HonData Flash Pro for '07-'08 Base TL and '07-'08 TLS
Yes Guys this is TRUE! I've been working closely with Doug and the guys from Hondata and they HAVE come out with the Flash Pro For the 07-08 3.2 TL and the 07-08 3.5 TLS. They used my vehicle to come up with a Flash for the 3.2S/C application. I will post up Graphs and pics when I get home tonight. Here is the link for your viewing pleasure!
It will available for purchase in early January of 2013
http://www.hondata.com/flashpro_07-08_tl.html
The following 21 users liked this post by ziggyh22:
04WDPSeDaN (12-18-2012),
BostonSilverTypeS (12-18-2012),
BU (12-29-2012),
CBP08TL (12-18-2012),
Derek Killian (12-18-2012),
and 16 others liked this post.
Blue line is from FIC dont know why it dosent have the before HP figures but at the the time my car was mostly stock except for ATLP J-Pipe. Not bad for Auto and my belt was slipping only getting 3maybe 4lbs of boost and 3-2lbs from 5000 rpm to redline Which in a way was good cause the stock injectors were already at 90% duty cycle.
Before (dotted blue):
- CT supercharger
- AEM FIC
- Stock injectors
After (solid Orange)
- Hondata TL FlashPro + tuning
- 2 PSI less peak boost (slipping belt)
Doug doing his thing at Church's
I love how my serial number says 0000000 Very first one!
The following 4 users liked this post by ziggyh22:
Horditruck (01-07-2013),
kingkong_dav (12-17-2012),
paperboy42190 (12-18-2012)
Not to be cynical, but I am anxiously waiting for people to start calling BS (don't confuse this as me calling it). I don't even know what to think at this point considering so many people were 100% sure this would never happen...then to have it happen for under $700 is just like whaaaa?!
Unless this doesn't do what I think it does...This is for 100% tunability while keeping all factory settings enabled, right? (edit: re-read the website description, pretty much what I was expecting)
EDIT 2: Also, makes me want to move away from N/A
The following 5 users liked this post by dandaman15:
Atlas.46 (12-17-2012),
Midnight Mystery (01-21-2022),
NvrDwn (12-17-2012),
SSM4DR (12-24-2012),
VicTL06 (12-17-2012)
The following 3 users liked this post by the fenda rolla:
It should be close to the gains seen by the J and R ecu. Probably around 15-20 whp and more with mods. I dont think any of these j series have VTEC on exhaust side.
Got to tell my friend to start advertising to take pre-orders.
Nice been following your build and this will be awesome on your setup!
Yeah man this is pretty huge you shouldve seen my smile on my face when I got the call from Doug! Now I LOVE my car more than ever
The following 2 users liked this post by ziggyh22:
contemplating future mods
Sub'd so I can research this a little more. If anybody closeby to me (NY/ Hudson Valley) can help me out with this I am 99% sure that I will buy this as a Christmas gift...
Is this a one time offer (limited release) or will this be available for a while?
All motor
Hehehehehe. I knew about this
Great news. I wasn't sure what years it would be for, but this is great. Now, how to get this to work for the 03-07 Accords and 04-06 TL is the question. I'm in 100% as long as I can get it to work for my car. Thank you Hondata! It's about time!
ziggyh22 (12-18-2012)
KingKong_Dav
Ziggy wassup! Thank you for your hard work n effort. I remember you were the 1st guy ever with a backward h22a head on your engine n the 1st guy with a 2nd gen supercharger on a 3rd gen.. now 1st hondata. User. Awesome! So does this mean US ua7 guys can supercharge w hondata support?
The following 6 users liked this post by VicTL06:
alexpapas90 (05-04-2016),
MistahWes06TL (01-10-2013),
NIGHTEHAWK (12-18-2012),
TLove It! (12-18-2012),
and 1 others liked this post.
The following 12 users liked this post by anx1300c:
Atlas.46 (12-18-2012),
Joneill44 (12-24-2012),
kibbles906 (12-18-2012),
NvrDwn (12-18-2012),
and 7 others liked this post.
All motor
^ Lulz. I'm sure there will be a way to make this work for the 04-06 TL. If so, I will be purchasing an 04-06 ECU pronto.
Look at the gains the OP saw. The peak gains were nearly identical but the low-midrange gains are incredible. He saw ~50wtq around 3K RPM and 15-20whp/20-30wtq throughout the entire rev range. Yes, it's a boosted application, but with basically no other mods besides the ATLP Jpipe as stated. Although OP, in your sig it says you have a lot more than just the Jpipe?
I'm really hoping this will pan out for the 04-06 TL as well so that we can all use this. If so, I will be ordering it as soon as it's available.
Sonnick (12-18-2012)
Wait thinking about it now.....................
Shit no ecu modification should be needed for the 03-07 accords , we should plug and play just like the 04-06 tl......why ?
Because fp connect thru obd port not hardwired in ecu, we just wouldnt get same expected wtq as em on the fp basemap
All motor
^ It 'flashes' the ECU. This is not like the JnR where it replaces the ECU. It plugs into the OBDII port as Jiga said and you tune it that way from what I understand.
I'm not exactly sure of the specifics, but that's what I gather.
Then u simply unplug your flashpro once tuning session is completed and store it in your room till your ready to retune or flash back car exactly back to stock ecu.
Here's an answer In advance....No you cant borrow someones flashpro and tune someone elses car as it remains faihful to 1 car @ a time
All motor
^ Correct.
Because of this it will NEVER be needed
Programmable ECU interface.
Connects via OBDII diagnostic port.
USB 2.0 connection
Works with Laptop or Desktop
No ECU modification necessary.
Live tuning
20 hours on board datalogging memory.
FlashProManager Windows software.
Check and clear diagnostic codes.
Customizable laptop gauges.
Readiness codes and smog check status.
Dual calibration storage - upload from one of two calibrations stored in the FlashPro.
Ignition, fuel, idle speed, table editing.
VTEC window.
MAP sensor based tuning.
Rev and launch limiters.
Map tracing & lambda overlay.
Expanded fuel, ignition and knock tables for forced induction.
4 bar MAP sensor support (43 psi).
Support for larger injectors.
Injector latency / dead time.
Individual cylinder fuel & ignition trim.
Individual cylinder knock count
Works with Hondata Traction control
Starting calibrations for NA, forced induction & larger injectors.
That HDtcs is such a big win for the J boys that are boosting
Look at HDtcs in action to see why
The following 4 users liked this post by jiga21:
