RL Brake Calipers on 3G TL
Thanks to Paul (NVA-AV6) and his awesome fabrication/machining skills on the aluminum brackets, I now officially have RL Calipers successfully retrofitted onto my '05 TL. I'm definitely not the first car to have done this, but I might be the first 3G TL to have it installed on. RL calipers are made by ADVICS and are 4-piston all alluminum radial mounted. They have a sweeping area that is greater than that of the TL-S/6 Speed Brembo. I was going to go with the TL Brembos but didn't want to go through the hassle of changing out my knuckles, bearings, sensors and whatnot. I found a good deal on the RL Calipers, so I pulled the trigger. Since all the parts in my setup are OEM type parts, maintaining them won't cost me an arm and a leg down the road. You can probably get the Wilwood kit for what I paid total, but I guess I just like to be different.
Specs:
'06 RL Calipers with G2 Caliper Epoxy Paint System
Racing Brake 320mm (12.6") 350z rotors (think 07-08)
EBC Yellowstuff Pads
Custom aluminum brackets
My car is super dirty but here are some pics of the operation:
Specs:
The following 2 users liked this post by binhsterbinh:
DjTribe__ (07-11-2014),
JoshD_99EM1 (07-08-2014)
The bed in process for EBC pads is slow and could take up to 1500 miles, so I won't be able to give more information until after they've fully bedded. Just testing them from 60-20mph right now, they stick like glue in comparison right off the bat vs having to push harder and harder on the OEM ceramics to get the same affect. One of the main reasons I went with OEM parts and not Wilwood (or any other setup in the $700-1000 price range) is because the RL calipers have the rubber weather seals on the pistons. As long as I keep it maintained, it should last a long long time. Seattle is a moist environment and the last thing I want to do is have to rebuild my calipers every few years.
As for a rear BBK kit, I'm going to pass. I'll be doing Racing Brake slotted rotors and Racing Brake ET500 pads in the back soon though which should be more than enough for my spirited driving.
I'd say if you can score a pair of RL Calipers for a good deal and have patience to wait for a custom bracket to be built, this is quite a worthy setup. The only major con I've noticed is that their aren't many aftermarket HP brake pad suppliers for the RL besides EBC. Also, if you want a bigger rotor, you can use the Nismo 350z rotors (330mm ~13") as well. Since RL Calipers are Radial mounted, you can use any sized rotor your want (> or = to 12.6") and add spacers to the bracket accordingly. From the specs I read, you can probably get away with using the 14" rotors from a G37/FX56 ; however, the drawback here is weight unless you buy expensive 2 piece rotors. This also won't clear smaller wheels.
12.6" Racing Brake 1 piece rotor = 17lbs
14" G37 stock 1 piece rotor = 28lbs
Undying Dreams (02-10-2013)
As for rotor options, I had to do a lot of reading/research to figure out what works and what doesn't. Spent quite a bit of time looking up rotor specs at RockAuto as well as scouring other forums. Marcus at Heeltoe ended up selling me on Racing Brake products that the decision to move forward was a no brainer. I just wish they made RB ET500 for the RL calipers. Talk to Marcus, he should be able to get both the EBC pads, Racing Brake SS lines and rotors for you at a very reasonable price. The lines are the same between RL and TL. The rotors are not though because RL is 5x120mm vs. TL's 5x114mm.
Also, if you plan on painting, don't forget to wipe the brake fluid off the calipers when you're installing/flushing the system. That crap ate through the G2 Caliper Paint on the backside of my calipers where I missed with the rag. Glad it was just on the back side.
Another tidbit of information. Rockauto has remanufactured brembo TL 6-Speed / TL-S calipers for ~$150 each after $50 core charge. This includes the powdercoating for those who want to do the whole knuckle swap thing.
94 DC4 RS LSV/Turbo
mmmh paul should make these brackets for both the brembo and rl calipers
there are a ton of auto guys who'd be all over using oem parts to brake upgrade
TSX, AV6 AND AUTO TL
Agreed. I believe the main differences between Base Auto TL knuckle and the TL-S/ 6 speed knuckle is that one sits more forward than the other. I can't remember which one was sitting more forward towards the rotor, but I think a search would provide more queues on this. Someone on this forum had created a bracket and then scrapped the idea because he was concerned about the safety of using hybrid brackets. Remanufactured Powder coated Type-S calipers for $200 after returning the cores is a pretty slick deal. Someone should do this!
94 DC4 RS LSV/Turbo
what he think rotora, wilwood, stoptech, etc.. make more than 1 4pot caliper depending on the car... pfff they make 1 and each kit comes with adapter brackets
Option B would be to fabricate a bracket that extends the brembo mounting points radially outwards away from the hub center. Even in this case, we're assuming the brembos will clear the 5AT knuckles even with the bracket. Option B also would require an upgrade to a larger rotor than the 12.2" rotor. Perhaps more along the lines of 13" rotors at minimum.
https://acurazine.com/forums/showthr...bo+swap&page=2
Update: I got factory 04-06 Acura TL (17x8) wheels fit with this setup; however, the wheel weights were incredibly close to the calipers. Since I just use factory wheels for 4 wheel alignments, I went ahead and scraped off the weights. Also the custom bracket studs which are radially mounted had to get shaved down slightly to clear the inside of the wheel as well. I'd imagine a 13" rotor may not fit on 17's since the caliper would sit 1/4" further out towards the inside of the rim, especially with wheel weights.
Aluminum Brackets were about ~$120. Member NVA-AV6 made mine. It's not just a simple rectangle bracket like most would think. Paul provided everything I needed to install (i.e. high quality bolts, washers, fit check process to accommodate my rotor choice).
Now if only Paul would do a bracket for a 2 piston rear setup on a larger rotor. I don't care what anyone says, if you have the bias setup for minimum stopping distances, the rears are not adequate if you track it hard.
Under track conditions, my rears are not adequate. I have Rotora slotted stock size in the rear and Cobalt pads which are being swapped to EBC Yellows due to their very high friction coefficient (.6) to help with rear bias even more.
My rears are starting to see 1,000 degrees while the front 13" Rotoras are seeing 590-ish degrees. I would really like a cheap rear rotor upgrade but if I have to wait till tax return time, I guess I can always do a 13" Rotora set in the rear too.
J36Twingt28r's,nextgt30r
^^ im pretty sure he does?? i think i remeber somewhere on v6net that he made a 2 piston rear caliper conversion. im trying to think cause it was either nsx rear calipers or something else?? the cool thing about paul is if u got the $$ for fabrication he will basically fab ANYTHING FOR YOU, heck he is making me a custom intake manifold from scratch.
now someones gotta pay the dough so we can see some individual throttle bodies on our cars
Paul can definitely fabricate a bracket for a 2 piston caliper(ie rotora/wilwood) no problem, but the issue is the sourcing of the rotors. The TL/TSX have an integrated drum parking brake inside the rear rotor. I think only Rotora has a larger than stock rear rotor that will be applicable on a TL/TSX rear brakes. They are oversized 2-piece 330mm x 30mm (~13"). Those rotors alone would cost in ballpark of $350-400 per pair. Add the calipers of your choice at $300-$500 and the $120-$150 custom bracket and you're looking at about $1000. At that price point, the full 13" Rotora Rear BBK seems like a reasonable price and a whole lot less effort. One thing to remember is that Paul will need an actual rotor and caliper shipped to his address in order for him to mock it up and fab the bracket.
Fastbrakes has a TSX 12" rear brake kit upgrade including the rotors and adapter kit for $275. I'm not sure if that will fit the 3G TL though. Stock rotors are 289mm x 9mm non-vented.
Fastbrakes also carry a 3G TL Rear 4-piston Wilwood Caliper kit for $685 without rotors or $755 with rotors. These are designed for use with stock sized rotors though. I'm pretty sure using the stock non-vented rotors with 4-pistons only equates to heat related issues.
As for the brackets, contact member NVA-AV6. He'll be able to custom fabricate your aluminum brackets. He might already have a rotor and set of calipers to do the mockup.
jauman (09-27-2013)
on top of the cailpers,
45018-SEP-A60 CALIPER SUB-ASSY., R. FR. -calipers with pins and spring
45019-SEP-A51 CALIPER SUB-ASSY., L. FR. -calipers with pins and spring
45022-SEP-A60 PAD SET, FR.- Brembo OEM pads
51210-SEP-A01 KNUCKLE, R. FR.
51215-SEP-A01 KNUCKLE, L. FR.
57450-SEP-A01 SENSOR ASSY., R. FR. -wheel speed sensor (if req'd)
57455-SEP-A01 SENSOR ASSY., L. FR. -wheel speed sensor (if req'd)
45251-SEP-A51 DISK, FR. BRAKE (17 in.) x2 -rotors,Brembo blanks
45255-SEP-A50 SPLASH GUARD, R. FR. -backing plate
45256-SEP-A50 SPLASH GUARD, L. FR. -backing plate
90651-SEP-A50 CLIP, R. CALIPER x2 -shim between bolt,knuckle and caliper
90656-SEP-A50 CLIP, L. CALIPER x2 -shim between bolt,knuckle and caliper
90107-SEP-A50 BOLT, CALIPER MOUNT x4-caliper to knuckle bolts
01464-SEP-A50 HOSE SET, R. FR. BRAKE- flex hose with brakets and clips
01465-SEP-A50 HOSE SET, L. FR. BRAKE- flex hose with brackets and clips
46335-SEP-A50 PIPE G, R. BRAKE - flex hose to caliper steel line
PIPE G, L. BRAKE - flex hose to caliper steel line
got this from a member here selling his calipers..
https://acurazine.com/forums/car-parts-sale-361/3g-tl-bbk-ss-brake-lines-rotors-810466/
make friends with the search option.!!GL
