Bumper removal help/ HID install help
hey everyone
me and a friend are installing HIDs on his 02 TL which came without HIDs
does anyone have a DIY on how to install/remove bumpers?
i tried searchin for bumper removal but way too many results and i have to go to work
i would really appreciate it if someone can give me instructions on installing HIDs and removing bumpers
::realizes he looks like a noob right about now::
thanks a lot
thanks a lot
03 ABP tls
look up headlight removal along those lines theres tons of stuff. all about unscrewing andf removing the screws and thats it
from : https://acurazine.com/forums/showthr...dlight+removal
The basics are
Remove the front bumper:
1. First, remove the black plastic piece that covers the radiator support by removing the plugs using a flat head screwdriver while not forgetting the small plugs on either end of the grill.
2. Remove the screws inside each front wheel well towards the upper corner where the bumper meets the fender. Since the pics are down, you may want to crank the steering wheel in the opposite direction so that you can stick your head in there, and see it better.
3. Remove the plastic plugs & bolts on the underside of the bumper that connect it to the plastic undercarriage tray. They will be more visible when you get under the car.
4. Unplug the fogs
5. Pull the bumper forward to release it from the clips holding it on
Now the headlighst will be clearly visible, so
6. Disconnect all the plugs for the low beams, highs, turn signals, etc.
7. Remove the exposed bolts on the top (under the hood), and bottom of the headlamps.
That should be it.
The basics are
4. Unplug the fogs
That should be it.
cycdaniel
12-17-2019 10:58 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
