| Welcome to Acurazine.com! |
Thread Tools |
#1 | |||||
| Sponsored Links | ||
#2 |
Registered User
This happens to be excellent. I am going to sticky this thread and close the existing thread since it is so large and unorganized. Good job on summarizing everything.
For anybody wanting to read through the original thread see this thread: http://tl.acurazine.com/forums/showthread.php?p=1368101 |
#3 |
Registered User
one question how do your get rid of the nag screen? i see you have a "navi-nonag.exe" file that was updated...explain?
#4 |
My problem is that I have burned this DVD in different modes with Nero and it does not want to read it. I used both CDRW & DVD+R. Everything else works great except for that last part.
I even went through all the other extra settings for Nero under the TSX thread and no win. ![]() |
#5 |
Registered User
Would also be nice if someone could compile all the backgrounds into one location.
#6 | |
Registered User
#7 |
Knocked the f*ck out!
#8 |
Registered User
it now said unable to openbootloader file why is that please help me out.i'm so lost with this.
#9 |
Registered User
please help me out of this?
#10 |
Registered User
If you can't save files to your hard drive then you should probably stop where you're at.
#11 | |
IndyHP Member
2005 Acura TL |
#12 | |
Registered User
#13 | |
I'm trying to find a place that I can upload some of mine at. I've been looking at photobucket and fotki. |
#14 | ||
. I am assuming that you will have to edit the file with Hex editor.Quote:
#15 | |
I remember doing that too. Sorry. Thanks for the tip though. |
#16 |
The intention of this thread is to keep it clean with mainly howto's and suggestions.
When posting questions, please be specific as to where you are having problems. Help us, help you. Please read the instructions carefully. Most of the time the answer is right there. MIN REQUIREMENTS TO DO THIS HACK
ADDITIONAL NOTES The commands you see (like "dumpnavi BNHH401A.BIN extract") are done through window's command prompt (Start > Run > cmd). For the commands to work, the files you specify and the dumpnavi program need to be in the same folder. You will need to change to the correct folder via the cd command. Here's an example on how to update the splash screen. I copied all files to "Z:\TLNaviFiles" on my computer.
If dumpnavi gives you errors, I can't really help you there (others may still). The development has stopped for this program and I am not planning to look at source code. You can PM me if you want specific help, but please be detailed. |
#17 |
Registered User
what is a bootloader and where do i find it
#18 | |
Registered User
Bysin: "I didnt include the navi-nonag.exe or any other modified files with the zip because its copyrighted by Acura. All files that you wish to update you'd have to modify yourself. But I'm sure anyone with a SH-4 disassembler and a hexeditor can figure it out how to remove the nag screen. I'll give you all a hint, 0x0900 is nop." |
#19 |
Registered User
OK - I've done a little research and found a SH4 dissasembler called "Ida Pro Advanced". I found it here: http://vetusware.com/download/IDA%20...04.15/?id=3377 (note this download site says it's a DOS file - it is not - it will run on Windows XP, Etc).
It's downloaded as an RAR file. 1) Download 2) Unpack it using WinRAR (available as a free download if you don't have it) 3) Run the executable in the unpacked files (.exe) 4) The prompt screen that pops up is apparently in a foreign language. Selecting the lower left "????????" button creates a new "Ida Pro Advanced" directory and unpacks all of the Ida Pro files into that new directory. 5) Within that new directory, double click the "Idag.exe" file and viola - you're running an SH4 dissasembler. Now - what to do next? Take the dissambles files and edit with a hex editor (there are many free Hex Editors available on-line - do a Google search)? What did Bysin mean when he said "0x0900 is nop"? Come on - let's crack this bitch! |
#20 | |
Registered User
Tell me about it... There are so many knowlegeable computer people here and no one wants to crack/hack or whatever you call it, to the file. |
#21 |
Registered User
More....
All:
More info on the "disabling the nag" hint left by Bysin. Regarding the "nop" command: NOP is just an "ignore me......I do nothing" instruction....Usefull if you're hex editing and need to erase a section of code. I take bysin's hint to mean that we need to erase the section of code: 0x0900 So taking bysin's hint and breaking it out: 1) Using the instructions in the first post of this thread - use the dumpnavi tool to extract the files from the Navi DVD's .bin files - (which will include navi.exe). 2) Use an SH4 disassembler (Bysin recommends Ida Pro Advanced in a post in this forum) to dissasemble the navi.exe file 3) Use a Hex editor to take the disassembled code and erase the 0x0900 section of code using the "nop" command. 4) (I'm guessing here) reassemble (compile?) the code as "navi-nonag.exe" 5) Using the instructions in the first post of this thread - use the dumpnavi tool to create new .bin files - which ill include the new navi-nonag.exe file and load them into you TL. I'm not a software developer, but this stuff doesn't seem like it's too hard. I've been able to get the navi.exe extracted from the .bin files and dissasmeble it with Ida Pro. At this point, we just need someone who knows how to use a hex editor to do the same and then use the nop command where bysin hinted. Then reassemble and viola - no more Nag screen. Anyone out there familiar with hex editors? |
#22 | |
Team Anthracite Member
The general approach here is good, but it is too general. The devil is in the details. The next level of detail is: 1. Review the assembly code to try and determine the logic used to wait for the user to press OK. 2. If you cannot read the assembly code, find an SH-4 emulator and environment to step through the code and find the OK logic. 3. Steps 1 and 2 are hard to do. After you have found the logic, see if you can NO-OP the code that says 'wait for the user to press OK' without breaking the logic. 4. Use the Hex Editor to NO-OP the code and try it in the simulator (if available). 5. There could be a lot of trial and error here, especially if a simulator is not available. 6. Save the files back to a CD per the Dumpnavi instructions and try it in your TL. 7. If you made a mistake, it may lock up the Navi. If it does, remove battery cable and reboot TL. 8. Repeat steps 1-7, until you get it right. (this may take a long time). I'll take a look at this using the Disassembler listed in this thread. I can do a lot better job if someone can get an SH-4 Windows CE environment and emulator for me. |
#23 |
Registered User
Did anyone else have trouble getting the files off the DVD? I put the disc in my DVD-RW and Windows won't even acknowledge that there's a disc in there. Is there some special trick?
#24 |
Registered User
Just FYI, I think Honda / Alpine have changed some things, possibly to make this harder to do. For one, the dev info screen in the nav unit no longer displays the 'Loading Filename'. Lots of other nifty things there, but no filename display. That said, there are three .bin files in the root of my Nav DVD (v6.11C): 06AVN.bin, 06AVN2.bin, and VRDB.BIN. The only one which dumpnavi.exe will open up is 06AVN2.bin, and it crashes while in the middle of listing the file. I'm also unable to dump files with it.
This is disappointing, because I wanted to change the boot screen, remove the nag screen, and look into the possibility of replacing the word AUX in the interface with IPOD to match the hookup I'm building. Ah well... I guess I'll have to look into this a bit more. < sigh > -Steve |
#25 |
Registered User
Oh, one other idea for those of you who are re-burning DVDs with all the nav system software on it. Look for the Honda and Acura dealer logos and replace them with just the color used to indicate transparency around the other icons. That's an easy workaround for disabling their constant display.
#26 |
Registered User
I just ran the GUI dumpnavi and clicked on modify nag screen and updated it, and it ran successfully saying that the file had been updated.
Does this mean that the nag screen is removed? i will burn it and try it tomorrow! |
#27 | |
Registered User
-Steve |
#28 |
Registered User
orange DVD
BNHH401A.bin |
#29 | |
Registered User
-Steve |
#30 |
Registered User
ver 3.5
#31 | |
Registered User
-Steve |
#32 | |
Registered User
#33 | |
Registered User
-Steve |
#34 | |
Registered User
#35 | |
This means that all of the DISCLAIMER text is erased so you get a blank screen until the OK button comes up. You probably won't like it because it makes it seem like the Navi is broken since there is nothing shown between the startup picture and the OK button.
Team Anthracite Member 2005 TL 5AT/Anthracite/Ebony/Navi A-Spec Underbody Kit/Lip Spoiler Interior Blue LEDs 35% Tint |
#36 | |
For the Acura TL, the orange 3.5 DVD is the current version shipping. You can see for yourself here https://iweb.alpine-usa.com/Acuradvdsales/naviorder.php |
#37 |
Registered User
Dissasembler
Ok, so i removed the bin from the DVD
I used dumpnavi to extract the files I load navi.exe into the dissassembly using a SH4 processor type....(not sure of the settings....any help here would be appreciated) i save to to navi.idc i open navi.idc up with my HexEditor I get some text that makes sense and a lot that doesnt. I cannot find the line 0x0900 so i fee that it either isnt get dissasembled right or the hex isnt reading it right. I am a coder but i have never used anything dealing with SH4. Does anyone have any advice to offer on this project? Has anyone gone this far yet with the info we have so far? |
#38 |
Registered User
Well I got mine to work last night, but after doing it, I think it was a waste of time. The blank screen is *almost* more annoying than the disclaimer. If someone figures out a way to go from splash screen to map w/ no other interaction then I'll try it again.
#39 | |
Registered User
I'm pretty sure that 0x0900 is the offest in the file, meaning how many bytes from the begining or such. There isn't likely any actual hex that shows as 0x0900. So the idea would be to move to 0x0900 in the file and replace whatever hex is there with the hex that represents a NOP instruction for the SH4. -apnar |
#40 | |
Registered User
| Tags |
| 0x0900, 35, acura, cd, dvd, hack, hacks, honda, nav, navi, navigation, rl, screen, system, tl, tool |
| Thread Tools | |
