F-CAN Error Codes
Old 07-21-2008, 07:36 AM
cbptls's Avatar
Exclamation F-CAN Error Codes
Anyone know what this error code represents?
Old 07-23-2008, 10:21 AM
hameline's Avatar
Unhappy
There are two "networks" in the TL, one fast controller area network (F-CAN) and one body controller area network (B-CAN), each with connected ECU's
The F-CAN is connected to the gauge control module, the ECM/PCM, the navigation unit and VSA.
I don't have a list of the specific codes, but your trouble is in one of the above. Any other indications of malfunctions?
Regardless, it's trip to the dealer time. At least you know the areas to look at.
Old 07-23-2008, 10:30 AM
cbptls's Avatar
Thanks hameline,
Car was dropped off at the dealer yesterday. They said something about the brakes, hopefully they'll finish up working on it today.
Old 07-25-2008, 09:22 AM
cbptls's Avatar
Modulator Assembly needed to be replaced.
Covered under warranty, otherwise a $709 part.
Old 07-30-2008, 03:55 PM
DivinDude's Avatar
My 07 TL-S has the same code .. dealer said it wasn't an issue
Old 07-02-2010, 11:37 PM
Abeyance's Avatar
Same thing
Does anyone have any further information on this, like if it is or isn't an issue? My '07 has this exact same code/error showing (I can post an identical picture if needed) and it's been there for quite a while. The only problem I've ever had with the car was the Nav freezing and "rebooting" once shortly after I got the car. Since then, never an issue.
Thanks.
Jamus22
06-11-2023 10:08 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
phillyguerrilla
09-26-2015 11:27 AM
Matthew Purpura
09-25-2015 06:10 PM
Quick Reply: F-CAN Error Codes
