2006 11:16 AM
Quick Reply: The 3G TL Garage: FAQ for 3G TL Newbies.....
