How I'm getting 25+ MPG - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > First Generation TL (1996-1998)
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Acurazine.com!
Welcome to Acurazine.com.
Old 10-04-2005, 9:53 AM   #1
UnsanePyro
Registered Driver
UnsanePyro's Avatar
Alright, I've talked about it a little bit, bragged about it a little bit and figured I would let everyone know what I have done to my car to help improve the milage. None of it is anything too special, but I figured that I would make a list if anyone wants to referance it.
March 2005
17.49
21.57
20.79
24.87
21.86
Average MPG: 21.316 That was with some highway driving mixed in, 350 miles in 3 days between filling up. I don't think it was all highway, but there was definately a good mix of it in there.
Now, everything that has been done:
Spark Plugs
Spark Plug Wires
Oil/Filter (5W30, filter from Acura) every 3,000-4,000
Transmission Fluid
Coolant
Air Filter
Fuel Filter
Exhaust Manifold
That is really all that has been done to the engine. The other three factors are:
Tire Pressure - I usally keep mine up a bit higher than reccomended. It isn't the best for performance, but I don't do any performance driving in my commuting. I have begun to keep it at about 34 PSI all the way around, a little bit more than reccomended + 10%.
FP 60 - http://www.lubecontrol.com/ -
FP60 increases combustion efficiency, lubricates fuel pumps and injectors, cleans the fuel system, and potentially increases mileage. It scavenges water and moisture from the fuel system as well so the resulting mix can be burned in the combustion chamber. Combustion chambers can be cleaned using FP60.
You add in a little to every tank, 1 oz to every 5 gal of gas. Some people reccomend an initial "shock" treatment, of about double that. I have been using it with great results. It is expensive, but I have had a definate savings even considering that.
Driving Style: For the msot part, I drive pretty conservatively. I prefer a smooth ride rather than a fast ride. I usually don't accelerate much past 3,500 RPM, try and roll to stop lights and avoid stopping, that sort of thing.
September 2005
25.09
28.72
24.48
24.92
24.36
Average MPG: 25.514 This month had a similar amount of highway driving over time on it, and the rest is the same driving as usual. Not much has really changed about the coniditions I drive in, so I think it is a pretty fair comparison.
All the MPG numbers were figured using (Miles Traveled/Gallons pumped to full).
As you can see, I went from 21.3 to 25.5, about a 20% increase. It cost some money to get there, but I've got a strong running car, with consistant savings every time I fill up.
Any thoughts?
:: '97 2.5 TL :: Debadged :: Inspire Tails :: Clear Corners :: Carputer :: JVC KD-DV5000 ::
UnsanePyro is offline   Reply With Quote
Sponsored Links
Old 10-04-2005, 10:24 AM   #2
cambo
OMG! Oh N0ES!
cambo's Avatar
fp60 is some great stuff
cambo is offline   Reply With Quote
Old 10-04-2005, 11:47 AM   #3
Ken1997TL
Mega Moderator
2002 Acura RL
Ken1997TL's Avatar
What do you get with pure highway driving?
On a 2.5 I'd assume 28 or 29...
Ken1997TL is online now   Reply With Quote
Old 10-04-2005, 2:16 PM   #4
ljmushock
ljmushock's Avatar
Nice, but I get that in my V6 tl and all I have done is thrown a new set of plugs in... currently have 115K miles... I guess it is mostly the weight of your foot... But props for making it work
ljmushock is offline   Reply With Quote
Old 10-04-2005, 5:53 PM   #5
Ken1997TL
Mega Moderator
2002 Acura RL
Ken1997TL's Avatar
Having stock wheels and not too sticky tires will definitely improve your gas mileage
Old 10-04-2005, 9:44 PM   #6
UnsanePyro
Registered Driver
UnsanePyro's Avatar
Pure highway, usually about 28. I don't usually use the CC (can't really on 95/195, you can once you get up to 89/93 though) and am usually between 80-90mph, with a little bit less air in the tires (a little more grip if I need to make a sudden move).
Old 10-04-2005, 10:12 PM   #7
Ken1997TL
Mega Moderator
2002 Acura RL
Ken1997TL's Avatar
Yeah, i bet if you drove 65 mph or so (not an option on New England highways ) you could get 30+
Old 10-04-2005, 10:13 PM   #8
HQuakers
giggity giggity giggity
HQuakers's Avatar
Tire pressure is a big part of getting good gas mileage. Also, leadfooters need not care about MPG.
Also, how big is our tank again? 14gal?
HQuakers is offline   Reply With Quote
Old 10-04-2005, 10:13 PM   #9
c29842984
17.2 gallons.
c29842984 is offline   Reply With Quote
Old 10-04-2005, 10:20 PM   #10
Ken1997TL
Mega Moderator
2002 Acura RL
Ken1997TL's Avatar
Yeah, tire pressure makes a difference. I usually do about 5 psi higher than is recommended on my cars.
Old 10-05-2005, 12:00 AM   #11
HQuakers
HQuakers's Avatar
Originally Posted by c29842984
17.2 gallons.
Shit, I was waaay off. Well, I was getting 18.6MPG, but now that the exhaust manifold is cracked, more like 16.8. Christ.
Old 10-05-2005, 1:41 AM   #12
Ken1997TL
Mega Moderator
2002 Acura RL
Ken1997TL's Avatar
Just go by what your put in your tank at the pump
Old 10-05-2005, 6:08 AM   #13
UnsanePyro
Registered Driver
UnsanePyro's Avatar
Yup, it's either ~85 in the left lane, or like 50 in the right hand lane, or any random ass speed in the middle. It sucks. When I go up towards Maine/Vermont it is nicer though, onc eyou get off 95 everything is better.
Old 10-05-2005, 1:05 PM   #14
DJBLAST
2003 Acura MDX
DJBLAST's Avatar
17.5? are you sure?
Last time i filled up, i had my gas light on and all that jazz.... i got up to like 14 gallons.
DJBLAST is offline   Reply With Quote
Old 10-05-2005, 1:11 PM   #15
UnsanePyro
Registered Driver
UnsanePyro's Avatar
http://hondanews.com/CatID3011?mid=2...40159&mime=asc
17.2 Gallons.
When the fuel light comes on, you still have a few gallons left. That way you can drive another 50+ miles, ample warning.
Old 10-05-2005, 1:39 PM   #16
WolfpackBill
TL no more!
WolfpackBill's Avatar
Heh...I always fill up when the needle is at the last 1/4 mark. When I fill up, it usually tops off around 10 gallons. It's weird!
WolfpackBill is offline   Reply With Quote
Old 10-05-2005, 3:25 PM   #17
mblackmarr
mblackmarr's Avatar
Some of you guys have put in new plugs, What is a good hi performance spark plug for our cars, Something titanium?
mblackmarr is offline   Reply With Quote
Old 10-06-2005, 8:57 PM   #18
KADAW
KADAW's Avatar
man i get like 16.3mpg. [all city tho] but sucka as chimp..funk!
KADAW is offline   Reply With Quote
Old 10-06-2005, 9:37 PM   #19
UnsanePyro
Registered Driver
UnsanePyro's Avatar
Damn man, I'm sorry, some stuff I understand, but that... I just don't. Care to help me out?
Old 10-06-2005, 9:47 PM   #20
KADAW
KADAW's Avatar
lol im sure u ment the end of my statement, i was jus fliping out i guess... cuz i only get 16mpg.. which i dont think is good.... better? sorrie was juss venting..
Old 12-13-2005, 8:39 PM   #21
copy252
copy252's Avatar
March 2005
17.49
21.57
20.79
24.87
21.86
Spark Plugs
Spark Plug Wires
Transmission Fluid
Coolant
Air Filter
Fuel Filter
Exhaust Manifold
FP 60 - http://www.lubecontrol.com/ - You add in a little to every tank, 1 oz to every 5 gal of gas. Some people reccomend an initial "shock" treatment, of about double that. I have been using it with great results. It is expensive, but I have had a definate savings even considering that.
September 2005
25.09
28.72
24.48
24.92
24.36
Any thoughts?
i need that! 14 a gallon here is killing my ass!
copy252 is offline   Reply With Quote
Advertising Information - Contact Us - AcuraZine -
Top
