J32A3 Engine into Integra NIGHTMARE
Alright. Keeping it short and sweet.
Liked J Swap, it's bad-ass. Started looking for engine.
Bought engine (75K Km's) w/ trans, harness, shift cables for $700.
Bought J Swap mounts.
Put engine in car.
Asked questions on forums about wiring.
Bought CL-S parts for $700 (ECU, harness, IM, TB, sensors) on advice of member to make it run.
Parts arrived, bolted on, didn't work, some pieces didn't match up.
Confronted member, he admitted bad advice, said he would help me figure it out. He hasn't, probably won't.
Another member is in the same boat I am. Same engine, same problems, SAME MEMBER GAVE HIM SAME BAD ADVICE, only he spent more money and drove back and fourth to his shop for weeks. His engine doesn't run either and he is out a lot of cash.
Questions:
What can we use for management? Stock 04-08 6 SPD w/ DBW?
There are a host of new improvements on 04-08 TL's which all have more complicated electrical systems integrated with the ECU. Will these be more trouble then they are worth?
Anything can be done, yes, but where is the "fine line" that we should observe? The two of us are bombarded with discouragement and doubts, but we are dead set on getting this swap done and working. We both think it can be done, we are both knowledgeable with swaps. We are hoping the experts here, with 3G TL experience will give us some more insight.
What I (we) have to work with:
J32A3 6 SPD - 100% factory, bolted into Integra w/ HASport mounts.
HASport axles.
Stock shift cables.
Hybrid Racing bolt in shifter.
Engine harness up to 3 big plugs.
RV-6 pre cat deletes
What I (we) need to make it run?
Remaining engine harness wiring (from 3 plugs in bay into cabin)
DBW 6 SPD ECU w/ ignition and key.
Additional ECU plugs for wiring.
Upper wideband O2 sensors, lower O2 sensors.
J Pipe
APP sensor w/ wiring and in-car module for DBW.
We do have the 04-08 TL PDF manual which has given us an idea of what we're looking at.
If anyone has advice on things we've overlooked, or something we should know, please share.
Put engine in car.
Questions:
HASport axles.
Stock shift cables.
J Pipe
J36Twingt28r's,nextgt30r
ask nva-av6 he will know what to do. he actually has an integra and is planning on doing the same thing, except gonna use a stroker j37 engine.
It is a TBW (Throttle By Wire) J32A3
The most popular V6 swap right now is the J32A2 which is cable throttle. Subtle difference from the outside I know, but Honda changed the entire engine when they built it (the J32A3). Sensors are different, more advanced and everything has been upgraded. It is these upgrades that have us stumped and are making it very difficult to do the swap.
94 DC4 RS LSV/Turbo
there's only 1 person who can help you... RICHIE V6
you need to literally convert the front of the car from the ecu to the headlights
my advice, find a junked manual tl and take the full wiring out, and have fun adapting it
I thought about doing this and theres another member on here (secret project ) working on the same block
it's not easy dealing with dbw... what did the dudes do with the modern k's??? dbw delete?
All motor
Take this with a grain of salt as I'm not sure....but since you have the J32a3 which is found in the TL, why can't you use the TL harness and ECU? Even the TL-s ECU to have a better benchmark to start with as it's hard for us to tune our engines anyway. With I/E/PC deletes/Jpipe you should be pushing more than the J35a8 found in the TL-s, so the ECU should work pretty well.
Like I said, I'm no expert, just trying to give suggestions and see if anyone can correct me. NVA-AV6 is definitely the guy to ask as he's done numerous J swaps. You can also call P2R (PowerRevRacing) as they do great work for the J series as well. Good luck with your swap.
I saw a J32 integra in action and let me just say it's a beast
This might help:
Karcepts makes an adapter plate that allows you to bolt on a throttle body that does not use DBW to some intake manifolds that normally run DBW throttle bodies.
I believe it was designed to be used on K series engines but I have been told that it does bolt to the J series intake manifold.
Here is the link:
KARCEPTS RBC ADAPTER
Hope that helps
Here is the link:
Hope that helps
94 DC4 RS LSV/Turbo
nope... no can do... can't just delete dbw and then expect for a stock ecu to magically not own you
you either need a standalone (the likes of which P2R used on their EF [aem ems])
or like I said before, convert everything from the ecu to the headlights into a TL... that's it... point blank
I have no intentions of deleting the DBW.
I know that it has to be there... PERIOD.
My concerns are with all the additional things that the TL has, over the CL-S. It is just a more complicated beast...
People on the forums are telling me...
"There's no way this can be done, there's just too much extra wiring, over a CL-S swap."
"The immobilizer system on the TL is nothing like the CL-S, even with the key and ignition it still won't run."
So, this is where I begin to have doubts and want to get second, third and fourth opinions...
I got the Shifts
this would be better off in the 2nd generation section. first mistake was buying the DBW engine. best swap is the 02-03 type-s engine with the cl-s or tl base 04-06 tranny and the richie V6 engine harness.
i researched for a year and a half before i jumped in. pm me with specific questions and i will help.
I got the Shifts
https://acurazine.com/forums/2g-tl-1999-2003-98/phees-99-tl6-swap-thread-parts-list-price-list-question-thread-703784/
my thread. it even has a parts list in it for the swap.
Ohh, you are in for a world of fun, the A3 would have been my last choice for this as the ECU will complain until you also graft in the ABS system, multiplexers, DBW system and cluster from another 04-06 TL. Backdating the cam and crank sensors to say a 03 CL-S won't fly eaither as the oil pump does not have to mounting holes in the right position for it, the tranny does not have the extra crank sensor, and the cam gear will not bolt up right to the A3 cams, so you now HAVE to go down the route of making your teg a 3rd gen TL.........
Danny Hunley (11-14-2012)
This is the hatch we built last summer. It is running code free and puts down 242WHP on a dyno dynamics. Kind of regret it, still cant get traction worth a damn.
The following 2 users liked this post by Richie v6:
Danny Hunley (11-14-2012),
sauceja (11-18-2012)
All motor
Selling the J32A3.
Weighed all the options.
Stand alone - too expensive.
Wiring in everything required to make it work right - too expensive.
Fabricating the engine to use older sensors - too expensive.
Buying J32A2 6MT, converting TL trans into CL-S trans with new bell housing... just right.
runnin a little boost
Selling the J32A3.
A stand alone is the only way to go. The only reason to stick with a factory ECM is if it were staying in a TL where many of the accessories rely on the factory computer. Otherwise junk the factory ECM.
You can get a decent standalone for $1,500 and have all the tunability you could ever dream of. For that price you could ditch the speed density setup and go with a more mod friendly mass air system. The standalones will always be safer for the engine especially once power levels start going higher with forced induction.
