Suspension block of some sort to help against scraping?
Old 04-19-2014, 11:20 PM
Gabriel Alejandro Iser
Xxb005txx's Avatar
Exclamation Suspension block of some sort to help against scraping?
Hello fellow enthusiast. SO i've heard from and older individual that supposedly there is a piece in the form of some time of block or cube. This is meant to help stop the scraping of the tires and the fenders. I was told they sold this at the local autoparts stores. Thing is the guy was drunk so idk if what he said then and there was legit or if it was crap. lol. help anybody? I swapped out my OEM wheels and rims for 17s with a wider tire width a long time ago. Whenever i catch a dip or train track or slight unlevel spot in the road my cart bounces and the tire hits the fender,making a painful scrape on my tire. Hope this helps answering my problem!
Old 04-20-2014, 03:05 AM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
You mean like a bump stop? You only need to stop the suspension stroke to a point and that its what the Bump Stop do...
Old 04-20-2014, 10:29 AM
Xxb005txx's Avatar
so thats real then!? and how would i do that? Sometime if i take a normally average turn ill scrape the back tire. I can stop that without it getting worse when i drop it?
Old 04-20-2014, 11:30 AM
3.2TLc's Avatar
Unhappy scrapin' & bumpin'...........
If ya are scraping presently on stock suspension, the chances are that ya will need to pull, roll, and trim ........ once ya drop the car. Alot depends on the rim's width and offset......along with the tire diameter.
Old 04-20-2014, 03:12 PM
Skirmich's Avatar
Amen
Old 04-20-2014, 04:32 PM
HE>i
05_NBP_TL's Avatar
Yes, they make a rubber spacer that goes in between the coils of your springs. It keeps the springs from compressing as much. They can be bought at automotive stores (advanced auto, O' reilly, Autozone, etc. ). I used them before to temporarily stop from scrubbing. I eventually trimmed my inner fender lips (with a dremel) to add more clearance. This was 12 years ago when I first bought my 99 TL so I was unaware of "rolling" fenders back then.
Old 04-23-2014, 09:07 AM
Xxb005txx's Avatar
so i can drop the car and still put these bump stoppers?
Old 04-23-2014, 04:16 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
NO. What the guy was talking about was simply a rubber piece designed to go between the coils (usually on a sagging suspension) to help add some lift. You can not use those to solve your problem. You need to
A: Get different rims that fit properly
B: Roll/Stretch your fenders to get the wheels to fit.
C: Both A & B
Old 04-24-2014, 04:52 AM
Xxb005txx's Avatar
So what's "rolling" your fender n how do u do it? Im a bit of a noob
Old 04-24-2014, 07:02 AM
fsttyms1's Avatar
First off, what is the offset to your rims? Its usually stamped on the back of the rim.
Where are you rubbing? Front AND Rear? just the rear?
Here is a video.
Xxb005txx (04-24-2014)
Old 04-24-2014, 11:24 AM
Xxb005txx's Avatar
Idk what my offset is to be honest,and it rubs n the back, mostly on the drivers side. Theyre 17s. I can check the exact tire specs later on after work. And will rolling my fender be an arm and a leg kinda job?
Old 04-25-2014, 11:11 AM
fsttyms1's Avatar
Take a wheel off and look at it. It should have the offset cast into it.
Have you tried trimming the tabs to see if that is your rubbing issue? (look in DIY thread for tab trimming)
As for rolling cost, usually not to bad, sometimes you can find a place to rent the tool and do it yourself. Personally from knowing how easy it is i wouldnt pay more than 200 for the 2 rear quarters to be rolled.
Old 04-25-2014, 07:34 PM
Xxb005txx's Avatar
so the offset is cast into the back of the rim on the inner part? and trimming the tabs? is that an easier alternative to rolling a fender?
Old 04-26-2014, 06:44 AM
3.2TLc's Avatar
Try pulling a rim and check for stamping.
Easy enough to trim the tabs.....check the past threads for simple "DIY"s if unsure how to do it. Have someone push down on the car's fenders while ya look at the tire positioning noting where clearance may be needed.
Old 04-26-2014, 06:55 AM
fsttyms1's Avatar
Usually. And yes, it is easierIF that is all that needs to be done. It is NOT a replacement or fix for not having to roll fenders if that is what really needs to be done.
Old 04-26-2014, 10:58 AM
Xxb005txx's Avatar
Shit. Im such a noob. Anyway anybody can paste hte DIY link for tab trimming? I couldnt seem to find it. And ill see if i can get the offset soon. IS there any specific way that the numbers look so i can know what it is im looking for?
Old 04-26-2014, 12:56 PM
fsttyms1's Avatar
DIY page, 5th one down
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Xxb005txx (04-27-2014)
Old 04-27-2014, 09:51 AM
Xxb005txx's Avatar
Old 05-03-2014, 08:00 AM
peewizzle's Avatar
what size tires do you have? from the pic in your avatar it looks like you have something like 225/55/17 and size like that would probably cause the rubbing in the rear. if you are planning to lower, i'd suggest thinner profile/correct size tire depending on your drop goals
Old 05-04-2014, 10:44 AM
Xxb005txx's Avatar
damn..that seems so legit that it may be right. lol. fuck i hate being a noob. ANd i was told yesterday i outta buy a camber kit so i wont need to roll my fenders, i just dont wanna make my car look like a hover craft n shit. lol. well the rear tires tho are actually 245 i believe
Old 05-04-2014, 07:31 PM
fsttyms1's Avatar
Get ALL the Actual Rim and Tire info, not i think or believe. We can better help you. And a camber kit will only help so much. The more camber you add the faster your tires will wear out.
Old 05-04-2014, 10:15 PM
Xxb005txx's Avatar
just got back from seeing my rear tire info, and this is what it says: 245/40ZR18 97W. i cant seem to get under the car to see the offset in the back of the rim since i dnt have a jack n im a big nigga.lol. thats all i can see for now :/
Old 05-05-2014, 08:36 AM
fsttyms1's Avatar
You dont have the oem jack? Take the rim off.
And odds are because of that tire size your rim has a pretty low offset and that is your issue.
Old 05-05-2014, 05:57 PM
3.2TLc's Avatar
If ya misplaced your jack, ya could try turning the front wheels and it may be easier to find a marking on the inner rim. Ya may need to clean a bit or need a flashlight to help. Also, ya might have to spin the wheel 180'.
Ya really need to locate or buy a jack !!!
Old 05-08-2014, 11:45 AM
Xxb005txx's Avatar
My front wheels are a different spec range tha my rears :/ and i got ripped off when it comes to the jack cuz i got my car at a used lot with no jack -_- Imma need to to that this weekend perhaps.
MrHeeltoe
20
02-23-2023 01:54 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Suspension block of some sort to help against scraping?
