Unofficial How to: Remove Transponder From 04-06 key thread!
Old 06-15-2008, 09:24 PM
izmyttz's Avatar
Yup. I got my Switchblade keys in. I am a very impatient person. So I decided to hack up an existing key that I had for the car because it was Saturday and the dealership was closed. It actually came out just fine. Removed the transponder and put it in the new key successfully. Here are quick tips and pics. No extensive detailed walk through. Just figured you guys would want to know just in case you got adventurous.
Steps:
1. Get key that currently is programmed to your car.
2. Get a serrated knife or small skinny saw (I used a SOG serrated knife)
3. Pop Acura symbol out of center of key...if you want.
4 Hold key with a hand cloth or small rag/towel to keep from cutting into hand. Or just use a counter mounted vise
5. Saw the sides of the key.
6 Use 2 sets of plyers to pull key apart.
7 Remove transponder plastic holder
8. Remove transponder from holder.
9. Take switchblade key apart and install the new transponder.
10. Reuse the old Acura emblem and personalize your jewelry!!!
Pics. Enjoy
Transponder chip
All Parts
New Key
Bling Bling Acura Things!
There you have it..the first How to Destroy your Key Pictorial!
Old 06-15-2008, 10:28 PM
chinesestunna's Avatar
awesome write up thanks! Where did you get the switchblade key that is compatible with 04-06 TL?
Old 06-15-2008, 11:34 PM
Fulani has a TL's Avatar
nice pictures. You know what you could have done was just cut the rubber off the key, so you still have the whole key intact and then just pull the rubber apart, and the chip is in the middle of the key as you realized.
Old 06-16-2008, 02:03 AM
steeez
ecliptics's Avatar
^his directions say to cut off the rubber but it looks like he twisted it with the plyers to break the seal and then rip off the rubber?
in the switchbade key how did you get the key off to get to the immobilzer? i understand how to take it apart in your 1st pic with it, but howd you get to the immobilzer part. after that do you just swap them? thanks
if its that easy, maybe ill just do that instead of getting it programmed for 60bucks..
how long it take you?
Old 06-16-2008, 07:41 AM
Quiet, Rika Neenja!
SRT-11's Avatar
dremmel would accomplish this much more cleanly I would think. where does the chip go in the new key? someone post a how-to swap the metal key portion of our key into the switchblade, that would be nice!
Old 06-16-2008, 08:19 AM
Tripnbeats's Avatar
i would put the key in a vice n press the corners til it cracks n then use a dremmel.
Old 06-16-2008, 09:59 AM
sixsixfour's Avatar
Id like to know where you put the trnasponder too. how did you get it to work with the switchblade?
Old 06-16-2008, 10:04 AM
Tripnbeats's Avatar
good work though....thanks for the write up dude!
Old 06-16-2008, 12:01 PM
izmyttz's Avatar
yes this sounds like a better way..however i was at my office..only had a few tools. we twisted the key to crack the plastic head. I would have just sawed the key but i had no clue where the transponder was exactly and i didn't want to saw it.
Old 06-16-2008, 12:04 PM
izmyttz's Avatar
in this picture i'm using the screw driver to point to the transponder on the switchblade key. the key has 4 screws that hold it together. one on the back near the key ring loop. and 3 inside holding the key onto the housing. these have loctite on them..they are very hard to get out without stripping.
Old 06-16-2008, 01:01 PM
Quiet, Rika Neenja!
SRT-11's Avatar
I have an idea, could you take both keys apart and have someone that's good at welding cut and weld the old key onto the new one and grind it down to be flush? is there feasibly any way to switch the old metal key body into the new key?
What did FLBUSA use to mill these keys? I sincerely doubt it was the only machine of it's kind in the friggin universe, we have to find someone that can do this!
Old 06-16-2008, 01:14 PM
iScrape going into
Distorted Reality's Avatar
It has been done deltaboxxx was able to do something close to that. pm him about it. He has a thread where it shows exactly what he did.
Old 06-16-2008, 01:59 PM
aztec209's Avatar
Did you get the key already milled or did you mill it??
Old 06-16-2008, 10:04 PM
izmyttz's Avatar
yeah i ordered them from oakland acura before they sold out.. i have one left ..i may sell it
Old 06-17-2008, 03:52 PM
Edwardlanti's Avatar
Hey your private messages are full.. I am trying to respond to you but I cant
Old 06-17-2008, 09:15 PM
izmyttz's Avatar
i'll delete some. sorry
Old 06-18-2008, 08:35 AM
Quiet, Rika Neenja!
SRT-11's Avatar
sell to me sell to me!!
Old 11-28-2008, 12:47 AM
substill's Avatar
It's fabulous.I will try my key as your instruction.
Old 11-28-2008, 08:03 AM
sjo
sjo's Avatar
Subscribed thread. Show pics!
EE4Life
04-01-2024 09:42 AM
Gabru678
04-24-2019 02:36 PM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
BoricuaTL
04-08-2016 01:08 PM
whitesoxsfan12
09-13-2015 02:09 PM
Quick Reply: Unofficial How to: Remove Transponder From 04-06 key thread!
