The TL has so much fail in hot weather
Old 05-04-2010, 03:09 PM
18psi
libert69's Avatar
Seems like 75 degrees is the cutoff point when the car goes into sloth mode.
/rant
Old 05-04-2010, 03:13 PM
אני עומד עם ישראל
Hapa DC5's Avatar
Really? The car seems to react to hot weather as any other car I owned has. You driving it hard?
Old 05-04-2010, 03:20 PM
18psi
libert69's Avatar
i can feel a huge difference when just rolling from a stop light accelerating moderately. 2nd gear just drags along
Old 05-04-2010, 03:32 PM
v|nsan|ty's Avatar
Lol come to Canada. In Edmonton, 75 degrees fahrenheit is nonexistent for more or less 2/3 of the calendar year
Old 05-04-2010, 04:00 PM
04Tl
Yonkers914's Avatar
yea it has been known that the TL suffers from heat soak. There is some steps u can take to reduce the problem If ur willling to do some things to ur car. the info can be found in "Tl on a diet" thread.
Old 05-04-2010, 04:09 PM
WhteTLS's Avatar
wait really? TLs crap out in the heat? I drove around all weekend this past weekend in VA/MD and it was in the 90s.. I didn't notice anything.
Old 05-04-2010, 04:14 PM
shadowkahn's Avatar
Any car will be slower when it gets hot. Underhood temps rise any time you stop, and the air is less dense, which means less oxygen to burn.
Old 05-04-2010, 04:16 PM
18psi
libert69's Avatar
yea ive done a few things to help cooling. TB bypass. No engine covers. Open mouth grill. Going to do Inaccurates "ulitmate cooling mod" soon
Anything else?
Old 05-04-2010, 04:42 PM
אני עומד עם ישראל
Hapa DC5's Avatar
Yeah they all have heatsoak.
Old 05-04-2010, 07:00 PM
S PAW 1's Avatar
Sometimes I wished that I ventilated seats.
IMO, other than that, I don't agree with your assessment
Sounds like a miserable summer for you this year
Old 05-04-2010, 09:46 PM
#1 Super Guy!
94eg!'s Avatar
It hits 115 here in Vegas. TL still runs fine. Were almost to 90 this week and mine is normal. Of course I don't usually do hard pulls. Only a few times on a tank...
Old 05-04-2010, 10:12 PM
18psi
libert69's Avatar
Normally yes. But ill be boosting soon so that will make up for it
Old 05-04-2010, 11:09 PM
ScoobyZINE
AMUA6's Avatar
I haven't really noticed any decrease in power in high heat. It's been in the 80's here and I haven't noticed a thing.. The only cooling mod I've done is the TB bypass.
Old 05-05-2010, 12:19 AM
samplemonster's Avatar
Hmm this is interesting, one hot summer like day a few months back in LA, I tried to cut in front of an old tercel from a red light. I barely made it past, he was trying to block me out, and he almost succeeded. Thought it was just me, but I guess others may be having the same assessment?
Old 05-05-2010, 12:38 AM
18psi
libert69's Avatar
I noticed today that it was about 76 with high humidity and the car was sluggish. once the humidity leveled off and temp was no lower then 75 (according to the mid) the car felt normal again
Old 05-05-2010, 01:11 AM
humidity is a killer on engine performance--wiki: density altitude
ways to reduce heatsoak:
install P2R or outlaw engineering intake manifold to engine spacer and TB to manifold spacer - those reduce heat transfer between critical parts of differing metals--
the manifold sits on top of the center of a v6 engine--lots of heat rising there~~
reduces internal temp of air in the intake-(there are sensors that adjust other settings based on that temp and air density)
better power,,more like 59f and sealevel~
Old 05-05-2010, 01:12 AM
75f seems low to me for a loss of power- are you on 91 octane gas?
a ck for codes or a run with scanner plugged in may reveal a bad sensor
Old 05-05-2010, 01:37 AM
AZ Community Team
Bearcat94's Avatar
@ "sloth mode"
Old 05-05-2010, 01:42 AM
BG74's Avatar
Maybe your A/C IS on?
Old 05-05-2010, 04:02 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
My car feels the same whether its in the summer or winter. And none of you can say that its hotter where you live unless you live in Hawaii or below Texas. 110 degrees + 100% humidity = really 130 degrees.
I don't know why, but when I clean my car it drives smoother, I think I'm smoking something.
Old 05-05-2010, 08:38 AM
Crestwood1001's Avatar
Def true, at the meet in college park we were all rolling together to Dave and Busters and the poor car was lagging in stop and go traffic on the highway.
Old 05-05-2010, 10:34 AM
Mug
Mug's Avatar
Less wind resistance.
Old 05-05-2010, 02:26 PM
bzyrice's Avatar
You have a CAI? I noticed mine is better in hot weather ever since I got mine. I wonder why.. lol ..
Old 05-05-2010, 09:10 PM
Burt the Boater's Avatar
Three years in Orlando with weather in the 90's and high humidity and mine still seems to run fine. Have you considered a ten degree cooler thermostat? I had a 1996 Taurus that performed poorly in greater than 92 degree weather. I changed the thermostat and the car seemed to work far better.
Old 05-05-2010, 09:13 PM
d-townhakuzo's Avatar
Lol we just hit 90 in Dallas, and the car seemed to running the same.
Old 05-05-2010, 09:41 PM
I'm Craig
cjTL's Avatar
The damn obnoxious cooling fan kicks on in my car all the time. Eff.
Old 05-05-2010, 10:04 PM
07 TL-S
Skrewologist's Avatar
... well. hint the name COLD air intake amirite?
Old 05-06-2010, 12:47 AM
crazy haitian's Avatar
i think your car needs a tune uppppppp baddddddddddddddddd
Old 05-06-2010, 12:54 AM
18psi
libert69's Avatar
Its not just me. theres quite a few members that experience this. I modified the stock intake so the opening is at the lower grill and I removed the resonator. Same thing as these overpriced intakes imo.
Old 05-06-2010, 08:19 AM
coykiam's Avatar
Originally Posted by Bearcat94
@ "sloth mode"
lol I had to re-read it because of "sloth mode." but to the OP I think every car does suffer from this, much more noticeable on 4 cylinder cars with the AC on.
Old 05-06-2010, 09:12 AM
Keep Right Except to Pass
1995hoo's Avatar
I've never had an issue in either hot weather (low 100s F) or very cold weather (-8F with the windchill closer to -25F). I did buy a house with a garage specifically for the purpose of parking the car in there, and of course it's notably cooler in the garage than it is outside in the sun, so who knows whether that makes any difference in terms of the car being cooler when I start off to go somewhere. I've been driving the RX-7 more this week because it's been great top-down weather; it seems to run better in the hotter weather than it does in the cold (maybe because the car is 22 years old?).
I also tend to buy 91 octane gas at Sunoco because they carry both 91 and 93 and the 91 is 2¢ a gallon cheaper. I sometimes buy 92 octane at the Wawa in Woodbridge if I'm down that way. I've noticed no difference in the car's performance on any of these three grades at any time of year (or on 94 octane, which I bought twice at Petro-Canada stations), so I don't see any reason not to go with the 91. Sunoco in the DC area used to carry 87-89-93-94, but they phased out the 94 due to MTBE regulations in a number of states and now they carry 87-89-91-93. The only car in which I've ever REALLY noticed the difference is in my brother's 1974 Beetle, which for some reason thrived on the 94 octane.
Old 05-06-2010, 10:05 AM
Majofo's Avatar
Bert you jackass.. you're going to be boosted soon and you're complaining about being in sloth mode.
Keep us updated on your progress. You're like the chimp we shot into space. Except the chimp is your 5AT. Will it survive?? to our fallen chimp comrades.
Old 05-06-2010, 07:44 PM
I hate cars's Avatar
Some TLs have serious issues in the heat. Mine is one of them. It's done it since it was brand new.
Every car gets slower as temps rise. My TL gets abnormally slow. It surges, it requires half throttle just to keep up with traffic from a redlight. Gas mileage goes down to about 12mpg around town.
I know what it is, I just don't know how to permanently fix it. The car has a detonation problem. The computer retards the timing and there goes power and gas mileage. I've monitored it on the scanner to verify. Running 100 unleaded cures it of this problem and it feels like any other car in the 105 degree summers. Unfortunately I don't have the money to run $6 gallon fuel.
I've monitiored AF ratios. I've verified the EGR works. I've changed the plugs to a colder range. I've verified every sensor is good. I've verified coolant temperature is correct (more on this later). I've done a water decarbonization even though it did this since it was new. I've relocated the air intake sensor to a cooler and then to a hotter place than the actual inake air to trick it and see if I could get any improvements. Nothing works. The only thing I haven't done is a compression check to see if something is mechanically wrong.
Those of you saying there is no problem are lucky but rest assured some TLs have a very real problem once it hits 80 degrees and above.
I do have one idea though. My TL runs at 198 degrees whether it's the middle of winter or summer. This is what many cars run at and many GM cars run at 210-220 degrees so I thought nothing of it. However, I recently discovered the TL comes with a 170 degree thermostat. I have to wonder if some of us got the wrong or a defective thermostat from the factory. That, coupled with the hotter intake air in the summer months may be the cause of the detonation. I have a thermostat on order so we'll see what happens.
Old 05-06-2010, 07:53 PM
laakness's Avatar
Interesting thoughts about the thermostat.
Old 05-06-2010, 11:27 PM
Middle Finger anyone?
NCTL05's Avatar
IHC-Where did you find out that our t-stat should be 170 degrees? I'm looking forward to more info about this.
I've been running my A/C lately and I am nothing but pissed at the slowness of my car. I also have a 6mt and you even have to change the way you shift with the A/C because of the extra strain. You have to give more throttle just to get going. I'd like to dyno the car with the A/C on to see how much hp I'm losing. I bet its around 20-25hp.
Old 05-06-2010, 11:36 PM
kidrocking79's Avatar
Anyone else feel like they lost power after putting in the CAI? I put mine in last week, and I'm not sure if it's me or what, but I don't think I feel the VTEC kicking in like I used to on stock intake. I love the way it sounds when I'm WOT from inside the car though !!!!
Old 05-06-2010, 11:42 PM
a 4 cylinder w/ the AC on?? they wouldn't be able to get out of their own way !!! lmao
Old 05-07-2010, 12:56 AM
Former Whyner
RonJonTL757's Avatar
lol try a 90+ degree day with a blower...no fun at all. I dont even bother boosting on a hot day
Old 05-07-2010, 01:19 AM
erick3's Avatar
Anything else?
mdx spacer + hood spacers. it really doesn't look at as bad as everyone makes it out to seem. and it works. it WORKS.
Old 05-07-2010, 01:40 AM
18psi
libert69's Avatar
lol...Im betting the trans will implode...But im hoping it doesnt
are you installing a meth kit?
i have the p2r IM spacer and TB spacer but I havent put it on yet. Very soon
link for hood spacer....
<---yes lazy
Quick Reply: The TL has so much fail in hot weather
