ECU Pinout 3G TL
Old 02-21-2007, 12:46 AM
Team Anthracite
tidus888's Avatar
ECU Pinout 3G TL
Does anyone have the pinouts for the ECU on the 3G TL?
it would be helpful. THanks
Old 04-02-2011, 05:13 PM
Comptechtl2367's Avatar
Back from the dead!
Anyone have this at all? I want to know if the "A" connector pinout between the Auto and MT are the same.
Old 04-02-2011, 08:44 PM
TLdream's Avatar
Originally Posted by Comptechtl2367
Back from the dead!
The pinnouts for the same years are the same auto or manual. The auto will have a few extra wires. Different years have different pinouts. from what i can remember the 04-05 is the same, the 06 is similar to the 07-08 but not exact. The dlc wiring is different on the 06 but most of the ecu plugs are the same. I may try to scan in the pinouts later if you need them.
Old 04-03-2011, 12:34 AM
Do you happen to have the MT and AT for the 06? i want to see it the match exactly. All i need it the plug "A" connector.
Old 04-03-2011, 09:40 PM
I got all the pinouts I needed.
If anyone ever needs them i have them for the 04-05 and the 06.
Old 04-23-2011, 07:30 PM
pass427's Avatar
Do u happen to have pinout handy I'm far away from shop and need the 2004 manual pinout please thanks
Old 04-23-2011, 07:42 PM
SpiderX1016's Avatar
Is this what you want? I can get them more in-depth on each pin if you want.
702Razz (09-13-2023)
Old 04-23-2011, 07:50 PM
pass427's Avatar
Spiderx1016 you're a savior I greatly appreciate this thanks a bunch
Old 04-27-2011, 10:39 AM
I emailed you the print out version of that, sorry for the delay i was not on here for quite awhile.
Old 12-30-2011, 04:40 PM
pass427's Avatar
Spiderx how about the pinout for 2006 model please thank you
Old 12-30-2011, 05:56 PM
KN_TL's Avatar
Is this what you are looking for?
Old 02-08-2012, 08:15 PM
cmluckett's Avatar
KN_TL - any chance you could repost those pics or pm them to me. i'm looking for pinouts for my 08 so i can get this fic connected correctly. i would greatly appreciate it if you could.
thanks.
Old 02-08-2012, 08:48 PM
KN_TL's Avatar
cmluckett (02-09-2012)
Old 02-09-2012, 08:04 AM
cmluckett's Avatar
Perfect!! Many Thanks!!
Old 02-09-2012, 08:31 AM
KN_TL's Avatar
No problem! Are you going to be implementing O2 skewing with your install?
If you are, can you post or PM me the details on that?
Old 02-09-2012, 11:19 AM
cmluckett's Avatar
i'm not quite sure yet. if i recall, aem recommends that being a last resort after map clamping, fuel mapping, and timing adjustments. i'm running rv6's hfpc and j-pipe. if it comes down to o2 skewing, i'll gladly share what knowledge i gain in the process. i'm less than 2 weeks out on my s/c install so i'll be back in touch soon on this issue.
thanks again!
Old 02-13-2019, 06:33 AM
Peter Allen's Avatar
i have just found myself in a similar situation and need both the 05 and the 06 PCM pinouts. Do you still have them available? Let me know. Thank you.
Old 02-13-2019, 09:48 AM
Late to the 3G Party
mb.3g's Avatar
The last post made here was 7 years ago. I doubt he's still around.
Old 05-13-2020, 09:11 PM
Ricky Weaver's Avatar
Hate to bring back from the dead but need these pinouts as I can't find them anywhere and all the ones in here don't show up. Trying to use ktuner on my dirt track race car but can't see spending $350 on a junper when I can repin the wires myself. Thanks
Old 05-18-2020, 03:52 PM
WarrenG's Avatar
06 pin out
Does anybody have a pin out in detail on an 06 at I’m doing a manual swap I’m 98 percent complete runs and drives but has bank 1 02 heater codes and the pin outs I have access to on identaguess do not show the colors I have left over
Old 05-18-2020, 04:33 PM
Anyone in general that reads the post that could help would be awesome
Old 05-18-2020, 05:11 PM
oraclem20's Avatar
Here's the ECU side pinouts. You'll have to trace wires from there, the pages for the other side of these connectors is nearly 100 pages of document.
File Type: pdf
File Type: pdf
Old 05-27-2020, 09:18 AM
WarrenG's Avatar
I got it now it’s complete just had the un used orange wire hooked to the o2 heater wire on connector a now it’s done finally hell yea
Old 11-03-2020, 06:07 PM
CjsWiring's Avatar
hello, im after the 07-08 ecu pinouts as well, but all i can seem to find are the 04-05. if you still have it is it possible to get them as well? i know this is an old post. im bringing back the accord to tl ecu jumpers that have been discontinued. thanks in advance
Old 02-11-2022, 11:30 PM
alfredo1's Avatar
Hi I need this
Old 08-28-2022, 03:17 AM
Narek's Avatar
Hi, can you please send it to me. During writing cable was taken of so I need to connect to my ECU with pinouts.
Old 09-12-2023, 12:04 PM
702Razz's Avatar
Yes Please THIRD 3rd gen Acura TL manual 6sp
Can I get the pinouts for the ecm/ecu for 2005 manual and 06 manual, I am doing a swap due to being told by the dealership mine is bad. Thank you
Also do you know if the PCM is the same or in the ECM for a 2005 Acura TL?
TypeS860
09-03-2021 06:42 PM
cycdaniel
12-17-2019 10:58 AM
Skirmich
10-01-2015 12:59 PM
malvothegreat
09-29-2015 12:38 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Quick Reply: ECU Pinout 3G TL
