Old 07-03-2013, 12:14 PM
  #1001
gilla_monster's Avatar
Not so sure the LED DRL fix would work since they only receive 6v instead of the 12v needed to power most LED bulbs. Damn...
Old 07-03-2013, 03:57 PM
  #1002
Engineer in Training
LockDots's Avatar
What are you trying to fix? A relay harness would supply 12V to both bulbs.
Old 07-15-2013, 10:16 AM
  #1003
mrsimeon's Avatar
Thumbs up Resistors I have 0.12 I can ship out my extra batches
Originally Posted by TotalTL
i went to radio shack and all they had were 10 ohm 1 watt resistors with 5% tolerance. would 10 ohms be too much? just want to make sure because i figured i could just go and buy them instead of waiting a week for them to come.
I have a batch of extra 0.12 ohm resistors.
I did my mod- to my relay-
If anyone needs resistors. I can mail them out to you-
Just pay a few bucks.
Old 09-04-2013, 01:00 PM
  #1004
itsdadadavid's Avatar
Is this the right resistor?
http://www.radioshack.com/product/in...uctId=12566016
I'm only asking because it looks different from the ones you guys use. The info is right but wasn't sure because it didn't look the same lol.
Old 09-04-2013, 04:18 PM
  #1005
LockDots's Avatar
It's 0.12Ω and 1W so you should be fine.
Old 09-11-2013, 03:14 PM
  #1006
Received 8,568 Likes on 6,621 Posts
Thanks to Roger555 for this mod. I was able to perform it on my 08 TL -S with a .24 ohm 1 W resistor and have both front and rear LEDs. If anyone is uncomfortable soldering but wants this done, I bought extra resistors and can perform it for you for a few bucks (for shipping) , PM me!!
Old 09-11-2013, 03:16 PM
  #1007
takin care of Business in
swoosh's Avatar
^^^ who is Roger555
he is da bomb....he has done couple great DIY's
Old 11-20-2013, 02:07 PM
  #1008
BANNED
Tl4eva's Avatar
Just did this yesterday. Work like a champ. Thanks for the DIY my friend
Old 12-04-2013, 06:35 PM
  #1009
killer8rican's Avatar
Remember if you put all four led turn signal youll need 2x resistors totalling .24 ohms
Old 12-05-2013, 09:06 AM
  #1010
Weezy2328's Avatar
what do I need for front switch back?? 12ohm??
Old 12-05-2013, 10:37 AM
  #1011
Chapter Leader (Eastern Canada)
abrieluno's Avatar
.12 ohms
The following 2 users liked this post by abrieluno:
mrsimeon (12-09-2013), swoosh (12-07-2013)
Old 12-07-2013, 12:46 PM
  #1012
swoosh's Avatar
12 ohm...
decimal brahhh !!!
abrieluno (12-08-2013)
Old 12-08-2013, 09:37 PM
  #1013
coffeebowl's Avatar
anyone have any extra .12 ohm resistors?
is installing a resistor the only way to make an led bulb work as the headlight turn signal... or is there just a plug n play out there somewhere?
Old 12-09-2013, 05:27 AM
  #1014
there are load resistors but require tapping the oem wiring, i have couple extra resistors also lemme know
coffeebowl (12-09-2013)
Old 12-09-2013, 06:54 AM
  #1015
coffeebowl's Avatar
awesome, I will buy one off of you.
Old 12-09-2013, 06:37 PM
  #1016
mrsimeon's Avatar
do you still have any .12 ohm resistors left?[/QUOTE]
HEY COFFEEBOWL....you need to delete some messages from your inbox.
Dont do the Load resistors, do this MOD with the relays, it does work and its Very easy, to do.
HI Coffeebowl. , Yes I have more Resistors.
Do you need ONE, or Two. just let me know how many you need,
and GIVE Me your mailing address so I can figure how much it will cost me to put these in an envelope for you.
Thanks for asking.
Sim
Old 12-09-2013, 06:39 PM
  #1017
mrsimeon's Avatar
YEs 0.12 Ohms, you need,
NOT 12 ohms.
Old 12-10-2013, 07:31 AM
  #1018
Weezy2328's Avatar
how do I solder the resistor?? people r sayin on the back but then the picture in the beginning shows different so idk what to do....my leds come in today
Old 12-10-2013, 11:26 AM
  #1019
swoosh's Avatar
you will remove the shunt resistor and install this the same way....
all soldering will be done on 1 side and components on the other
Old 12-10-2013, 12:37 PM
  #1020
Weezy2328's Avatar
okay very good and were can I get the resistor from locally? radio shack?
Old 12-10-2013, 12:51 PM
  #1021
swoosh's Avatar
I didnt get one a radioshack...I found someone selling it on the forums
Old 12-10-2013, 01:23 PM
  #1022
Weezy2328's Avatar
ok do u or anyone no any places??
Old 12-10-2013, 01:25 PM
  #1023
Weezy2328's Avatar
and this works with 08 tl type s correct??
Old 12-10-2013, 03:16 PM
  #1024
donaldoo's Avatar
Hey guy anybody have a extra resistor
PM please
Old 12-11-2013, 08:06 AM
  #1025
Weezy2328's Avatar
RESISTOR 1 WATT METAL OXIDE FILM FLAMEPROOF .12 OHM 5% AXIAL LEAD 10/PKG: Amazon.com: Industrial & Scientific RESISTOR 1 WATT METAL OXIDE FILM FLAMEPROOF .12 OHM 5% AXIAL LEAD 10/PKG: Amazon.com: Industrial & Scientific
this will work??
Old 12-11-2013, 08:08 AM
  #1026
Weezy2328's Avatar
http://www.sourceresearch.com/store1...8186&do=detail
or this?? I need to order asap
Old 12-11-2013, 08:40 AM
  #1027
pearl905's Avatar
Follow this tread, go to digi-key and order these ones...
https://acurazine.com/forums/showthread.php?t=815219
Old 12-11-2013, 12:39 PM
  #1028
Weezy2328's Avatar
i got the one from amazon.....should be fine?? its .12ohms 1 watt??
Old 12-11-2013, 09:13 PM
  #1029
vietxquangstah's Avatar
Those should work just fine for only 2 LED bulbs (Front 2 or Back 2). If you want to save time you can just solder a 0.24 ohm one and when you're ready to put LEDs in the front & rear you won't have to solder anymore because the resistor is already in place.
0.12 ohm resistors
http://www.digikey.com/product-detai...CCT-ND/2059055
Old 12-12-2013, 03:04 AM
  #1030
Wow Amaze Such TL-S
Kaiii's Avatar
thx again roger for writing this up.
so, i got my switchbacks, cheap soldering iron, solder, and resistor.
the turn signal relay was a HUGE pain in the butt to remove, but I now know how hard to pull it.
problem is, i'm scared as hell to solder anything on the back of that tiny board - anyone have any tips for exactly how they went about the procedure of removing the oem shunt resistor and installing the 0.12 ohm resistor? Like a more detailed explanation for someone like me with zero experience soldering would be very helpful (how much solder to use, how to avoid making it messy/lumpy, as the cleaner it is, the less chance of solder running across circuits on the board and screwing up, etc.) Also, would you guys recommend using a very small / fine tip for the soldering iron, or is it really not necessary? I understand the basic process of soldering, I just really didn't expect other important components on the board to be soooo close. Perhaps I'm overthinking this.
Old 12-12-2013, 07:07 AM
  #1031
you're over thinking it. I never soldered anything before until I did this mod. I bought a cheap radio Shack kit and watched 2 YouTube videos on how to solder and did it myself
Old 12-12-2013, 09:32 AM
  #1032
EvilVirus's Avatar
^ Yeah it was my first time soldering too. It came out like crap at first but I re-did it.
Weezy2328 you know you can edit your post within 15 mintues instead of posting a new post every 2-3 minutes.........just saying
Old 12-13-2013, 06:02 AM
  #1033
Weezy2328's Avatar
hey guys so I did my solderin last night ( had my dad do it since hes more handy then me) it looks like a clean solder.....so I put the relay back in and then I went to take the signal bulbs out of my 08 tl type s and I was pullin it and then just gave out and then did some research to see that u have to push down and twist so I will be doin that today.....my question is that my turn signals still work and my hazards and all...is that normal or are they suppose to not work?? im putting in my leds in today..
Old 12-13-2013, 09:31 AM
  #1034
yes you are supposed to push down and untwist it
yes your turn signals are supposed to work still including hazards. I don't get why that's even a concern. Did you expect doing this mod will make your turn signals and hazards not work?
I would be asking questions if they stopped working
Old 12-13-2013, 11:13 AM
  #1035
Weezy2328's Avatar
i just sayin since I put in that resistor and it still has the stock bulbs just making sure...ill be putting in the leds today after work
Old 12-13-2013, 11:23 PM
  #1036
Everything work out fine?
Old 12-14-2013, 07:15 AM
  #1037
Weezy2328's Avatar
yea came out perfect....give a nice look thank you guys
Old 12-15-2013, 11:53 AM
  #1038
viking00's Avatar
Anybody sell the relays with the resistor already soldered in?
I'd pay for one already done so I can remove the switchbacks and relay and put the original back in if/when I sell the TL.
Old 12-15-2013, 03:04 PM
  #1039
No need. Just remove the switchbacks and leave the relay in there. Even if it has the 0.12 or 0.24 ohm resistor soldered in it, it will still function and work with regular non LED bulbs (halogen factory style bulbs)
Old 01-03-2014, 08:10 PM
  #1040
LP700-4's Avatar
Help everyone I just did this mod with 2 0.12ohm 1W resistors in series. Turn signals work only when headlights are off?
I have LED's in all 4 corners.
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
