Bulb Application
Sippy Cup (x2)
Bulb Application
Not sure how useful this will be but I've seen a couple threads here and there for people asking what size bulb goes where. So here is the complete list.
1999 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen Upgrade: Up to 20% Brighter
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
7440
Tail light
7443
Stop light
7443
High mount stop light
7440
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
1157A
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
2002 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1156A
Tail light
7443
Stop light
7443
7440
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
168
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
1999 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
7440
Tail light
7443
Stop light
7443
7440
License plate
168
Back up light
921
Front sidemarker
1157A
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
2002 ACURA TL
Low beam headlamp
HID-D2R
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1156A
Tail light
7443
Stop light
7443
7440
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
168
Map light
168
Dome light
DE3175
Step/Courtesy light
158
Trunk/Cargo area
168
The following 7 users liked this post by snowman81:
Bricktop (02-18-2014),
cheekoo (02-06-2014),
GraveDigger (01-05-2014),
kmarqueling (03-04-2014),
Ndanny (06-06-2014),
and 2 others liked this post.
umm, looks like he just used http://www.sylvania.com/ConsumerProd...lacementGuide/
..dun rly need to be stickied IMO.
Are 194's interchangeable for the 168's? I've noticed that there are more aftermarket options for the 194s. What I really want are ultra bright white license plate bulbs....and I'll probably get the silver bulb (but blink amber/yellow) for the front turn signal since the lens itself is clear.
Does anyone know what bulb sizes are in the AC, and the Cluster Guide? I know shifting knob has #74
There's kits on ebay but they do not say the bulb sizes...
i was gonna get me some led lights for my map and cortsy light and my door panel lights but when i went to autolumination.com they only got 194 but on the title it says 194 and 168. are those the same or what and which leds should i get
AZ Community Team
Received 7,770 Likes
Every porn dvd in a
before you buy the bulbs, make sure they are the correct size, don't get too small and don't get too long... I ordered 194 SMT III 38mmx11mm x18 LCDs thinking 18 lcds are pretty damn bright, they are, but they were too long, wouldn't fit inside the housing for the map lights. The biggest you can fit in the map housing is 30 mm, maybe 32, but I would go with 30 mms. And the festoon bulb for the dome light 3175 bulb, get size 36 or 37 mm, don't get 31 mm, too short, it'll work, but it won't sit well. And if the bulb doesn't work, just rotate the bulb 180 and it should work. Hope this helps.
2001 TL- guessing its from 99-01
OEM 168 bulb size 25mm
Map Light -168 bulb size 30, maybe 32mm
Trunk Light - 168 bulb size 28 mm
Dome Light 3175 size 36-37mm
thanks for the list - just want to confirm. My 2000 TL (stock everything) 's driver side low beam bulb is gone. (the one that is white)
Is this the correct replacement? Just want to confirm before i order it.
Low beam headlamp
HID-D2R
And the DIY for this is - https://acurazine.com/forums/2g-tl-1999-2003-98/low-beam-installation-631575/#post9056124 and https://acurazine.com/forums/2g-tl-1999-2003-98/diy-installing-headlight-bulbs-2nd-gen-tl-%5Bpics%5D-872082/, correct?
Thanks in advance
Low beam headlamp
HID-D2R
Thanks in advance
need a quick help. I installed the bulb I bought above in the left headlight. Now it is not focused on the ground like 10-20 feet away, but like 50-70 feet. If I am parked in garage and turn these on, the left one focuses quite above the right one vertically.
Is there any way I can adjust the height to make the visibility better?
thanks!
thanks!
Hey Cheekoo, as mentioned.....if ya were not previously having the issue prior to replacing the headlight bulb, then recheck your work.
If things still don't seem right, there are adjustors for headlight aiming. Check previous posted threads for the procedure. Was the car wrecked ?
nope, i dont think there was an issue before.
Car has not been in a wreck.
I will check the placement and housing this weekend. thanks for the responses. Will post here what i find.
