Transmission Fluid Woes
Hey everyone,
Well, after about 3 hours of searching/reading long dead threads, I have a few questions that I'm sure many of you will have the answer to
I am planning on changing my transmission fluid, 3rd/4th gear pressure switches, and transmission fluid some time next week. I was looking over the previous owner's service records and realized he had been having cheap places like jiffy lube change the transmission fluid at random intervals. I've also noticed a little hesitation between shifting at 3rd and 4th gear, and I've heard changing the fluid and pressure switches would fix the problem. So that brings me to the point of this thread:
The question here is which fluid should I get, how much of it, and where is it available at a decent price?
I've heard of Amsoil and Redline, but there's a few different types of each and I'd really not get stuck with over 100 bucks of fluid that's of no use to me Links would be awesome, or if you know stores in the NoVa area that would be cool too so I won't have to wait/pay for shipping
Also, during the 3x3 drain/fill process, during which drain/fill do you guys think it would be best to change the filter? I was thinking maybe the last since that would be the time when the fluid would be cleanest/purest/newest.
Thanks everyone for your input.
I was in the same position as you. I have a 2008 TL-S w/ 32k mile on it and was debating if i should do my 3x3. After reading through the threads on Racing ATF and reading about everyone's result, I decided it was a sure enough thing to switch off Z1 to Redline racing.
http://www.amazon.com/Red-Line-Racin...6890562&sr=8-1
Amazon is probably one of the cheapest. Free shipping and no tax.
I didn't change my pressure switches or my tranny filter, so someone else will chime in on that.
08 MDX, 04 TL (sold)
I did the switches and a single drain and fill with Redline. I felt like I had purchased a brand new transmission. Cured the stuttering and shifts like new now. 15k later and I'm still happy (and ready for my next drain and fill with Redline.
To the OP,
I did the 3x3 on my 04 with AMSOIL Super Shift Racing fluid w/ NO friction moldifiers. Prior to doing so, the tranny had shuttered on me a couple of times going into 4th gear. I have not done my pressure switches yet but I will get to it before spring. All I can say is the fluid really did make a world of difference and stopped the shuttering. It is now ~3000 miles later, and I am still good to go. It was around 135 shipped to my door for 11 quarts of the fluid. I bought a couple extra just to have them in the garage.
Hope this helps.
Hope this helps.
Chapter Leader (Houston)
Go with the Redline Racing fluid and if you're not totally comfortable with that you can go for a Racing/D4 mix like I did. I did that basically to introduce the Racing fluid slowly. I will do a 1x3 with the racing fluid in a few months. As for the filter, I did mine just before I did the 3x3. I changed the switches about a year ago when I had Z1 fluid.
Sorry for the person I'm quoting
"Type F fluid is a BIG NO NO, it has detergent in it and will destroy the seals in the soliniod within 3-6 months (seen it happen). Other Honda trans I have seen run with Dextron I,II,III usually have clutch failures quickly."
I was planning to go for a Type F, but after reading numerous of threads of people asking so many questions about Type F, I have decided to go for the D4 instead. If I do a 3x3 drain/fill will it completely drain out all of the Z1?
Also, since Acura transmissions are the same as Honda's it's safe to use Redline D4 on a 2004 Honda Pilot?
I think that most of the transmission experts are tired of posting the same comments on trans fluid. All the answers can be found in a couple of very long threads if you search.
Basically Z1 is hated, Redline Racing is preferred (or a mix with Redline light weight racing), Amsoil has been used and Redline D4 (if you're scared to use racing or worried about the warranty). Some people still stick with Z1 but change it more often than the 60k or 100kmi interval.
I called Acura Care and they told me that using a compatible fluid that is NOT Z1 will NOT void your warranty.
Good to know, but posting a short, quick answer for someone like me would make life a lot easier than reading countless pages of countless dead threads.
Anywho... After reading up on the forum and doing some google magic for the last 4 hours, I bit the bullet and bought redline racing fluid from amazon for about 120$...
I'll post my results when the fluid, trans filter, and pressure switches finally come in and are installed. I'm expecting a torrent of awesomeness.
To see why RedLine Racing is better, check this thread below.
Racing ATF (click here)
I know this is a long thread to read. But, you can read it backwards. Read the last page first and then read each previous page.
On Page 14 (second half of the page), you will see pics of the trans drain plug filled with clutch material. Be sure to read the second half of Page 14 because it will answer your question. The Racing stops all of the clutch wear. No fluid except a type F fluid (such as Racing or Lightweight) is able to stop the clutch wear. There are many trans on our 3G forum that have failed due to clutches that are completely worn down.
Thanks for chiming in Innacurate, I'm glad to see that I'm on the right track!
I read some of your older posts along with some of IHC's (funny how thats turned into his nickname, lol) and decided to go for it.
As for mixing it with the lightweight, I don't think I'm going to mess too much with that. I'm not too worried about it, and I've also already ordered 12 quarts of racing fluid. Worst case, I'll start mixing in lightweight if I notice negative results after the first 1x3 interval. (correct me if I'm wrong here, lol)
http://www.redlineoil.com/product.aspx?pid=52&pcid=9
Dogmatic Dinosaur
I used Dex III on a rebuilt tranny for my 92 accord and it had 340K and was still going stong when I got rid of my car. It would sometimes downshift harder when I used cheap fluid (had a stupid issue with axle wanting to pop out for a while), but if I used synthetic Dex III, it was awesome - I used the Mobil 1.
I had a similar problem, my car would sometimes jitter when switching between 3rd and 4th gear. I took it to the acura dealership and they basically told me i needed a new transmission,
but since i had a aftermarket extended warranty, my warranty wanted me to go to one of their shops. So i took my car home and called my buddy that works for Acura. i told him my situation and what the car was doing and he basically said the service manager was a moron, and all i needed was to flush my transmission fluid. so I got him to do it and the jitter is gone. It runs perfect!!!!
08 tl type s 6-shift
I change brake fluid, steering fluid& transmission fluid regularly once every 35k with the acura fluids. they are kinda cool.
I usually bought them from
http://acura.bernardiparts.com/Acura...798-9031A.aspx
damn there are so many threads on transmission fluid, lol. good grief. Im at 30k on my 08 TL 5AT and am going to do the 3x3 drain and fill soon. I most likely will try the mobil 1 ATF first and see how it does just because its easier to obtain locally. Then maybe ill switch to the appraised redline racing ATF from amazon after.
right now my engine/transmission will hesitate and "bump" from park to drive, neutral to drive, and usually coming out of first gear into second it seems to hesitate as well, almost stutters.
Switches will cure the bump into gear. Fluid will cure a 1-2 shudder.
Yes sir. When you go from park or neutral to drive, the transmission engages 3rd gear and then first gear. This reduces that jerk you feel when shifting into gear. When the switch values start to change, the trans stays in 3rd too long and you can feel the double bump of it going from 3rd to 1st. Normally it's so quick you don't feel it.
lately my car has been feeling more of a jerk going from N or P to D. i might do the switches soon.
3rd has less leverage on the wheels so when you go from no load (park) to third and it applies power to the wheels, you don't get a jerk. Once the power is applied it can go down to first and you don't feel it. Same thing if you started off in third in a manual, you would have no acceleration but you also wouldn't have to worry about it snapping your head back.
Look in the "racing atf" and "very interesting conversation with my trans builder" threads. Tons of 3g failures around here. Tons of near failures with flares and shudders cured with the type F fluid and pressure switches.
I can attest fot what IHC is saying. 3rd and 4th sensors and Redline Racing ATF cured me of the shutter which I knew what just the feeling of my transmission destroying itself. I now feel much more confident of my transmissions lifespan. 10k miles so far, and so good.
so wait....... there are three different redline racing ATF fluids? Redline Racing, Redline Racing Type F, and Redline Racing D4. What exactly are people using cause now im confused
im sorry, but what are the differences? is this the one used by many on acurazine?
There's only one Redline Racing. It's Type-F.
There's Redline D-4 which is a Dex III.
