| New! Use your Facebook to securely log into this site, click logo to login |
| Welcome to Acurazine.com! |
Thread Tools |
#1 | ||||
Need more discretionary $
I-160: USA Spec Install
2006 Acura TL - Anthracite/Ebony 5AT W/NAVI Comptech RSB, Wing Spoiler, Tint, USA Spec Module, SMT Tower 194 License Plate LED's, TL-S Marker Lights, Bridgestone RE760 Sports (245/40/18), A-Spec Wheels (Ebony Chrome), A-Spec Suspension, A-Spec Brake Pads, Front A-Spec Spoiler, CF Engine Cover |
| Sponsored Links | ||
#2 | |
LIST/RAMEN/WING MAHSTA 짱
2007 Acura TL |
Clean install, BTW!
'07 NBP TL Type-S 6MT
Click --> "From a Lifesaver to a Soulsaver" Click --> Mods List EPIC THREAD - Azine Love |
#3 |
^^Thanks for the compliment on the install.
Regarding that notch - I didn't know it was there either! I was trying to figure out how I was going to get the arm rest to close when I had the Touch out; I looked down, and there it was! I was VERY pleasantly surprised. Many thanks to the engineers at Acura who had some foresight on this.
#4 | ||
Just to consolidate some of the information on these installs into one spot, here are a couple of good comments about installation:
From Budman231 (http://tl.acurazine.com/forums/showt...39#post1945239) Post #51: Quote:
Hopefully, for the sake of future searches, this will help a bit.
#5 |
USA Spec + ProClip = Good
Ok, so I installed the USA Spec HON2y in my car, 3GTL (2004).
It went smoothly and works well. Time will tell if I have the skipping issue, but so far, I haven't. I decided to install the USA Spec under the steering wheel panel, in case I needed to pull it and do a swap for newer firmware at some point. I followed the instructions as posted in the PDF above, but I had to pull the radio out a bit more, 'cause I have big hands. :-) The only strange thing is that when I plug in my iPhone, I get the pop-up about "This accessory is not made to work with iPhone" -- I choose No (don't use Airplane mode) and everything seems to work fine. (I will edit this post in a few minutes and add the pics). |
#6 |
USA Spec + ProClip = Good (Cont.)
{Sigh}
I only had 5 minutes to edit my post... oh well. here are the pics. iPhone mounted on the dash: Close up: I ran the AUX from the HON2y into the center console: Annoying popup: I don't remember reading if anyone else had this issue or not... So here's the total: $25.00 ProClip iPhone Padded Holder #870168 $11.00 ProClip Vertical Extension Plate #213065 (so that my iPhone wouldn't block my airvent) $30.00 ProClip Acura TL 2004 Center Mount #853464 $150.00 USA Spec HON2y (purchased at Crutchfield.com) ----- $216, plus a few dollars here and there for shipping and tax, probably another $30 or $40 dollars. A friend helped me install it, so I saved a bit there, but overall, very affordable, and IMHO very professional looking. Enjoy! |
#7 |
DMoyes - thanks for adding to the install information in this thread. Glad some of this information helped out.
Regarding your placement of the iPhone, AcuraTL06 originally installed his up front and found some interference issues with his center speaker (he's using the Dice unit). Have you noticed any similar problems? See post #30 in this link: http://tl.acurazine.com/forums/showt...98#post1965798 BTW, this is my 500th POST!!!! ![]()
#8 |
I've only had it installed since Saturday afternoon, and I didn't get to drive it today. :-(
But, it's been mounted there for almost a month, before I bought the HON2y, so I don't think I'll have any problems. I do have an hour drive to a client tomorrow, so I'll see if there's any interference... but so far, it sounds great... I was worried, because I was used to hearing the GSM buzz through the tape deck occasionally. I'll keep you informed. Oh, and congrats on your 500th post! |
#9 |
Green Machine
I found this on ebay. http://cgi.ebay.com/ebaymotors/2004-...em360026145520 I want to do the adapter install in my 04 non-nav. Is this all I need for the install? Is this just as good as the Dice unit?
#10 | |
Regarding your question, is it "as good as" the Dice unit - you need to decide which features are important to you, etc. There is no text option on the USA Spec. However, if you use the XM radio in your car, then you may not want the text option (which was the case for me). You'll find plenty of posts and threads here from people telling about the various features of each. Also, there's a member here on the forum (Nick@Dice) who works at Dice and is a big help to other members. You could PM him for some ideas as well. Best of luck!
#11 |
Green Machine
Thanks for your help. I do want the option of text since I don't use my XM radio.
#12 |
Update
Ok, I've been using it mounted this way for about a month now, and I haven't had the skipping issue, not even once.
Also, I haven't noticed any interference with the center speaker. I do sometimes hear the GSM buzz, through the stereo, but it's very, very soft, and doesn't happen very often. I can only hear it when the music (or podcast) is very low, or sometimes between songs. Mostly I don't hear it, though. Overall I am very happy with this solution and will strongly consider USA Spec in the future. |
#13 | |
I'm curious - did you set up your USA Spec in Hybrid mode or in the dedicated iPod control mode?
#14 | |
So, yeah, direct, I control it using the touch screen, but I can still skip forwards / backwards with the steering wheel control. No matter what the stereo is set on (FM / AM / CD / XM) it switches to CDC when you plug in the iPhone, which works perfectly for me. Also, if I have the iPhone on "paused playback" when I plug it in, it continues from there. The "accessory not made for iPhone" screen goes away by itself after a few seconds if you don't touch it. If you've just taken your iPhone off the charger in the morning, and you plug it in, it simply starts "All Songs" playing... but it doesn't do it in Shuffle mode. Hope this helps. |
#15 |
so can you still use xm with this with navi?
#16 |
08 NBP Type S Sucka !!
i think you can use XM but with no text on your cars radio
#17 | |
#18 |
does the USASpec adapter works and charges the iphone.?
#19 | |
#20 | |
#21 |
fellow MASShole
well kit came in the mail yesterday ... this will be my project for the day
#22 |
fellow MASShole
well im havin problems..
everythings installed but the head unit isnt recognizing the ipod ?? i have an 04 non nav the funny thing is that i cant even get to the XM anymore??? the button doesnt even do anything i removed the aux pin plugged it into the Y adapter and then plugged the USA unit into the back of the headunit .... nothin ... any ideas?? |
#23 | |
Try removing it completely, and see if XM comes back. Make sure the unit is in Direct mode. Hope this helps. |
#24 |
fellow MASShole
sorry for the slow reply .. turns out im an idiot the plug from the back of the headunit wasnt on all the way
everything is all set and working great ... 04 non navi only took about 40 min once i figured out what my problem was |
#25 |
got mine installed the other night! i love it. I actually went ahead and threw a slim PS2 under the driver seat while I had the dash apart! works like a champ! thanx for the great write up!
#26 | |
#27 | |
#28 |
A-spec steering wheel ftw
mmmm this is sounding better and better! imagine all the money saved from not burning CD's/DVD-A's anymore? lol
#29 |
Wish I had a Carrera.
This thing is awesome!!
Hello all!! I just registered to this forum and it is awesome!! I just installed this adapter and it works quite nicely... The install took all of 30 minutes is quite simple... Thanks for all your help!
#30 |
would my 6-disc player work with this? I have an 08 TL navi.
#31 | |
2007 Acura TL |
#32 |
Just installed it. But I had a problem where the unit just buzzed out and stop playing. Unplugging and replugging the ipod fix it. Hopefully it doesnt happen again. I have an Ipod classic (5.5 gen?). I also notice my speakers popped once or twice. And I broke a clip by the steering wheel
If my problems dont come back then Ill be very happy. Got the unit for $110 shipped and about 2 hours to install cause Im total noob. I would have gone with DICE but it locks your ipod, and I cant have that. OH yea thanks so much for this helpful thread! |
#33 | |
Mega Moderator
2010 Honda AccordMy Garage |
#34 |
"Advance"
Is there an Audio Jack INPUT in the USA SPEC ?? or is it only made for IPOD??
#35 | |
#36 | |
Full of water...
2006 Acura TL |
there is a left/right input for another device like a DVD input or something, but i believe it is only meant to "control" an ipod. i a going to use this input for my TomTom, so i can play movies and have the sound run through my car speakers but question...i was reading the directions, and for some reason i keep thinking it needs to be in Hybrid mode in order to access that input port, does anyone know if that is true? or can i still presss "CD 6" or whatever and still access it in Direct mode? i want to do Direct, but i also want the other input to work as well...
2006 NBP 5AT navi-lessCurrent: - A-Spec Ebony w/ Pirelli Pzero Neros, A-Spec suspension, body kit, steering wheel, badge - Supercomputer pedals - All-season OEM mats- LEDs interior/exterior- Driver door lock shave - "Custom" radar and TomTom install - P2R TBS - AEM CAI. - Pedal Lock - Optional carbon fiber interior trim - Blue Batmobile overlays - Hoen Endurance fogs -ATLP race & j-pipe- USA Spec - Racing Brake pads and rotors Future:- Progress RSB, UR pulley, more ATLP bling |
#37 | |
Mega Moderator
#38 |
'08 TL non-Nav
I'll be having one of these for sale next week (the PA11-HON2y). PM me if interested.
#39 | |
#40 | |
Full of water...
2006 Acura TL |
i just installed mine today and i am SOOOOO happy!. finally, no more tape hiss. plus, i got my TomTom hooked up to it so i can listen to the movies through the car speakers. i havent really tested it out much yet, but from my initial playing around i am really happy.
| Thread Tools | |
