white smoke coming from behind the engine? - AcuraZine Community
Register Albums FAQ Members Calendar Search Today's Posts Mark All Read ExperienceUsed CarsVendorsGarage
Notices
Old 10-25-2009, 5:58 PM   #1
bdown62007
bdown62007's Avatar
Points: 4,147, Level: 40
Points: 4,147, Level: 40 Points: 4,147, Level: 40 Points: 4,147, Level: 40
like the post said its a white smoking that comes from under my hood after about 5 mins or so of driving. so i took it to a mechanic yesterday and he said it might be that i need to change the oil so he did. then it went away for about 20 mins then started up again...does anyone kno what this could be. i hope its nothing serious because im a student with very little dispensable cash
bdown62007 is offline   Reply With Quote
Old 10-25-2009, 6:21 PM   #2
SouthernBoy
SouthernBoy's Avatar
Points: 15,574, Level: 80
Points: 15,574, Level: 80 Points: 15,574, Level: 80 Points: 15,574, Level: 80
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Oil generally emits a light blue smoke when coming from the engine. But you said behind your engine which sounds more like it's coming from the exhaust system (main cat perhaps). While tends to indicate coolant. I'm not sure what the power steering fluid color would be when burning. Do you notice an odor?
In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
Si vis pacem, para bellum.
2004 TL 6MT Navigation
Anthracite/Ebony
Bone Stock
SouthernBoy is offline   Reply With Quote
Old 10-25-2009, 6:32 PM   #3
KzooTL
05' AT SSM
KzooTL's Avatar
Points: 4,880, Level: 44
Points: 4,880, Level: 44 Points: 4,880, Level: 44 Points: 4,880, Level: 44
Activity: 0.3%
Had the powersteering hose recall done?
When its smoking pop the hood and see where its coming from.
KzooTL is offline   Reply With Quote
Old 10-25-2009, 6:43 PM   #4
bdown62007
bdown62007's Avatar
the mechanic said it smelled like out. and its a light white color. i havent had the recall done i believe. and when i popped the hood it was coming from behind the engine on the passengers side
Old 10-25-2009, 7:50 PM   #5
Opel
Opel's Avatar
Points: 6,687, Level: 53
Points: 6,687, Level: 53 Points: 6,687, Level: 53 Points: 6,687, Level: 53
Activity: 0.7%
what kinda fucking mechanic can't look and find out where smoke is coming from? i mean damn....thats like saying "i think smoke's coming from the fire"
so he just assumes shit like that....it can also be oil from valve cover, PS fluid,
you could have a coolant leak....and it could be burning off from the cat just like Southernboy said.
04 6MT 375 whp---It's been 3 years reading on here and still haven't decided on a CAI. can anyone help?
Opel is offline   Reply With Quote
Old 10-25-2009, 8:34 PM   #6
shftl
Points: 5,195, Level: 46
Points: 5,195, Level: 46 Points: 5,195, Level: 46 Points: 5,195, Level: 46
I am. It's white. The smoke that came up behind the engine from a power steering hose leak, that sprayed hydraulic fluid on the exhaust manifold of my 89 Sable, was pure white. The flames that followed, and consumed the front half of the car, were orange. Has your car had the PS hose recall work done?
You've got a potentially catastrophic situation on your hands, if that's what it is. Take your car immediately to an Acura service department.
shftl is offline   Reply With Quote
Old 10-25-2009, 9:26 PM   #7
SouthernBoy
Activity: 1.4%
Thank you.
Let me guess how your Sable's PS line failed. It was a metallic line and was routed very close to one of the head pipes. The natural vibration and movement of the engine caused the flange from either the head pipe or the exhaust manifold to rub against the line until it penetrated the line and fluid spewed forth. Want to bet this is what happened? And was your Sable built in Mexico or in the Atlanta plant? I would wager Mexico.
We bought a 1990 Taurus for my wife and this is what happened to her's, though fortunately, no fire. And it was made in Mexico. In fourteen months, it had twelve trips to the dealer for warranty work, some rather serious.
You're right to advice the OP to get that car in quickly and have it checked.
Anthracite/Ebony
Bone Stock
Old 10-26-2009, 2:33 AM   #8
xxbiggie
xxbiggie's Avatar
Points: 4,044, Level: 40
Points: 4,044, Level: 40 Points: 4,044, Level: 40 Points: 4,044, Level: 40
I had smoke coming from the engine as well a month or so ago. The leak was from the power steering hose, and it was behind the engine on the passenger side. You might wanna take a look there.
Mine had a pinhole where the hose has the rubber mount around it. See if its coming from there.
Took it to the dealership for the recall, and now all is good.
05 Acura TL || Advan RZ-DF matte black 19x9 || A-spec kit || Tein SS || Accord Fog lights || OEM Window Visors || Injen CAI || Tanabe Exhaust || Wilwood BBK || Progress RSB
xxbiggie is offline   Reply With Quote
Old 10-26-2009, 7:42 PM   #9
shftl
Thank you.
I think you're right. The Sable developed a power steering hose leak that caused plentiful white smoke. I had the hose replaced, and about a week later, when I made a hard right turn I heard something pop and the power steering died. A couple of minutes later there were cheerful flames coming up through the cowl. It's pretty clear that either the new hose had a flaw in the neoprene or the metal end at the steering rack came unswaged. Anyway, bdown is driving a time bomb and needs to get the recall fixes done.
Old 10-27-2009, 6:48 PM   #10
bdown62007
bdown62007's Avatar
well it was the power steering hose. i took it to the dealer and its all taken car of now free of charge...thanks everyone for their help
Old 10-28-2009, 7:33 PM   #11
lazytik
Points: 6,527, Level: 52
Points: 6,527, Level: 52 Points: 6,527, Level: 52 Points: 6,527, Level: 52
Hi guys.
I just read this yesterday and lo and behold today I smelled the smells and saw the sights of this issue.
I didn't drive it tonight and am going to get it towed to the nearest dealership tomorrow and have them do the hose replacement. However, I checked the records on my car, and it already had this recall done once....
bdown: how long did it take? Would I need to arrange for another car?
lazytik is offline   Reply With Quote
Old 10-30-2009, 8:14 AM   #12
LoveMyTL-S
2008 Acura TL-S
LoveMyTL-S's Avatar
micheal.cain
Points: 24,594, Level: 95
Points: 24,594, Level: 95 Points: 24,594, Level: 95 Points: 24,594, Level: 95
Activity: 6.6%
Activity: 6.6% Activity: 6.6% Activity: 6.6%
I think it only takes about an hour to replace the hose.
2006 Honda CR-V (Sahara Sand Metallic)
2008 Acura TL-S (Carbon Bronze Pearl)
| iJDMTOY | Drop Stop | vLEDS | Trunk Tray | All Weather Mats | Plastidip |
Car of the Month Contests are going on now! Is your car good enough to win our monthly contests and possibly be our 1st Car of The Year for AcuraZine? Click here and Sign up for this month's contest today!!!!!!!!
LoveMyTL-S is offline   Reply With Quote
advan, burning, car, coming, engine, exhaust, gallery, honda, no51c, rdx, rubber, smoke, smokes, taurus, vibrating, wheel, white
