Anyone ever use Duplicolor Caliper Paint? Brush on style? - AcuraZine Community
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Acurazine.com!
Welcome to Acurazine.com.
Old 08-20-2008, 12:46 PM   #1
02CL-TypeS
02CL-TypeS's Avatar
I just bought a brush on Duplicolor Caliper Paint Kit from autozone, but am thinking about taking it back. I've read around and it seems like the paint does not hold up well very long and flakes off b/c of brake dust and salt during winters.
Just wondering what you're experiences have been with the brush on paint(not spray!). I'm considering buying the G2 Caliper Paint kit b/c it is an epoxy rather then enamal.
I don't want to use spray paint b/c I would like to paint the calipers while they are on the car
2002 SSM Acura CL Type S
05 Acura TL rims, XS Power Headers, CAI w/AEM Dryflow Filter, Red Calipers, Infinity Basslink 10" subwoofer, Magnaflow 14832 mufflers, Tokico Blues, H&R Sport Springs
02CL-TypeS is offline   Reply With Quote
Sponsored Links
Old 08-20-2008, 12:52 PM   #2
Cdat
Slow Paper> No Paper
2005 Acura TL
Cdat's Avatar
I think Kennedy did his with the brush on paint hit him up with a PM.
05 TL Auto w/Navi
NBP/CAMEL, 5% Tint, Rear Wing Spoiler, Splash Guards, Blue/ White LED's, Lower Mesh Grill, Type S Tail Lights, Fujita CAI, P2R Throttle Body Spacer, Sun Voltage Battery Regulator, NRG Hyper Voltsage Kit, Powder Coated Engine Manifold Cover, Bosch Icons, Cleared Head Lights w/ LED Switch Backs
Cdat is offline   Reply With Quote
Old 08-20-2008, 1:27 PM   #3
gatrhumpy
My other ride is an E-6!
gatrhumpy's Avatar
I did this with my Accord, and it's help up great! The only thing that I did differently that everyone else is to grind down the dust and the calipers with a Dremel before you paint it. It still has help up perfect after two years with no re-application.
2004 Graphite Pearl Accord EX V6 with navigation
My other ride is an E-6. :D
Here's what's new in Jacksonville! http://www.outandaboutinjax.com/
gatrhumpy is offline   Reply With Quote
Old 08-20-2008, 1:34 PM   #4
HONgDA
2005 TL (7/07-8/29/09)
Trader Rating: (1)
I use spray can high temp black paint and several clear coats. It is more efficient and it holds up very well. NO chipping yet. I only needed to do the rears.
HONgDA is offline   Reply With Quote
Old 08-20-2008, 1:36 PM   #5
TeknoKing
CKOPOCTb
2008 Acura TL
TeknoKing's Avatar
I've used it on my 2G TL, as long as you sand the caliper for a smooth finish, the paint is awesome, but after a rough winter, does require reapplication in the spring... But it's cheap and does the job.
HaPPy TLing!!!
TeknoKing is offline   Reply With Quote
Old 08-20-2008, 2:06 PM   #6
02CL-TypeS
02CL-TypeS's Avatar
I guess I'll just keep it. It was only $17. I just don't want to ever have to repaint the calipers again lol...and I'm doing it right before winter at this point
Old 08-20-2008, 3:54 PM   #7
01tl4tl
Just a little touch up is needed on them from time to time- the can has enough paint to do 5 cars-
Its just as easy to apply another full coat when you do touchup- so they always look azine meet, show-car ready
caliper paint-Not the toughest material known to mankind- so it will get chipped
Use the prep spray cleaner in the kit, apply 3 coats- read the can directions on painting- they differ from the box
130 grit sandpaper or wire wheel or wire brush to rough the surface never hurt- good paint is 90 percent in the prep work
Take your time- enjoy- buy extra foam brushes and some smal flux brushes- the paint dries quickly and you need a new tool for recoat layers
Best to remove calipers and brackets to paint- clean and grease the calipers and pads while there- reassemble- touch up- done
Old 08-20-2008, 4:37 PM   #8
LoveMyTL-S
2008 Acura TL
LoveMyTL-S's Avatar
I used that kit when I had the TSX. Painted calipers red. Cleaned them really good. I used break cleaner and sprayed them as well. Dries quick. I then applied 4 coats of the paint. I just went around to each caliper and applied a coat. By the time I got around to the first one it was dry. Held up pretty well. Good luck with your project.
2006 Honda CR-V (Sahara Sand Metallic)
2003 Nissan 350Z (Chrome Silver)
LoveMyTL-S is offline   Reply With Quote
Old 08-21-2008, 11:09 AM   #9
02CL-TypeS
02CL-TypeS's Avatar
Well I started last night. I only did the front calipers. I did 5 coats each and will be doing 5 coats each on the rear tonigt. They look sick in red
Old 08-21-2008, 2:02 PM   #10
01tl4tl
5 coats!!! I thnk you set a new record! they will hold up well to abuse now!
Paint the rears black- they are such tiny calipers- do you really want to call attention to them ?? or be stealth about them -
and let the red fronts pretend they are a BIG brake kit~
Old 08-21-2008, 2:47 PM   #11
mmade22
200,000 mile club
2005 Acura TL
mmade22's Avatar
Red is the way to go......I did a diy on how I did mine.......
GunMetal 8.5 A-Specs/H&R sport springs/koni yellow struts Custom Blacked out grill (DIY)/Custom A-spec Embroidered floor mats/CAI/Cleared out headlights/ slotted/drilled Stoptech rotors/Custom painted brembo calipers (DIY)/A-spec kit/smoked sides/07-08 base tails tinted in the corners/Type-S rear aspec with the type-s exhaust (DIY)/RF 3sixty.2 processor/Alpine PDX150/cadence sub amp/10 inch pioneer sub/Image Dynamics 6.5 components
mmade22 is offline   Reply With Quote
Old 08-21-2008, 7:16 PM   #12
anx1300c
I used the Duplicolor paint a couple days ago on my rears. I went with black to match the front Brembos. I did them on the car, only painting what's visible from the wheel well. If my car was a show car, I would've gone all out. I did clean them up well though, using the supplied cleaner and some Simple Green and various dremel attachments.
06' 6MT NBP, AEM, P2R, UR Pulley, ATLP J/Race Pipes, Excelerate/Billy Boat Resonated Cat-Back, V1
anx1300c is offline   Reply With Quote
Old 08-21-2008, 9:05 PM   #13
02CL-TypeS
02CL-TypeS's Avatar
just finished my rears. Five coats on each caliper(really shined them up)....man do they look good even if they are small. It really gives my ride some more character and blends in nice with the Type-S badge. I'm gonna post some pics up tomorrow of the calipers without the wheels and then with the wheels on.
BTW, to you guys wondering why I posted here when I have an 02 CL-S...this section gets viewed the most
Old 08-21-2008, 9:13 PM   #14
terminex
Terminex
terminex's Avatar
did it on mine
I did mine (front & rear) about 2.5 years ago using the same duplicolor brush kit. I have had no problems. (I did scrub the hell out of them first using brake cleaner (about a can per caliper) and a brass brush.
Terminex
2005 Anthracite Metallic
Cleared headlights
custom lower fog lights
Window roll-up module
shaved door lock mod (exterior)
"chopped" door lock (interior)
2007 TL-S Tail lights
2007 TL-S side marker lights
2007 TL-S Switchblade key
2007 TL-S spoiler
Cold Air Induction
Lighted door sills
PIAA reverse lights
Debadged
Color matched plate mount
Color matched splash guards
Carbon Fiber Blackwood shifter
Tinted Windows
Navi hacks
Nav 2 TV, USASpec iPod, & reverse Camera
terminex is offline   Reply With Quote
acura, acurazine, caliper, calipers, color, dupli, louis, paint, red, sale, spray, st, tl, tsx, types
Advertising Information - Contact Us - AcuraZine -
Top
