Alternate to Acura Dealer for 105k service
I'm confused about what I should do about the 105k service. I'm not taking my TL to Acura it's a long long drive and they want $1800. I called Pep Boys and they do it but they want to use their parts or they don't guarantee the work. So if I go with Pep Boys for the timing belt, spark plugs, and water pump I have to use their parts or I might as well had a 12 year old install it if anything goes wrong. I know everyone is all about OEM parts but if I buy the OEM parts and have pep boys install them...no guarantee on anything and the timing belt being incorrectly installed could blow your whole engine. Any suggestions?
Personally, I have had bad experiences with pep boys in the past and will never take any of my vehicles there.
Try and find an independent shop other than a chain?
Definitely had my bad experiences with Pepboy's also. My 95 GT Mustang they replaced the power steering pump ($1000 later and it leaked about 2 weeks later). I sold it as-is. Then I took my 00 Dodge Ram for small noises I heard ($800 later my truck started riding funny with a bad vibration; took it back and they said there was nothing wrong. I even paid $70 for a full inspection, they charge people for a car inspection before you buy the car. The vibration was the rear ujoint connected to the rear drive shaft. The driveshaft came loose and tore open the rear of the T-case. That was a $2000 repair that I feel they should have caught during the inspection. Yea so not a good experience either.....
Try a Honda Dealer.....they will usually be cheaper due to lower hourly labor rates.
Here's what a NJ Honda dealer would do at 105,000 miles for the 3G Acura TL for "less than $800.00":
Replace Timing Belt
Replace Accessory Belts
Replace Water Pump
Flush Coolant System
Inspect Internal Engine Seals
Adjust Valves
Keep in that you need to compare apples with apples....Everyone has a different "recommendation" what the 105k service entails......
Replace Timing Belt
Replace Water Pump
Adjust Valves
Don't let PepBoys touch the belt or the valves. The thought of one of those guys doing a valve adjustment is scary.
As it was mentioned above, start with the Honda dealer. If that's not low enough, you could find an independent Honda mechanic. I've found that many times the owner or lead mechanic of a specialty shop was a dealership employee at one time.
The two items you don't want to cheap out on are the timing belt and waterpump. If you want to try your luck with different valvecover gaskets or serpentine belt and such, go for it.
18psi
Replace Timing Belt
Replace Water Pump
Adjust Valves
Replace Timing Belt
Replace Water Pump
Adjust Valves
a valve adjustment by itself is around 300$
B A N N E D
I'm getting mine done at a local honda stealership for $850. I'd rather pay a couple extra hundered doller than have an idependent do it (just because i dont really trust anyone in the area to do it) Acura wants $1200.. and they are using OEM parts obviously and warranty there work... HONDA DEALERSHIP FTW
B A N N E D
The technican at honda said that its the honda odyssey kit, all honda oem parts. I already let him know that i think the valves sound fine.(they do to me i guess) but yea 850 bucks (i got a 12% coupon from acura on the timing belt service) and they are letting me use it, I used the oil change counpon there to and i only had to wait like twenty mins for my oil change, and the guys there were not pricks like the guys at my local acura dealer
Exhaust valves on the other hand usually tighten up and don't get noisy. Too tight can burn an exhaust valve requiring the heads to come off to fix.
If they're loud they need adjusting. If they're quiet they could still need adjusting.
Spend $300 now to get them adjusted or pay $2,500 later to have them replaced.
One alternative is DIY. Gonna cost way less than the dealer or shop or anything.
B A N N E D
Intakes get loose and get noisy yet are harmless other than the noise to run them that way.
I completly agree and see where your comming from, The technican told me they dont even offer people valve adjustments unless they are loud, you think thats the reason maybe? so you can come back and spend $2500 later? I plan on getting the service done early just because i cant imagine owing my car with 170k+... but like the werid thing is he did not even bring up the ajustment, i did...
To tell you the truth, from what I've seen with valve adjustments, Acura could recommend adjusting the valves at something like 20,000 miles and then a much longer interval after that. I would guess that much of the tightness comes from the initial break-in then it slows a lot after that, at least that's what I've seen from other cars. The problem is they could never get away with a 20K initial valve adjustment, consumers would not go for that. After I do mine, I'm just planning on checking them but I don't expect to do it again for 150K or more.
exactly what is done at an acura dealer for the 105k service. im coming up on it and do have the funds. thinkin about doing the belts and water pump myself...dont trust myself for valve adjustment however
you have to ask each shop/dealer what they are replacing, many low ball you to get the job and dont include timing belt pully and tensioner- or spark plugs (if not done yet book says at 105)
while other places will do it right, and include those up front rather than call you to get approval once car is apart--an old trick~ get it in and then up the price a few times
most places only quote wp and tbelt as the 105 but its more. get in writing what they do
should also replace/flush fluids if not done yet- ps and brake fluid flush, brake inspection and lube their parts,,
depends on where you are in maitenance overall- whats left from the 60 not done yet?
this is the cars only big service - the rest are fluid change and inspect things- lube as needed
Valve adjust: unless you are using a mechanics stethascope you cant hear them correctly.. and then it takes a trained ear
There is a minimum and maximum clearance between 2 parts at the adjuster nut, tech inserts measuring tool- a slim feeler gauge
if between those numbers, or where they have found to be an optimal setting of towards tight or loose of spec limit, then proceed to next valve- rotate engine to next postion and continue. repeatrepeatrepeat
if valve clearance not in spec- loosen adjuster nut, adjust-adjust-ck adjust- lock and recheck
thats what `adjust as needed` means- the ones that NEED IT get adjusted
Will usually find a few exhaust out of spec at least
A perfectly set valvetrain makes the fuel injection work better and the car run smoother overall = closer to equal compression in each cylinder- same amount of time valve open and its lift -inlet or exhausting
a really good tech writes down the numbers before and after to show their work.
You can run a compression test before and after and see you have done something good.
Why its not offered:
Its not a high profit job- the actual time used vs billable time for the job when tech can be working on fast easy money jobs,,it requires a `skilled tech level`, techs dont like doing it so they dont report it, writers dont always understand what to really sell- they sell the fast money jobs
You dont have to do the valve adjust WITH the timing belt job-
it can be done on its own at anytime, after an oil change is my way, so the surfaces you are measuring .008 clearance between are clean and accurate reading
There is a cover or 2 off for tbelt job that gives better access to see some timing marks and speed locating engine to next position,
but you can also see other ones without removing the tbelt cover
Okay, so if Honda does a similar thing for around $800, but probably does not do a valve adjustment, is it better to go with the Acura 105k service at $1200ish if you get them to agree to the valve adjustments in writing (not just inspection)? Just curious...I have about 3 1/2 years or so before I have to worry about it.
if they write it as inspect valves- the time is the same if written as adjust as needed
You dont `ck the gap` and find it out of spec- then move on because its `just Inspect` lol
it bills 2-3 hours labor, if you want it done then specify Valve Adjustment on the work order and tech will do what the paper says
Most of the work is getting the valve covers off!
Honda will do whatever you want- you are calling for a price- they give you a price to get you in,,,then suggest the valves--depending on how busy it is in the shop that day..do they have time to do the extra job?? do they have time for induction cleaning (seafoam)- then they will sell it!!
i think im going to have to go for the valve adjustment some other time then. im hearing some major "ticking" and "chucking" noises from my engine. been hearing it for a few thousand miles now. just changed the oil bout 200 miles ago
One on the right for me
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
