Removing Resonator on Stock exhaust (Summary Post #1 & #1811)
Old 01-20-2006, 03:12 AM
aznbo187's Avatar
Just wondering if anyone had tried to take out the stock resonator on the stock TL exhaust system and replaced that with a straight pipe and leaving the rest of the system the same?
I know for a fact that on a few V6's, or other cars, doing this mod, did not give much power gains, but it did make the car sound a little bit more aggressive and tuned. But on other cars, this made the exhaust sound raspy and ricey.
And insight?
Moderator edit:
In order to save new readers from going through 20 pages, see the "Compilation of Resonator Modification on page 22, Post #528" https://acurazine.com/forums/showpost.php?p=8707306&postcount=528
EDIT:
Summary:
Originally Posted by aznbo187
Compilation of all stages of exhaust resonator modification.
So I took the time and made this post so all of the new people don't have to go through 20 pages of discussion.
So far, there are 4 stages of this exhaust mod.
Stage 1.
Least noticeable in exhaust note increase.
Configuration:
Stock exhaust.
Remove mid-muffler. Replace with 2.5" straight pipe. Everything else remains stock.
Cost: Can be anywhere from $30-$60 w/aluminized pipping.
Stage 2.
A tad louder than stage one, a bit more pronounced tone.
Configuration:
Stock exhaust.
Remove stock resonator. Replace with Magnaflow resonator part# 10416.
Magnaflow resonator is a 14" long resonator, which dampens and changes the note of the stock exhaust a bit more, thus you get a bit more loudness/tone.
Cost: Magnaflow resonator costs around $60. Install ranges from $60 -$90 w/ aluminized pipping.
Stage 3.
(Tone result TBA)
Stock exhaust.
Remove stock resonator. Replace with Dynomax resonator part# WLK-24215.
Dynomax resonator is a 12" long resonator, which is a bit shorter and less dampening than the magnaflow resonator, thus it should give you a bit more loudness/tone than stage 2.
Cost: Dynomax resonator costs around $40. Install ranges from $60 - $90 w/aluminized pipping.
Stage 4.
Loudest setup out of all 3. Has a bit of a rasp, similar to M3 exhaust setup.
Stock exhaust.
Remove Mid-muffler. Replace with a 2.5" straight pipe.
Remove stock resonator. Replace with a 2.5" straight pipe.
Cost: Can be anywhere from $40 - $60.
Note: If you live in a climate that is prone to rain, snow, rust, Stainless steel pipping is highly recommended.
This also does not prevent you from passing smog, as it does not alter the characteristics of the catalytic converters, but it does not mean that this is street legal either as it does alter the stock setup of the exhaust.
Media.
Stage 1: Revving
Stage 1: Revving
Stage 2: Revving
Stage 2: Revving Pt.2
Stage 2: Inside Revving
Stage 2: Drive By
Stage 3: Windows Down Driving
Stage 3: Revving
Stage 3: Drive By 1
Stage 3: Drive By 2
Stage 3: 2007 TL-S all-in-one
Stage 4: Revving
Stock Exhaust Configuration.
Stage 1.
Stage2.
Stage3.
Magnaflow Resonator 10416
Dynomax Resonator WLK-24215
Good luck!
aznbo187
Originally Posted by Toddy
Hope this helps. I labeled everything in Red for you
The following 15 users liked this post by aznbo187:
Bearcat94 (07-19-2011), Colorado Guy AF Ret. (04-29-2013), conort2390 (07-10-2013), CurtisB95 (08-28-2012), DerrickW (09-25-2015), DoomDude666 (10-31-2013), kevin963 (10-06-2016), LeMix (12-21-2013), Mrtastygoody (10-15-2012), robocam (04-28-2014), rossv1 (10-15-2012), Scalways (05-29-2012), serbj (04-12-2012), t5C7 (10-07-2013), Undying Dreams (06-27-2012) and 10 others liked this post. (Show less...)
Old 01-20-2006, 01:13 PM
9.5+10.5 22m=Hella Flush
ed99's Avatar
Someone did that last yr and if I can remember that member said it did make the OEM muffler sound a bit more aggressive.
Old 01-20-2006, 08:00 PM
Youse Gots Sacked
NFLblitze1's Avatar
id like a little mroe feedback on this aswell...im contemplating the same thing
Old 01-21-2006, 03:51 AM
aznbo187's Avatar
I just remember I saw this silver tl a while back with the stock exhaust and it made a tiny gurgle like sound (similar to G35) so I'm hoping this would give it that tone. I mean I read that getting a catback is not going to gain much Hp, and it would mainly be for sound, so this would be ideal for me.
I remember, on my 1997 Jetta VR6, I removed the stock resonator, and it gave the stock exhaust a perfect growl with no rasp or anything.
So any feedback on how it would sound on this car would be awesome before i go ahead and do it.
tyreek77 (05-21-2012)
Old 01-21-2006, 04:12 AM
SSM 6MT
rstark's Avatar
I'm interested too...
Old 01-21-2006, 09:25 AM
Scoobie Specialist
dman918's Avatar
I definitely want to know as well. I want an exhaust with a similar volume level to the g35.
Old 01-21-2006, 10:48 AM
Got Pearl?
flvol77's Avatar
And insight?
IMO I would maybe change it out to a magnaflow SS resonator and remove the stock mid muffler and I think that would change the sound. Ask Subinf, he has done about everything to his exhaust that can be done.
Old 01-21-2006, 11:47 AM
aznbo187's Avatar
So I searched the forums and it seems that the user "galespeed" has removed his mid muffler. He seemed to have removed the resonator (closest to cat), and mid muffler (muffler closest to oem canisters) and replaced it with a straight pipe. With that he had a certain resonance, or rasp, or rice canister sound at about 3k rpm. He then put the resonator back on, but kept the mid muffler still straight piped and he said that he thinks the sound is now perfect. I think im goin to do this as well. Remember, don't remove the resonator, just the muffler closest to the rear of the car.
The following 2 users liked this post by aznbo187:
Scalways (05-29-2012), t5C7 (10-07-2013)
Old 01-21-2006, 12:24 PM
One on the right for me
subinf's Avatar
i agree...get rid of the mid muffler and keep the resonator, otherwise, as you mentioned, you will get a pretty harsh rapsy sound.
t5C7 (10-07-2013)
Old 01-21-2006, 01:26 PM
Youse Gots Sacked
NFLblitze1's Avatar
is the exhaust pipe "b" the mid muffler? how much do u think a shop would charge to make a new pipe and install etc....
Old 01-21-2006, 01:32 PM
CTS-V Import Slayer
MichaelBenz's Avatar
Check the "book" post here I made in this cooresponding thread....could answer some of your questions? Total Exhuast theory writeup near bottom....
https://acurazine.com/forums/ramblings-12/impossible-flash-game-130018/
Old 01-21-2006, 03:44 PM
subinf's Avatar
removing either the resonator or the mid-muffler should not cost more than 35 dollars (at 70/hr). some shops have a min. exhaust charge which is usually an hour, but for something as simple and easy as this 1/2 hr labor is what should be charged.
Old 01-21-2006, 04:13 PM
Youse Gots Sacked
NFLblitze1's Avatar
Subinf,
do you recommend to remove only the midmuffler? how big of a difference do you guys think it will make?
Old 01-21-2006, 04:25 PM
subinf's Avatar
Originally Posted by NFLblitze1
Subinf,
if you were going to remove something from the oem exhaust i would rec. doing just the mid muffler. i dont think removing the resonator will give you a pleasant sounding exhaust note and if you remove both you are heading into raspy territory. its an easy mod if you are looking to change the sound of the TL
JDMJDK77 (10-28-2013)
Old 01-21-2006, 04:37 PM
aznbo187's Avatar
Okay, well I just went ahead and got it done. I had the mid muffler removed, not the resonator. They charged me $30 and it took all about 15 minutes.
Sound. I love it. I think this is the way the TL should have come stock. Similar note to a G35, but a lot more refined and subtle. Fits the TL personality perfectly, compared to the stock exhausts that emit no sound what so ever. The tone is similar to that as the G35, or the Fx, but much smoother and quieter. There is no drone at highway speeds, no rasp, no rice sound, and no rattles.
If your looking to keep the car stock looking, but you feel the stock exhaust is just TOO quiet, and want something a tad bit louder but not something where the wife, girlfriend, neighbors would instantly notice, this is for you!
The following 5 users liked this post by aznbo187:
conort2390 (07-10-2013), danielPL (02-01-2012), JDMJDK77 (10-28-2013), nrb2005tl (06-09-2011), t5C7 (10-07-2013)
Old 01-21-2006, 04:43 PM
Registered Offender
ImPo Skyline's Avatar
Thanks aznbo187, I'm going to have it removed this weekend. I was going to do it regardless, however I've been putting it off like crazy. Its for sure now.
Old 01-21-2006, 05:09 PM
Youse Gots Sacked
NFLblitze1's Avatar
so what consists of removing the mid muffler removed? do they take it out and replace with a straight pipe?
Old 01-21-2006, 05:27 PM
subinf's Avatar
^-yup, the shop will cut the muffler out, take regular pipe, expand the ends so it slips over the pipe on the car and weld it up. if you wanted to get fancy with everything you could have the shop add flanges to the exhaust so you can remove and replace the straight pipe with the muffler if you ever wanted to go back and do it yourself.
Old 01-22-2006, 10:43 AM
Scoobie Specialist
dman918's Avatar
How much do you think it would cost to have a straight pipe made with flanges so that it is easily changable back to stock?
Old 01-22-2006, 12:06 PM
aznkikaz's Avatar
great review! I might go do it now since it is so cheap but one question
If I trade the car in would it go down in value?
Old 01-22-2006, 02:11 PM
Registered Offender
I had a flanged straight pipe made for my civic, it cost me $30 for each, the pipe cut out flanged and the straight pipe flanged. all and all it was $100 for all 4 flanges and labor.
Old 01-22-2006, 04:15 PM
Registered Offender
Don't tell anyone that it's been removed. They will give you a value of the car, wash it and put it on their front used line. I doubt they will inspect a 04 + tl.
Maybe just brakes and tires.
Old 01-22-2006, 04:57 PM
Scoobie Specialist
dman918's Avatar
So is it pretty much silent when cruising and idling? The difference is just in acceleration?
Old 01-23-2006, 01:39 AM
VelfarreClubber's Avatar
Does it sound just as loud as the G35 or Fx? i know the tone is similar but im wondering about "volume"
Old 01-23-2006, 02:08 AM
aznbo187's Avatar
Cruising, you cant really tell a difference at all unless your you have ur music on 0 and your REALLY trying to listen for it, even then you probably will have a hard time making it out.
Old 01-23-2006, 02:09 AM
aznbo187's Avatar
The tone is similar, but the volume is not near the Infiniti's exhaust. It's one of those mod's you can hear, but anyone else would not be able to tell the difference, or hardly be able to tell that it's been modified unless its a car enthusiasts.
Old 01-23-2006, 02:12 AM
aznbo187's Avatar
After having this mod done, I love the outcome but if there could be one thing I wish was better was that it had just a tiny bit more volume. I was wondering what would happen if i replaced the stock resonator, with a smaller resonator?
Would that jsut create a different "bad spot" where it would sound raspy at a certain rpm?
I know an intake would add to the engine noise, but would an intake make the exhaust a little louder?
Old 01-23-2006, 08:49 AM
Youse Gots Sacked
NFLblitze1's Avatar
aznbo187..did u just take out the midmuffler?
Old 01-23-2006, 09:20 AM
HEK
Team Nighthawk Mambo King
HEK's Avatar
Same question and any pictures??
Old 01-23-2006, 11:26 AM
Dlifter's Avatar
G35ish sound
I would assume to get that nice G35 exhaust sound that everyone is talking about the ideal thing to do is just to get a small resonator and leave everything else alone. Correct me if this incorrect.
Old 01-23-2006, 11:37 AM
aznbo187's Avatar
Yes, just the mid-muffler, not the resonator. The mid-muffler is a square looking muffler after the resonator, which is a long tube looking muffler. So just remove the mid-muffler and have them weld on a straight pipe.
Old 01-23-2006, 11:38 AM
aznbo187's Avatar
No, not the resonator. The resonator cancels out the virbration, but doesnt reduce sound. You want to remove the mid-muffler.
Old 01-24-2006, 06:00 PM
Scoobie Specialist
dman918's Avatar
Where did you go to get it done for $30? Everywhere I have called so far is quoting $60-$70.
Old 01-24-2006, 06:33 PM
Youse Gots Sacked
NFLblitze1's Avatar
^^^^ I Guess it depends where you live...
Old 01-24-2006, 07:17 PM
subinf's Avatar
where do you live? if its in norcal i can get your the job for 35 w/o flanges.
Old 01-24-2006, 09:59 PM
Scoobie Specialist
dman918's Avatar
Madison, WI.
Hmmm, I will keep trying. but so far it has been pricy for probably a $5 piece of pipe and 15 minutes worth of work. I wish I was around by you b/c I would love to hear the magnaflow as well.
Old 01-25-2006, 03:09 AM
aznbo187's Avatar
If your going to name brand exhaust shops their prices are a bit higher. I had it done at a "hole in the wall" shop. Pretty much the same thing. Just tell them to make sure the welds are good.
Old 01-25-2006, 09:52 PM
Registered Offender
I've got a quote for $25.00. I'm dropping it off tomorrow and picking it up after work. I'll for sure make a video/sound clip for everyone and have it posted by this time tomorrow night.
Anyone in southern california should call Rod's muffler service. The guy has personally owned and operated it for 22 years. His name is Rod, (949) 661 3883.
Let him know the guys from Mercedes sent you, He'll hook it up.
Old 01-25-2006, 10:05 PM
Youse Gots Sacked
NFLblitze1's Avatar
can't wait for it...can u do a before and after sound clip? do one now...and one when u get it back....
aslo...are u just getting the midmuffler removed or are u getting the RESONATOR and the MID-MUFFLER removed?
Old 01-25-2006, 10:30 PM
Registered Offender
I talked to the guy today, he said I'd get more sound if the resonator is removed.
I think I'll go that route and maybe do the mid later. I'll go make a stock sound clip now. I'm just worried about how it will sound after its uploaded.
Quick Reply: Removing Resonator on Stock exhaust (Summary Post #1 & #1811)
