DIY Power steering pump repair kit $22.99
Old 12-31-2010, 02:50 PM
hocthainguyen's Avatar
as promise to those that dont want to pay $250 dollars for a rebuilt PSP......you can get one of these repair kit at your local auto parts store......
i dont know how to post pictures on here so i put the pictures at this link...hope this will help some of you.....and the schematic
http://www.facebook.com/album.php?ai...1&l=d9cc17b400
Old 12-31-2010, 05:31 PM
2003 TL-p
gold2003tl (90)'s Avatar
nice pics, great diy. you can also post pics though an image unloader like Photobucket and just copy and past the image link..
Old 12-31-2010, 07:08 PM
Unregistered Member
Karanx7's Avatar
Wish there was text, but it seems pretty self explanatory.
If this works, I'll leave a small portion for you in my will.
Old 12-31-2010, 08:27 PM
well if you need help on which part then just ask pls....when i get time after the holiday i will try to put text in with the pictures.....its basicly very simple....a few Orings and one seal.....and get a bottle of break cleaner so you can clean the parts ....
Old 01-03-2011, 09:59 PM
i have put text in with the pictures......good luck
Old 01-09-2011, 11:36 PM
Unregistered Member
Karanx7's Avatar
I'm doing it now, and I'm having trouble getting the pump out. I've got the rear most bolt out, but the other two are nearly impossible to get to. Do you need a special tool? Is it possible to do it with just a wrench/socket?
Old 01-10-2011, 12:38 AM
Unregistered Member
Karanx7's Avatar
Nvm...
Old 01-10-2011, 12:52 AM
Unregistered Member
Karanx7's Avatar
Ok, next problem lol. Anyone have any tips of removing a the pulley bolt? It's on there pretty tight.
Old 01-10-2011, 07:28 AM
totaledTL's Avatar
Air gun.
Old 01-10-2011, 05:40 PM
Unregistered Member
Karanx7's Avatar
I don't have an air gun. Do you think it's possible to loosen it while the belt is still on, and then remove the pulley once the pump is out? Also, is it simply counter-clockwise, or should I rotate in the direction the belt rotates?
Old 01-10-2011, 10:13 PM
use a screwdriver and stick it thru one of the opening in the pully and against the housing....that what i did....=)....and it counter clockwise ....the normal loosening of bolt....
Old 01-10-2011, 10:17 PM
a normal long socket will do....=).....12mm i believe...
Old 01-11-2011, 10:38 AM
acutee's Avatar
Very nice writeup. Thanks.
Old 01-11-2011, 10:54 AM
acutee's Avatar
I went through your DIY, and in your case, you only replaced the seals. Many of us have the problem with the bearing too. Do you think the bearing is easy to be replaced? or it is tight on the rod and will need to be pressed out. Thanks again for the great DIY.
Old 01-12-2011, 12:30 PM
Smile
yes ....if your bearing is bad then it would be best if you used a presser......for those that dont have one a hammer and cresent wrench would do....but be careful and put on the nut in the thread b4 attempting to remoce the bearing ....it on there pretty good but it will come off....just take your time and cautious....
Old 12-22-2011, 03:46 PM
acutee's Avatar
Do you happen to have the psp seal kit part number on the other side of that picture seal kit?
Old 12-22-2011, 08:46 PM
jo3lo22's Avatar
I'm so doin this
Old 10-10-2016, 08:54 PM
AmyLynne Marley's Avatar
This link doesn't work, can you post again PLEASE
TL-Rocket
04-29-2023 02:33 AM
mike from annapolis
05-07-2017 08:21 PM
nash3222
09-10-2015 09:46 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: DIY Power steering pump repair kit $22.99
