5AT Filter Cartridge
Old 06-12-2009, 11:06 AM
NE14RoxCJ's Avatar
For those who don't believe it, here it is. Remove the stock air box and look for the cover on the trans with three bolts and a fluid line attached.
And here's the old and new filters.
Yes, you loose enough fluid to make a good mess. I changed mine after I drained the ATF, but looking at the location of the filter (at the highest point) I don't think it would keep flowing if you did it full.
I like pics, so I thought I'd help others who share the same feeling.
PaulK3 (12-02-2019)
Old 06-12-2009, 11:32 AM
2009 g37s 6mt
ssmtl2nv's Avatar
filter part #
Old 06-12-2009, 11:39 AM
NE14RoxCJ's Avatar
#'s 7, 21, and 2x #24
Filter : 25450-RAY-003
O-ring: 91301-RAY-004
Washers: 94109-12000
About $16 + shipping
Old 06-12-2009, 11:53 AM
sjo
sjo's Avatar
How many Km's is that filter? Thing looks filthy! You've got me worrying about changnig mine now.
Good find!
Old 06-12-2009, 12:51 PM
NE14RoxCJ's Avatar
108k miles. or 174,000 km. yeah, it looked pretty bad compared to the new one. I've changed the trans fluid once on that filter an I think the first owner had the fluid changed also. So 2 or three fluid changes on the orignal filter. I changed the fluid when I changed the filter this time.
Old 06-16-2009, 11:36 AM
LoveMyTL-S's Avatar
Awesome find and looks easy enough to do. Thanks for sharing..........
Old 06-16-2009, 11:38 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Hmmm...does this apply to us 6MT owners?
Old 06-16-2009, 07:31 PM
NE14RoxCJ's Avatar
Nope, just the 5AT. It is rare for these transmissions to have an accessible filter. So that's why I posted it. The 6MT is an entirely different beast.
Old 06-16-2009, 07:44 PM
^^^ Got it. That's what I thought...Thanks!
Old 06-16-2009, 07:49 PM
jimij25's Avatar
good info, gettin ready to change my fluid, guess im gonna get the filter too.
Old 06-16-2009, 11:29 PM
05' AT SSM
KzooTL's Avatar
Ty for this writeup , give me something to do this weekend.
Old 09-11-2009, 02:52 PM
redlinin616's Avatar
well for those of us with a 2007/2008 type s, im not sure that there is one. the transmissions are different. I looked on the website stated before for the part but couldnt find one. maybe someone else knows.
Old 09-11-2009, 02:59 PM
ajs800's Avatar
Is this directly under the air filter or are there additional items that need to be removed? Thanks for the pics! I will make sure to change the next time I do the 3x fluid change.
Old 09-14-2009, 04:20 PM
NE14RoxCJ's Avatar
Pretty sure it was just the air filter box and hose to the throttle body. That's about all that needs to be removed for access.
Old 09-14-2009, 07:54 PM
Acura Cert MASTER TECH
acuratech239's Avatar
princelybug - Not to get off topic from these fine 5AT owners, but us 6MT'ers do have a "strainer", def wouldn't call it a filter though. You have to remove it when ripping the trans apart, as I have done a few times at work. PM if you want more info! Hope all is going well, haven't talked to you in awhile!
Old 09-14-2009, 07:57 PM
Pm'ed.
Old 11-11-2009, 08:47 PM
Lazer187's Avatar
So Do the 5AT Acura TL Type S Have a filter like redlinin asked.?
Old 11-13-2009, 02:48 PM
Quiet, Rika Neenja!
SRT-11's Avatar
I'm going to do the tranny filter swap out tomorrow, just curious how much additional fluid I'll lose when changing the filter? I only have a finite amount of ATF.
Old 11-13-2009, 08:25 PM
dwb993's Avatar
You will lose about the amount that fills that small chamber that holds the filter. Not much at all. Sure can make a mess though.
OP-thanks for posting these pics. Only problem was I did mine a month ago! Coulda used them then.
Should really be added to the Garage in the tranny fluid change section. Replacing this filter is very doable on 04-06 ATs.
Old 11-14-2009, 06:11 PM
Quiet, Rika Neenja!
SRT-11's Avatar
FYI to anyone that hasn't done this, it's a complete whore to do. Albeit it is far from the most difficult thing I've ever done on this car, in theory it's quite simple, just getting that damn banjo fitting out of the way and getting the spring to seat properly and stay in place when putting the filter in, etc ,etc... I recommend getting ratcheting box wrenches and also stuff a bunch of paper towels down in the spaces beneath where the filter is, it saved me the mess.
Old 03-11-2010, 08:50 PM
VENOME1's Avatar
GREAT FIND, VERY EASY AND ACCESSIBLE. SHOULD BE REPLACED AT THIRD 3x3 SESSION. THIS WAY ALL OLD FLUID IS OUT AND IT ONLY GETS CLEAN FLUID.
Old 03-12-2010, 11:48 AM
Red89gt's Avatar
What year TL's have that filter?
All the third gen's?
Old 03-12-2010, 11:52 AM
Majofo's Avatar
04-06
Old 03-12-2010, 03:16 PM
maknwar's Avatar
for 07 tl type s
25450-P4V-013
not sure that it can be changed though
Old 03-12-2010, 03:19 PM
Majofo's Avatar
nope, unless you drop the trans..
Old 03-16-2010, 08:21 PM
Down for a photoshoot?
crzygosu87's Avatar
anybody have torque values for those bolts??
Old 03-18-2010, 11:09 AM
3GTL/1GTSX
tg900's Avatar
So the guy at the guy at the tranny shop said you have to take the motor and tranny apart to get the filter out....what a liar. Charged me $100 to flush the fluid. I know i'll be doing this job myself and for cheaper in 50K miles.
Old 04-01-2010, 02:54 AM
NBP is a pain...
gotkilled's Avatar
any noticeable difference after replacing the atf filter? i'm contemplating replacing the 3rd and 4th gear pressure switch along with this at the same and doing my last 1x3 atf.
Old 04-02-2010, 06:40 AM
myblack04tl's Avatar
I don't think you will notice a difference by just changing the filter but if you have alot of milage on the trans that filter is pretty dirty. I would changed it. I changed mine and it wasn't to hard.
Old 04-02-2010, 07:53 AM
KaMLuNg's Avatar
it is true for the 07-08 models...
Old 04-10-2010, 05:33 PM
NBP is a pain...
gotkilled's Avatar
dang, this is tougher than expected. i'm stuck right now trying to remove the filter cover. it is stuck on there pretty tight. i tried prying the cover off and now the top part of the cover is slightly off while the bottom is still stuck in there.
the banjo and the line are also blocking the bath. i tried to move it over a bit but there isn't much give and i dont want to break the line.
any help guys? thanks
Old 04-10-2010, 06:43 PM
NBP is a pain...
gotkilled's Avatar
blah...took a while but i was able to get it out. just gotta pry out the cover as the seal is holding it in there pretty well. as for the banjo fitting and line you just gotta maneuver it out carefully. i pushed down and moved it over to the right.
the spring was a bit tricky as well. you just gotta slide the filter in slowly and it should catch.
Old 04-10-2010, 06:52 PM
dwb993's Avatar
Glad you got it. I just PM'ed you back---I did not get it until late.
Old 04-10-2010, 07:25 PM
SpiderX1016's Avatar
One tip, get a ratcheting wrench. Something like this
http://www.amazon.com/Gear-Wrench-95.../dp/B000HBDWMA
It will make everything easier. It took me like 15 minutes just to get the bottom bolt off and another 10 to put it back in.
I drained the transmission before taking the filter out. Not much fluid came out doing the filter change.
Old 04-10-2010, 08:14 PM
NBP is a pain...
gotkilled's Avatar
thanks dwb993 and all! took a while but I was glad i did it. the filter looks dirty but it didn't have any stuck particles to it whatsoever.
spiderx1016, i've never seen you around even though you're in Rosemead. I live in TC; pretty much neighboring cities.
Old 04-10-2010, 08:46 PM
heh, I barely got the car 3 weeks ago. So it's still stock. Plus I only drive the tl on the weekends.
It's a silver tl rockin the Phoenix suns license plate frame or ch auto frame lol
I go to 24 hr fitness in Arcadia so I pass by temple city everytime I go.
Old 05-24-2010, 05:12 AM
Spazzz
AJHardee's Avatar
Were Are the PICS???? Why cant I see them? I want to make sure I am ordering the right part from Advanced Auto Parts...unless somebody knows of a better place to order?
Old 05-24-2010, 08:52 AM
Majofo's Avatar
^ Your firewall is blocking Photobucket. Are you at work trying to view this thread? Try adding an exception to your internet protection program.
Old 05-25-2010, 01:22 AM
I'm not sure your local Auto Parts store will have this filter.
I literally called 13 dealers in SoCal for the filter and o-ring. Only one had it and they only had one of each in stock. They had a ton of washers though.
It costed $47 for the O-Ring, Filter Gasket and Filter Element at the dealer and another 2 washers for about a buck.
It's pretty cheap here.
Old 05-25-2010, 09:15 AM
dwb993's Avatar
I used Bernardiparts.com on the East Coast.
Quick Reply: 5AT Filter Cartridge
