DIY Brake Switch
Old 03-18-2007, 01:11 PM
I'm stock and hating it.
lokee99's Avatar
DIY Brake Switch
I'm not sure of the actual name I just got the part no. from Fsttyms1 and went and pick one up from Acura for about 48 bucks. The problem I was having is when I depressed the brake my brake lights didn't come on and my parking lock would not release. So I couldn't shift from park without using the manual release near the shifter. Didn't see a DIY for this so I did one.
Here is the part I bought.
Then I took this screw out to take the bottom panel from under the steering wheel.
Here is the Bad switch.
Loosen this nut to screw the switch out. Believe me don't try to loosen the other one. It dose not move. I know, I tried.
Now take the connector off before you turn the hell out of the wire.
Now take the good switch and screw it in till the black part of the switch is being depressed by the brake. Then tighten the nut you used to loosen it and reconnect the connector and your done. Back to normal BABY!!!
The following 3 users liked this post by lokee99:
BLADE RUNNER (01-27-2015), Curious3GTL (08-09-2015), Undying Dreams (06-05-2014)
Old 03-18-2007, 01:15 PM
lokee99's Avatar
Part# 36750-S84-003 SWITCH ASSY., STOP & CRUISE
No its not on the floor. Its located further up on the brake pedal. Part# 3
Old 03-18-2007, 01:44 PM
Make sure to have a friend stand behind the car and tell you when the brake lights come on as you push the pedal.
There is a range of adjustment provided by the 2 nuts and you want them to come on as soon as you get on the brakes, not halfway to locked!
If you are wanting to outfox and outbrake the competition on the track, adjust so lights come on late
Old 03-18-2007, 02:12 PM
imprezagtr's Avatar
Cool!! def comes in handy when that problem occur. Stick it please!!
Old 03-18-2007, 04:07 PM
NiGhT rIdEr
bkzjimmy's Avatar
good info mine gets stuck once in a while and i have to push it in wit my finger and let it pop out.
btw, there a DIY section in case u didnt know.
Old 03-18-2007, 05:03 PM
xyrcncp's Avatar
Nice DIY. I remember this was the first car part I ever changed myself when I used to drive my 84 Chevy Celebrity in HS...lol
Old 03-18-2007, 05:14 PM
bk
try some wd40 in the general area of the switch opening- see if that frees it up for you
Old 10-06-2007, 01:37 PM
Thanks for DIY...saved me $75 labor that I would have spent at Dealer.
Old 12-21-2007, 08:44 AM
DiegosAnotherR1's Avatar
great post. got to do this to my girlfriends car today after work.
Old 12-21-2007, 12:31 PM
acutee's Avatar
Very nice.
Old 01-21-2008, 07:22 PM
lavoieste's Avatar
i'm next
Just started on me today! I thought oh no big deal till i get a chance to figure it out. Then i read a few threads and realized..hey stupid you have NO BRAKE LIGHTS!!!! CRRRRRRRAAAAAAAAPPPPPPPPPp\
To the Top of the To Do list it sits now.
I have to go and get the part tomorrow for an evening swap out.
Thanks everyone. Gotta love forums! Best info around.
Old 01-21-2008, 09:56 PM
Originally Posted by lavoieste
Old 01-21-2008, 10:26 PM
hates the winter
ChrisQ1980's Avatar
Nice write up, this happend on my 90 Grand Marquis and it was a bitch to do. lol Now I know how to do it if my TL ever needs it.
Old 01-22-2008, 09:30 PM
lavoieste's Avatar
DIY to the rescue......
All done! nice and easy. Thanks again.
interesting factoid..
called the local Honda shop gave them the part number and they said it was 44.12 sounded good to me. But for the heck of it i figured I would call the Acura dealer 3 miles down the road from the Honda dealer to see how much more they wanted for it. ( might as well have some fun). Called and my jaw just about hit the floor they were 9 dollars cheaper than the Honda shop. ?
Anyways. It is an easy fix.
Love Forums! Gonna change the clutch in my 99 Vette this spring with DIY with the Corvette forum.
P.S.
fsttyms1 sorry about the Packers! They are my 2nd favorite team. I love Farve!
Go Patriots!
Old 01-23-2008, 07:03 AM
P.S.
Go Patriots!
Old 01-01-2009, 06:40 PM
niju321's Avatar
great diy! saved me $$$ at the dealer.
Old 01-01-2009, 07:30 PM
kakins23's Avatar
NICE!!!!!!
Old 01-01-2009, 09:59 PM
nf3d0149ab's Avatar
Nice DIY.
Old 10-20-2009, 06:01 PM
shizzytheking's Avatar
what did you use to loosen the nut before you took off the bad switch is there anything you can use besides a 14 or 15mm wrench???
Old 10-20-2009, 06:19 PM
Sorry, but What else would you use? Get the proper tools. You might be able to use a small crescent wrench.
Old 01-12-2010, 12:55 PM
Crazy Bimmer's Avatar
Would this also cause the brake fuse to blow often if the brake switch is bad?
Lately the car has been blowing the brake fuse and when that happens the shifter will lock and no brake lights. Replace the fuse then the car is fine for a day or so but will blow again. Im stumped.
Old 01-12-2010, 01:52 PM
It might, have you checked the wiring by the tail lights to see if something is bad or grounding out?
Old 01-12-2010, 05:41 PM
Checked the wiring in the back, looked fine and even changed the bulbs and inspected the sockets. Everything looks fine. Its never been rear ended so all wiring is still same as factory. This is on an 02 RL though. Brake fuse will blow when the brake is pressed at startup. So either something is grounding out someplace or its the brake switch...
Guess I will change the brake switch and see what happens from there. Great thread btw.
Old 03-01-2010, 06:38 PM
But I just got here
Nitin's Avatar
Awesome DIY! My only question is, how do you remove the connector from the switch? I've tried everything but just can't seem to get it off.
Old 03-01-2010, 07:08 PM
soria's Avatar
You just need to press down on that tab the arrow points too and pull.
Old 06-08-2010, 08:10 PM
Neejay's Avatar
Perfect! Thanks a lot!
Old 08-08-2010, 09:42 PM
KKS_TLS's Avatar
I have the same symptoms my 2002 TL (no brake lights, shift geat locked in park). I replaced the brake switch but it didn't help - great thread btw. Is there any other resolution for this?
Old 12-15-2010, 10:44 PM
zac
zac's Avatar
This DIY was great! Thanks!
I had been using the manual override at first not realizing what was going on and when i researched the problem I realized my brake lights weren't working either, so that made me hurry up and fix the issue.
Picked up the part from a local parts store (it was about 5 bucks cheaper than the dealers) Took about 10 minutes, just don't forget that the one outside nut doesn't move and its the switch/sensor that turns.
Old 10-06-2014, 12:59 AM
hjeb's Avatar
Lightbulb Need HELP
Hello,
I have the same problem with my acura tl 1999! Did anybody find the solution??
Please helppppp
Old 10-06-2014, 07:45 AM
3.2TLc's Avatar
Brake Switch.......
So either something is grounding out someplace or its the brake switch...Guess I will change the brake switch and see what happens from there. Great thread btw.
Welcome Hjeb !!!
Have ya checked all the wiring and connectors to the rear brake lamps, including the high mount ?
Old 10-09-2014, 04:00 PM
hjeb's Avatar
Hey, Did you find what was the problem with your Acura TL? I had the same problem with my brake light, and stop fuse is gone several times
I really appreciate if you could let me know what was the problem in your Acura?
Old 10-09-2014, 04:02 PM
hjeb's Avatar
Originally Posted by 3.2TLc
Welcome Hjeb !!!
Hello,
Thank you.
Yes I did, It looks ok.
Is it possible that the problem came from brake switch?
Old 08-09-2015, 07:01 PM
amg2y's Avatar
Originally Posted by 01tl4tl
bk
I sprayed the switch with wd40 and it works again.
Save me some $$$.
Old 10-31-2018, 07:25 AM
Curious3GTL's Avatar
So my Brake lights don't work and I can't shift out of park without releasing the gate shifter, but my cruise control does work? Why? This is for a 2000 TL.
Old 10-31-2018, 07:34 AM
Received 8,584 Likes on 6,630 Posts
Replace your brake switch
Curious3GTL (10-31-2018)
SidhuSaaB
05-30-2020 12:40 AM
blacktsxwagon
10-27-2015 10:12 PM
2ManyHobbies
09-24-2015 09:23 PM
eastcoastguy
09-23-2015 06:29 AM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: DIY Brake Switch
