3G TL Technical Service Bulletins (TSB'S) 3G Garage #J-016
Old 03-01-2007, 10:08 AM
Administrator
Ron A's Avatar
IMPORTANT NOTICE-We seem to be back in business 14Sep11
UPDATED 14 September 2011
THE INSTRUCTIONS HAVE BEEN CHANGED AND SIMPLIFIED
We have regained our access. Follow these instructions. Exactly!
PLEASE CLEAR YOUR CACHE BEFORE PROCEEDING. IF YOU DON'T, AND HAVE A PROBLEM, CLEAR YOUR CACHE.
1. Open this link . If you get a popup asking for a user name and password, just click on "Cancel" and you will be able to proceed. I'm not sure if Honda made a mistake and intends to implement the user name and password requirement later but for now this will work. If it changes, let me know.
2. Open any one of the listings.
3. You can now open the below listed links.
ADDED 17 MAY 2012: Use this link to search for tsb's and recalls not listed. I don't guarantee that they have everything but they have a lot of them.
Many thanks to TSXV6Guy for sharing this method with us.
el42 tire vibration work sheet
tsb 88-016: Battery test procedure.
TSB 89-015: ATF Cooler Cleaner.
TSB 90-009: Automatic Transmission In-Warranty Exchange Program
TSB 96-009: Removal of Clear Guard Protective Film.
TSB 96-025: Navigation System Component In-Warranty Exchange/Out-of-Warranty Repair.
TSB 97-040: Keyless Remote Transmitter Information.
TSB 98-015: Special Tool Loan Program
TSB 99-010: Cutting Keys With the Exacta Key Code Cutter.
TSB 00-037: Brake Disc Refinishing Guidelines.
TSB 01-026: Updating the ECM/PCM (Revised 20 Sept 2005.
TSB 02-020: Initializing the OPDS Unit.
2003:
TSB 03-012: Immobilizer System (Type 4).
TSB 03-013: TQI of the DVD Navigation System With Voice Recognition.
TSB 03-023: TQI and New Model Information.
TSB 03-024: 2004 Acura Paint Codes.
TSB 03-033: MIL Comes On With DTCs P0301, P0305, and Possible P0300
2004:
TSB 04-004: Updating the Honda Interface Module (HIM) Model 3557-0100-00
TSB 04-005: Driving Position Memory System Does Not Work.
TSB 04-006: Audio Unit Diagnosis. (Revised 10/19/2005)
TSB 04-015: ABS Indicator Comes On With DTCs 15, 16, 17, 43, and/or 44.
TSB 04-016: MIL Comes On With DTC P2195 or P2197.
TSB 04-019: Brembo Brakes Squeal With Light Application.
TSB 04-020: Safety Recall: CL and TL Automatic Transmission 2nd Gear Inspection.
TSB 04-034: Moonroof Wind Deflector Rattles.
TSB 04-036: HomeLink™ Unit Does Not Learn The Garage Opener Code
TSB 04-039: Headliner Sags at Moonroof Opening.
TSB 04-043: Rear Shelf Rattles.
2005:
TSB 05-003: 2005 Acura Paint Codes
TSB 05-013: Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition.
TSB 05-014: Child Seat Anchor Locating Button Is Missing (Revised 06/07/2005)
TSB 05-016: Roof Console Bezel is Cracked or Broken
TSB 05-017: 5th Gear Vibration or Drone.
TSB 05-018: Navigation System DVD Information
TSB 05-020: HandsFreeLink (HFL) System Does Not Work (Revised 09/23/2005)
TSB 05-025: Outside Air Temperature Gauge Reads Inaccurately
TSB 05-029: Product Update: DTC B1161 with Outside Air Temperature Displays Three Dashes (- - -), or Intermittent Dead Battery
TSB 05-032: 2006 Acura Paint Codes, Exterior and Interior Color Code Locations (Revised 2/10/2006)
TSB 05-033: Power Mirrors, Auto Dimming Mirror, Power Seat Position Memory, and Windshield Washer Do Not Work (Revised 10/14/2005)
TSB 05-034: 2006 TL: TQI and New Model Information
TSB 05-043: Safety Recall: Right Front Impact Sensor Is Loose
TSB 05-050: Premature Rear Tire Wear (supersedes TSB 05-076)
TSB 05-076: Premature Rear Tire Wear (superseded by TSB 05-050)
2006:
TSB 06-009: Power Window Main Switch Button is Damaged or Missing
TSB 06-012: Inside Rearview Mirror Is Loose
TSB 06-013: Long Crank Time or Hard Starting
TSB 06-023: MIL comes on with DTC P0116
TSB 06-024: High Mount Brake Light Cover Material Comes Loose
TSB 06-031: Front Door Glass Makes Noise or Stops When Going Up or Down
TSB 06-034: Vehicle Pulling or Drifting
TSB 06-035: 2007TL: TQI of the DVD Navigation System with Voice Recognition
TSB 06-036: 2007TL: TQI and New Model Information
TSB 06-040: Glove Box Rattles or Squeaks
TSB 06-043: Moonroof Glass Weatherstrip Is Damaged
TSB 06-046: Tubeless Tire Repair Information
TSB 06-050: Warranty Extension: Vehicle Warranty Mileage
TSB 06-053: 2007 Acura Paint Codes, Exterior and Interior Color Code Locations
2007:
TSB 07-005: 2004–06 TL: Front Brakes Squeal
TSB 07-006: Door Panel or B-Pillar Rattles, Ticks, or Buzzes
TSB 07-010: Music Link (For iPod) General Information and Symptom Troubleshooting
TSB 07-011: Rattle, Slapping, or Tapping From Moonroof While Driving
TSB 07-013: Whine From Speakers During HFL Use
TSB 07-017: Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
TSB 07-026: Pinging, Rattling, or Squealing During Light Acceleration
TSB 07-028: Audio Button Panel Lights Do Not Work; Audio Unit Button Lights Stay On With the Key Off
TSB 07-035: Front Passenger's Seat Squeaks or Rattles
TSB 07-036: Audio System Will Not Play a DVD-A
TSB 07-038: No Sound From XM Satellite Radio or Delayed Song Title Display
TSB 07-039: 2007 Type-S TL! Knock or Clunk From the Rear Suspension
TSB 07-041: Brake Pedal Is Low and Feels Soft
TSB 07-043: Outer Door Handle Extension Falls Off
TSB 07-048: Driver’s Side Vent Rattles While Driving
TSB 07-049: Front Center Speaker Grille Rattles
TSB 07-050: Service Manual Update: HFL (HandsFreeLink) General Troubleshooting Information. Applies to all 2006-2008 Vehicles with HFL
TSB 07-060: Power Steering Moans or Whines
2008:
TSB 08-004: Driver's Seat Cushion Rocks or Is Loose
TSB 08-008: 2004-08 TL: Seat Back Panel Is Loose or Detached
TSB 08-013: 2004-05 TL: Safety Recall: Windshield Wiper Motor Does Not Work
TSB 08-016: 2004-08 TL: Safety Recall: Power Steering Feed Hose Leak
TSB 08-018: Transmission Grinds When Shifting Into 3rd Gear, Pops Out of 3rd Gear, or Is Hard to Shift Into 3rd Gear
TSB 08-021: Acuralink Message Cannot Be Read, There Is No XM Radio Or Traffic, Or XM Channels Are Wrong
TSB 08-031: Chirp From the Timing Belt Area
TSB 08-035: (2006-2008) DVD Read Error, or No Route Displayed, And navigation DVD is Scratched
TSB 08-043: (2007-2008 TL-S) MIL Comes on with ETC P0171 or P0174 (Fuel To lean)
TSB 08-049: (2004-2006 TL) NEW Drive Belt Auto-Tensioner Replacement Instructions
TSB 08-050: (2007-2008 TL Navigation) Time On display Change Randomly but Never by exactly 1 hr.
TSB 08-054: (2004-2008 TL) Poor AM or FM Reception
TSB 08-057: (2007-2008 TL) HFL Doesn't Work, Car hard to start or No start
NOTE: Above link is not working. Please click here to open the PDF.
2009:
TSB 09-001: (2008 TL) XM Notes are Duplicated; Wrong Map Colors When Off Route; Wrong Image Appears During Talk Button Tutorials; Off Road Tracking "Bread Crumbs" Disappear (first 1/2 mile) After Ignition Cycle
TSB 09-047: (2006–2008 TL) Door Mirror Does Not Work Properly
TSB 09-056: (2007-2008 TL) Fuel Cap Warning Message is on W/O DTC Code If the link doesn't open, click here for the TSB PDF.
2010:
TSB 10-008: (2007-2008 TL) Switchblade Key does Not Lock in Extended Position
TSB 10-014: (2004-2008 TL) Power Window Goes UP and REVERSES on it's Own, Is Slow to Open and Close, Or Squeals, Creaks, Clunks, or Clicks
TSB 10-017: (2004-2008 TL without Navigation) XM Information is Displayed, but there is NO sound
TSB 10-028: 2011 Acura Paint Codes
TSB 10-031: (2008 TL) In Florida, Navigation Unit Reboots When Destination Is Entered
TSB 10-035: (2007-2008 TL) Drive Belt Squeaks
2011:
TSB 11-004: (2004-2008 TL 6MT) Clutch Pedal Pops, Squeaks, or Clicks
TSB 11-007: (2004-2008 TL ALL) Knocking or Vibration While Driving
2012:
TSB 12-020: Safety Recall: 2007–08 TL Power Steering Feed Hose Leak
Ron A is online now
The following 29 users liked this post by Ron A:
ackyourah (03-04-2012), AcuraPote (01-24-2013), arrowpig (10-16-2012), av2600 (04-04-2012), carcrazy (04-03-2012), CrownTypeS (12-25-2014), Davidkelly (06-27-2012), dbooksta (03-28-2013), deepen03 (03-01-2012), DMZ (06-01-2012), Flip 2 (06-30-2015), gilla_monster (12-08-2011), J1simon (07-10-2012), JJTLTYPES (09-25-2012), Krzyskome (05-12-2013), mattymattB (04-14-2015), Pair of TLs (02-16-2013), paperboy42190 (12-05-2012), PeterF (10-09-2014), polobunny (11-25-2014), serbj (06-21-2012), Shoot2Thrill (10-12-2012), TheHypnoToad (01-06-2012), tomlinsonj (11-23-2011), trance957 (08-27-2012), trehman (10-30-2012), VegasMike007 (02-18-2013), Vlad_Type_S (05-30-2013), v|nsan|ty (06-24-2012) and 24 others liked this post. (Show less...)
lanechanger
10-13-2015 10:56 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
2ManyHobbies
09-24-2015 09:23 PM
flybyglass
09-24-2015 01:12 PM
JOE COOL
2G RDX Problems & Fixes
09-24-2015 07:15 AM
Quick Reply: 3G TL Technical Service Bulletins (TSB'S) 3G Garage #J-016
