what does a thermal expansion valve look like - AcuraZine Community
Go Back   AcuraZine Community > AcuraZine TL Community > First Generation TL (1996-1998)
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Acurazine.com!
Welcome to Acurazine.com.
Old 01-28-2010, 2:11 AM   #1
Bal`thzar
New Member
First thanks for all of the help in my first thread. Now that I have a service manual I am having a hard time idenifying the thermal expansion valve.
my airconditioner works then all of the refridgerent gets trapped on the other side of the valve and it doesn't let it bleed back into the compressor unless I turn it off and let the car sit.
so looking through the service manual I can't seem to find the thermal expansion valve. that is the term used here in New Zealand. I am hoping maybe its known under a different name in the service manual. I know its in the dash.
anyone can give me a hand on a different name or a description of what it looks like, I have the diagrams of the heating and cooling system, but still having a hard time.
Bal`thzar is offline   Reply With Quote
Sponsored Links
Old 01-28-2010, 2:47 AM   #2
Bal`thzar
New Member
woo hoo I actually found one online I just have to figure out how to get to it. talk about living in a lifetime of lowered expectations.
Old 01-28-2010, 2:48 AM   #3
tmnhs81
tmnhs81's Avatar
#13.
1997 Acura 3.2TL Base.
ACURAFEST '10
Saturday Oct 09 2010
Click
tmnhs81 is offline   Reply With Quote
Old 01-28-2010, 2:56 AM   #4
Bal`thzar
New Member
Originally Posted by tmnhs81 View Post
#13.
you lost me
Old 01-28-2010, 11:42 AM   #5
TexasHonda
Part No. 13 in the diagram is the expansion valve.
Note, the expansion valve could be faulty or debris could be intermittently blocking the valve. If it's debris, the system may need to be flushed to clear the debris, else a replacement expansion valve may not fix the problem. In the case of debris, the evaporator needs to be replaced as it's difficult to effectively flush, and same for the condensor.
This sounds harsh, but less harsh than going through an extensive repair and winding up w/ same problem.
Here in states, used parts are an effective method of reducing repair costs dramatically compared to purchase of OEM parts. I've had excellent results w/ used AC parts.
good luck
1997 Acura 2.5 TL
2007 Honda Accord LX/SE
1994 Honda Accord
I don't drive em, just fix em.
TexasHonda is offline   Reply With Quote
Old 01-29-2010, 3:12 AM   #6
Bal`thzar
New Member
wow am I a bonehead. thanks guys.
it seems that Honda used this particular tx valve was used across several different models. anyone have a part number for this one?
Old 01-29-2010, 3:30 AM   #7
Go90go
大日本帝国
Go90go's Avatar
80220-SW5-003
The 013 and the 023 are the same, too.
~Cheers~
Go90go is offline   Reply With Quote
Old 01-29-2010, 7:46 PM   #8
Bal`thzar
New Member
anyone got a link to the schematic that has part 13 on it because i can't find it in the service manual
Old 01-29-2010, 8:45 PM   #9
Bal`thzar
New Member
I have found 3 different parts that are listed to work, 2 of the expansion valves have a thermostat and a secondary connector and one just has a thermostat. here is a link
http://cpwstore.carpartswholesale.co...versal:0)&sv=0
I am not sure of the difference. I am wondering if the secondary connector connects to the console thermostat if there is an internal one.
any ideas guys
Old 01-30-2010, 8:58 AM   #10
TexasHonda
From diagram, your expansion valve has both a pressure bias tube and a thermal sensor tube. Only connections are to the evaporator. Sensor bulb is pushed into fins of evaporator to sense evap temp.
good luck
1997 Acura 2.5 TL
1994 Honda Accord
Old 01-30-2010, 6:59 PM   #11
Bal`thzar
New Member
thank you very much now atleast I know the one to buy
Old 01-31-2010, 7:45 AM   #12
Mandy
98 3.2 Nighthawk Black
Mandy's Avatar
good luck
You are good man! Thanks for your help!
http://i184.photobucket.com/albums/x...s/DSCN0013.jpg
98 3.2 Nighthawk Black Pearl breaking 94k miles...
Mandy is offline   Reply With Quote
05, 1997, acura, costs, expansion, names, problem, removal, repair, rsx, thermal, tl, tsx, tx, valve, vavle
Advertising Information - Contact Us - AcuraZine -
Top
